can i use jtag_mod as gpio,and use swd debug
ccc_clive
current,the jtag_mod  pin is only pull down to gnd, and no other function.But i want to use this pin as gpio,because no any more pin can use.I do not know the jtag_mod function is check at power on or at debug and download.Is this pin can used as gpio,and use swd debug.
Gavin_Jia
Hi @ccc_clive ,
Thanks for your interest in NXP MIMXRT series!
Unfortunately, that's not allowed. While we call the signal JTAG_MOD, it will still affect SWD function. So if you want any debugging capability (JTAG or SWD), then we should tie that signal to ground and not try to use it as a GPIO.
Gavin
Gavin_Jia
Hi @ccc_clive ,
Gavin
