fsl_pwm integer conversion failure?
960件の閲覧回数
choix361
The processor is RT1064.
Release Name: MCUXpresso Software Development Kit (SDK)
Release Version: 25.12.00
In fsl_pwm.c line 790,
pulseCnt = pulseEndCnt - base->SM[subModuleSync].INIT + 1U;
Each term is uint16_t.
When pulseEndCnt < base->SM[subModuleSync].INIT, the result can be negative as int32_t. pulseCnt(uint16_t) will take the result and upper two bytes would be truncated. What would be the proper casting to keep the intention?
3 返答(返信)
933件の閲覧回数
mayliu1
Hi @choix361 ,
Thank you so much for your interest in our products and for using our community.
Please notes that RT1064 eFlexPWM count-related registers are defined as signed 16-bit values.
I suggest you can try to do the arithmetic in int32_t , and only then convert to uint16_t after range checking.
int32_t pulseCntCalc = (int32_t)(int16_t)pulseEndCnt - (int32_t)(int16_t)base->SM[subModuleSync].INIT + 1;
if(( pulseCntCalc < 0) || (pulseCntCalc > UINT16_MAX))
// you can print log and handle invalid range
else
pulseCnt = (uint16_t)pulseCntCalc;
Wish it helps you
Best Regards
MayLiu
917件の閲覧回数
choix361
I saw many cases fall into if statement. Is it ok to intentionally truncate the data here?
Or set PulseCnt to certain fixed value?
if((pulseCntCalc < 0) || (pulseCntCalc > UINT16_MAX))
    //Intentionally truncate data
    pulseCntCalc = pulseCntCalc & 0x0000FFFF;
793件の閲覧回数
mayliu1
I don’t recommend truncating the value. It’s better to first identify the root cause of why it exceeds the valid range.
%3CLINGO-SUB%20id%3D%22lingo-sub-2338796%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Efsl_pwm%20%E3%81%AE%E6%95%B4%E6%95%B0%E5%A4%89%E6%8F%9B%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8B%EF%BC%9F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2338796%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%E3%81%AFRT1064%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E5%90%8D%EF%BC%9AMCUXpresso%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E9%96%8B%E7%99%BA%E3%82%AD%E3%83%83%E3%83%88%EF%BC%88SDK%EF%BC%89%3CBR%20%2F%3E%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%EF%BC%9A25.12.00%3C%2FP%3E%3CP%3Efsl_pwm.c%20%E5%86%85790%E8%A1%8C%E7%9B%AE%E3%80%81%3C%2FP%3E%3CP%3E%E3%83%91%E3%83%AB%E3%82%B9Cnt%20%3D%20%E3%83%91%E3%83%AB%E3%82%B9EndCnt%20-%20%E3%83%99%E3%83%BC%E3%82%B9-%26gt%3BSM%5BsubModuleSync%5D.INIT%20%2B%201U%3B%3C%2FP%3E%3CP%3E%E5%90%84%E9%A0%85%E3%81%AF%20uint16_t%20%E5%9E%8B%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EpulseEndCnt%20SM%5BsubModuleSync%5D.INIT%20%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81%E7%B5%90%E6%9E%9C%E3%81%AF%20int32_t%20%E3%81%A8%E3%81%97%E3%81%A6%E8%B2%A0%E3%81%AB%E3%81%AA%E3%82%8B%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82pulseCnt(uint16_t)%20%E3%81%AF%E7%B5%90%E6%9E%9C%E3%82%92%E5%8F%97%E3%81%91%E5%8F%96%E3%82%8A%E3%80%81%E4%B8%8A%E4%BD%8D%202%20%E3%83%90%E3%82%A4%E3%83%88%E3%81%8C%E5%88%87%E3%82%8A%E6%8D%A8%E3%81%A6%E3%82%89%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E6%84%8F%E5%9B%B3%E3%82%92%E6%90%8D%E3%81%AA%E3%82%8F%E3%81%AA%E3%81%84%E9%81%A9%E5%88%87%E3%81%AA%E9%85%8D%E5%BD%B9%E3%81%AF%E3%81%A9%E3%82%8C%E3%81%A0%E3%82%8D%E3%81%86%E3%81%8B%EF%BC%9F%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2339483%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20fsl_pwm%20integer%20conversion%20failure%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2339483%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3Eif((%20pulseCntCalc%20%26lt%3B%200)%20%7C%7C%20(pulseCntCalc%20%26gt%3B%20UINT16_MAX))%3C%2FP%3E%3CP%3E%7B%3C%2FP%3E%3CP%3E%2F%2F%20%E3%83%AD%E3%82%B0%E3%82%92%E5%87%BA%E5%8A%9B%E3%81%97%E3%80%81%E7%84%A1%E5%8A%B9%E3%81%AA%E7%AF%84%E5%9B%B2%E3%82%92%E5%87%A6%E7%90%86%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%7D%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E7%A7%81%E3%81%AF%E5%A4%9A%E3%81%8F%E3%81%AE%E3%82%B1%E3%83%BC%E3%82%B9%E3%81%8C%3CEM%3E%3CSTRONG%3Eif%E6%96%87%3C%2FSTRONG%3E%3C%2FEM%3E%E3%81%AB%E8%A9%B2%E5%BD%93%E3%81%99%E3%82%8B%E3%81%AE%E3%82%92%E8%A6%8B%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%93%E3%81%93%E3%81%A7%E6%84%8F%E5%9B%B3%E7%9A%84%E3%81%AB%E3%83%87%E3%83%BC%E3%82%BF%E3%82%92%E5%88%87%E3%82%8A%E6%8D%A8%E3%81%A6%E3%81%A6%E3%82%82%E5%95%8F%E9%A1%8C%E3%81%AA%E3%81%84%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%EF%BC%9F%3C%2FP%3E%3CP%3E%E3%81%BE%E3%81%9F%E3%81%AF%E3%80%81PulseCnt%E3%82%92%E7%89%B9%E5%AE%9A%E3%81%AE%E5%9B%BA%E5%AE%9A%E5%80%A4%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%EF%BC%9F%3C%2FP%3E%3CP%3Eif((pulseCntCalc%20%26lt%3B%200)%20%7C%7C%20(pulseCntCalc%20%26gt%3B%20UINT16_MAX))%3CBR%20%2F%3E%E3%83%A4%E3%83%BC%E3%82%B8%E3%83%A5%3CBR%20%2F%3E%2F%2F%E6%84%8F%E5%9B%B3%E7%9A%84%E3%81%AB%E3%83%87%E3%83%BC%E3%82%BF%E3%82%92%E5%88%87%E3%82%8A%E6%8D%A8%E3%81%A6%E3%82%8B%3CBR%20%2F%3EpulseCntCalc%20%3D%20pulseCntCalc%20%26amp%3B%200x0000FFFF%3B%3CBR%20%2F%3E%20pulseCnt%20%3D%20(uint16_t)pulseCntCalc%3B%3CBR%20%2F%3E%20%7D%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2339141%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20fsl_pwm%20integer%20conversion%20failure%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2339141%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F192846%22%20target%3D%22_blank%22%3E%40choix361%20%E3%81%95%E3%82%93%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CP%3E%E5%BC%8A%E7%A4%BE%E8%A3%BD%E5%93%81%E3%81%AB%E3%81%94%E9%96%A2%E5%BF%83%E3%82%92%E3%81%8A%E5%AF%84%E3%81%9B%E3%81%84%E3%81%9F%E3%81%A0%E3%81%8D%E3%80%81%E3%81%BE%E3%81%9F%E5%BC%8A%E7%A4%BE%E3%81%AE%E3%82%B3%E3%83%9F%E3%83%A5%E3%83%8B%E3%83%86%E3%82%A3%E3%82%92%E3%81%94%E5%88%A9%E7%94%A8%E3%81%84%E3%81%9F%E3%81%A0%E3%81%8D%E3%80%81%E8%AA%A0%E3%81%AB%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CDIV%20id%3D%22tinyMceEditormayliu1_0%22%20class%3D%22mceNonEditable%20lia-copypaste-placeholder%22%3E%26nbsp%3B%3C%2FDIV%3E%0A%3CP%3ERT1064%20eFlexPWM%E3%81%AE%E3%82%AB%E3%82%A6%E3%83%B3%E3%83%88%E9%96%A2%E9%80%A3%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%81%AF%E3%80%81%E7%AC%A6%E5%8F%B7%E4%BB%98%E3%81%8D16%E3%83%93%E3%83%83%E3%83%88%E5%80%A4%E3%81%A8%E3%81%97%E3%81%A6%E5%AE%9A%E7%BE%A9%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AB%E3%81%94%E6%B3%A8%E6%84%8F%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%221.png%22%20style%3D%22width%3A%20749px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%221.png%22%20style%3D%22width%3A%20749px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%221.png%22%20style%3D%22width%3A%20749px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F380332iDE9457499BCB69EB%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%221.png%22%20alt%3D%221.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E1.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E6%BC%94%E7%AE%97%E3%81%AF%E3%81%BE%E3%81%9Aint32_t%E3%81%A7%E8%A1%8C%E3%81%84%E3%80%81%E7%AF%84%E5%9B%B2%E3%83%81%E3%82%A7%E3%83%83%E3%82%AF%E3%82%92%E8%A1%8C%E3%81%A3%E3%81%9F%E5%BE%8C%E3%81%ABuint16_t%E3%81%AB%E5%A4%89%E6%8F%9B%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E3%81%8A%E5%8B%A7%E3%82%81%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CDIV%3E%0A%3CDIV%3E%0A%3CP%3Eint32_t%20pulseCntCalc%20%3D%20(int32_t)(int16_t)pulseEndCnt%20-%20(int32_t)(int16_t)base-%26gt%3BSM%5BsubModuleSync%5D.INIT%20%2B%201%3B%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3Eif((%20pulseCntCalc%20%26lt%3B%200)%20%7C%7C%20(pulseCntCalc%20%26gt%3B%20UINT16_MAX))%3C%2FP%3E%0A%3CP%3E%7B%3C%2FP%3E%0A%3CP%3E%2F%2F%20%E3%83%AD%E3%82%B0%E3%82%92%E5%87%BA%E5%8A%9B%E3%81%97%E3%80%81%E7%84%A1%E5%8A%B9%E3%81%AA%E7%AF%84%E5%9B%B2%E3%82%92%E5%87%A6%E7%90%86%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%3C%2FP%3E%0A%3CP%3E%7D%3C%2FP%3E%0A%3CP%3E%E3%81%9D%E3%81%86%E3%81%A7%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%E3%80%81%3C%2FP%3E%0A%3CP%3E%7B%3C%2FP%3E%0A%3CP%3EpulseCnt%20%3D%20(uint16_t)pulseCntCalc%3B%3C%2FP%3E%0A%3CP%3E%7D%3C%2FP%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3CP%3E%E3%81%8A%E5%BD%B9%E3%81%AB%E7%AB%8B%E3%81%A6%E3%82%8C%E3%81%B0%E5%B9%B8%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%83%A1%E3%82%A4%E3%83%AA%E3%82%A6%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2344885%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20fsl_pwm%20integer%20conversion%20failure%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2344885%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CDIV%3E%E5%80%A4%E3%82%92%E5%88%87%E3%82%8A%E6%8D%A8%E3%81%A6%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E3%81%8A%E5%8B%A7%E3%82%81%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%81%BE%E3%81%9A%E3%80%81%E3%81%AA%E3%81%9C%E6%9C%89%E5%8A%B9%E7%AF%84%E5%9B%B2%E3%82%92%E8%B6%85%E3%81%88%E3%81%A6%E3%81%97%E3%81%BE%E3%81%86%E3%81%AE%E3%81%8B%E3%80%81%E3%81%9D%E3%81%AE%E6%A0%B9%E6%9C%AC%E5%8E%9F%E5%9B%A0%E3%82%92%E7%89%B9%E5%AE%9A%E3%81%99%E3%82%8B%E6%96%B9%E3%81%8C%E8%89%AF%E3%81%84%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%80%82%3C%2FDIV%3E%3C%2FLINGO-BODY%3E
