fsl_pwm integer conversion failure?
973 次查看
choix361
The processor is RT1064.
Release Name: MCUXpresso Software Development Kit (SDK)
Release Version: 25.12.00
In fsl_pwm.c line 790,
pulseCnt = pulseEndCnt - base->SM[subModuleSync].INIT + 1U;
Each term is uint16_t.
When pulseEndCnt < base->SM[subModuleSync].INIT, the result can be negative as int32_t. pulseCnt(uint16_t) will take the result and upper two bytes would be truncated. What would be the proper casting to keep the intention?
946 次查看
mayliu1
Hi @choix361 ,
Thank you so much for your interest in our products and for using our community.
Please notes that RT1064 eFlexPWM count-related registers are defined as signed 16-bit values.
I suggest you can try to do the arithmetic in int32_t , and only then convert to uint16_t after range checking.
int32_t pulseCntCalc = (int32_t)(int16_t)pulseEndCnt - (int32_t)(int16_t)base->SM[subModuleSync].INIT + 1;
if(( pulseCntCalc < 0) || (pulseCntCalc > UINT16_MAX))
// you can print log and handle invalid range
else
pulseCnt = (uint16_t)pulseCntCalc;
Wish it helps you
Best Regards
MayLiu
930 次查看
choix361
I saw many cases fall into if statement. Is it ok to intentionally truncate the data here?
Or set PulseCnt to certain fixed value?
if((pulseCntCalc < 0) || (pulseCntCalc > UINT16_MAX))
    //Intentionally truncate data
    pulseCntCalc = pulseCntCalc & 0x0000FFFF;
806 次查看
mayliu1
I don’t recommend truncating the value. It’s better to first identify the root cause of why it exceeds the valid range.
%3CLINGO-SUB%20id%3D%22lingo-sub-2338796%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Efsl_pwm%E6%95%B4%E6%95%B0%E8%BD%AC%E6%8D%A2%E5%A4%B1%E8%B4%A5%EF%BC%9F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2338796%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%A4%84%E7%90%86%E5%99%A8%E6%98%AF%20RT1064%E3%80%82%3C%2FP%3E%3CP%3E%E7%89%88%E6%9C%AC%E5%90%8D%E7%A7%B0%EF%BC%9AMCUXpresso%20%E8%BD%AF%E4%BB%B6%E5%BC%80%E5%8F%91%E5%A5%97%E4%BB%B6%20(SDK)%20%3CBR%20%2F%3E%20%E5%8F%91%E5%B8%83%E7%89%88%E6%9C%AC%EF%BC%9A25.12.00%3C%2FP%3E%3CP%3E%E5%9C%A8%20fsl_pwm.c%20%E4%B8%AD%E7%AC%AC%20790%20%E8%A1%8C%E3%80%81%3C%2FP%3E%3CP%3EpulseCnt%20%3D%20pulseEndCnt%20-%20base-%26gt%3BSM%5BsubModuleSync%5D.INIT%2B1U%EF%BC%9B%3C%2FP%3E%3CP%3E%E6%AF%8F%E4%B8%AA%E9%A1%B9%E9%83%BD%E6%98%AF%20uint16_t%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E5%BD%93%20pulseEndCntSM%5BsubModuleSync%5D.INIT%EF%BC%8C%E7%BB%93%E6%9E%9C%E5%8F%AF%E8%83%BD%E4%B8%BA%E8%B4%9F%E5%80%BC%20int32_t%E3%80%82PulseCNT%20(uint16_t)%20%E5%B0%86%E8%8E%B7%E5%8F%96%E7%BB%93%E6%9E%9C%EF%BC%8C%E4%B8%8A%E9%9D%A2%E7%9A%84%E4%B8%A4%E4%B8%AA%E5%AD%97%E8%8A%82%E5%B0%86%E8%A2%AB%E6%88%AA%E6%96%AD%E3%80%82%E6%80%8E%E6%A0%B7%E6%89%8D%E8%83%BD%E4%BF%9D%E6%8C%81%E8%BF%99%E7%A7%8D%E6%84%8F%E5%9B%BE%EF%BC%9F%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2339483%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20fsl_pwm%20integer%20conversion%20failure%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2339483%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3Eif((%20pulseCntCalc%26lt%3B%200)%20%7C%7C(pulseCntCalc%26gt%3B%20UINT16_MAX))%3C%2FP%3E%3CP%3E%7B%3C%2FP%3E%3CP%3E%20%20%20%20%2F%2F%20%E5%8F%AF%E4%BB%A5%E6%89%93%E5%8D%B0%E6%97%A5%E5%BF%97%E5%B9%B6%E5%A4%84%E7%90%86%E6%97%A0%E6%95%88%E8%8C%83%E5%9B%B4%3C%2FP%3E%3CP%3E%7D%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E6%88%91%E7%9C%8B%E5%88%B0%E5%BE%88%E5%A4%9A%E6%83%85%E5%86%B5%E9%83%BD%E5%B1%9E%E4%BA%8E%20%3CEM%3E%3CSTRONG%3E%E5%A6%82%E6%9E%9C%E8%AF%AD%E5%8F%A5%3C%2FSTRONG%3E%3C%2FEM%3E.%E5%9C%A8%E8%BF%99%E9%87%8C%E6%95%85%E6%84%8F%E6%88%AA%E6%96%AD%E6%95%B0%E6%8D%AE%E5%8F%AF%E4%BB%A5%E5%90%97%EF%BC%9F%3C%2FP%3E%3CP%3E%E6%88%96%E8%80%85%E5%B0%86%20PulseCnt%20%E8%AE%BE%E7%BD%AE%E4%B8%BA%E6%9F%90%E4%B8%AA%E5%9B%BA%E5%AE%9A%E5%80%BC%EF%BC%9F%3C%2FP%3E%3CP%3Eif((pulseCntCalc%26lt%3B%200)%20%7C%7C%20(pulseCntCalc%26gt%3B%20UINT16_MAX))%3CBR%20%2F%3E%7B%3CBR%20%2F%3E%20%2F%2F%20%E6%95%85%E6%84%8F%E6%88%AA%E6%96%AD%E6%95%B0%E6%8D%AE%3CBR%20%2F%3E%20pulseCntCalc%20%3D%20pulseCntCalc%26amp%3B%200x0000FFFF%3B%3CBR%20%2F%3E%20pulseCnt%20%3D%20(uint16_t)pulseCntCalc%3B%3CBR%20%2F%3E%7D%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2339141%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20fsl_pwm%20integer%20conversion%20failure%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2339141%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F192846%22%20target%3D%22_blank%22%3E%40choix361%3C%2FA%3E%EF%BC%8C%3C%2FP%3E%0A%3CP%3E%E9%9D%9E%E5%B8%B8%E6%84%9F%E8%B0%A2%E6%82%A8%E5%85%B3%E6%B3%A8%E6%88%91%E4%BB%AC%E7%9A%84%E4%BA%A7%E5%93%81%E5%B9%B6%E4%BD%BF%E7%94%A8%E6%88%91%E4%BB%AC%E7%9A%84%E7%A4%BE%E5%8C%BA%E3%80%82%3C%2FP%3E%0A%3CDIV%20id%3D%22tinyMceEditormayliu1_0%22%20class%3D%22mceNonEditable%20lia-copypaste-placeholder%22%3E%26nbsp%3B%3C%2FDIV%3E%0A%3CP%3E%E8%AF%B7%E6%B3%A8%E6%84%8F%EF%BC%8CRT1064%20eFlexPWM%20%E8%AE%A1%E6%95%B0%E7%9B%B8%E5%85%B3%E5%AF%84%E5%AD%98%E5%99%A8%E5%AE%9A%E4%B9%89%E4%B8%BA%E5%B8%A6%E7%AC%A6%E5%8F%B7%E7%9A%84%2016%20%E4%BD%8D%E5%80%BC%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%221.png%22%20style%3D%22width%3A%20749px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%221.png%22%20style%3D%22width%3A%20749px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%221.png%22%20style%3D%22width%3A%20749px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F380332iDE9457499BCB69EB%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%221.png%22%20alt%3D%221.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E6%88%91%E5%BB%BA%E8%AE%AE%E4%BD%A0%E5%8F%AF%E4%BB%A5%E5%B0%9D%E8%AF%95%E5%9C%A8%20int32_t%20%E4%B8%AD%E8%BF%9B%E8%A1%8C%E8%BF%90%E7%AE%97%EF%BC%8C%E7%84%B6%E5%90%8E%E5%9C%A8%E8%8C%83%E5%9B%B4%E6%A3%80%E6%9F%A5%E5%90%8E%E6%89%8D%E8%BD%AC%E6%8D%A2%E4%B8%BA%20uint16_t%E3%80%82%3C%2FP%3E%0A%3CDIV%3E%0A%3CDIV%3E%0A%3CP%3Eint32_t%20pulseCntCalc%20%3D%20(int32_t)(int16_t)pulseEndCnt%20-%20(int32_t)(int16_t)base-%26gt%3BSM%5BsubModuleSync%5D.INIT%20%2B%201%EF%BC%9B%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3Eif((%20pulseCntCalc%26lt%3B%200)%20%7C%7C(pulseCntCalc%26gt%3B%20UINT16_MAX))%3C%2FP%3E%0A%3CP%3E%7B%3C%2FP%3E%0A%3CP%3E%2F%2F%20%E5%8F%AF%E4%BB%A5%E6%89%93%E5%8D%B0%E6%97%A5%E5%BF%97%E5%B9%B6%E5%A4%84%E7%90%86%E6%97%A0%E6%95%88%E8%8C%83%E5%9B%B4%3C%2FP%3E%0A%3CP%3E%7D%3C%2FP%3E%0A%3CP%3Eelse%3C%2FP%3E%0A%3CP%3E%7B%3C%2FP%3E%0A%3CP%3EpulseCnt%20%3D%20(uint16_t)pulseCntCalc%EF%BC%9B%3C%2FP%3E%0A%3CP%3E%7D%3C%2FP%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3CP%3E%E5%B8%8C%E6%9C%9B%E5%AF%B9%E6%82%A8%E6%9C%89%E6%89%80%E5%B8%AE%E5%8A%A9%3C%2FP%3E%0A%3CP%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FP%3E%0A%3CP%3EMayLiu%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2344885%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20fsl_pwm%20integer%20conversion%20failure%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2344885%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CDIV%3E%E6%88%91%E4%B8%8D%E5%BB%BA%E8%AE%AE%E6%88%AA%E6%96%AD%E6%95%B0%E5%80%BC%E3%80%82%E6%9C%80%E5%A5%BD%E5%85%88%E6%89%BE%E5%87%BA%E8%B6%85%E5%87%BA%E6%9C%89%E6%95%88%E8%8C%83%E5%9B%B4%E7%9A%84%E6%A0%B9%E6%9C%AC%E5%8E%9F%E5%9B%A0%E3%80%82%3C%2FDIV%3E%3C%2FLINGO-BODY%3E
