XRT 1060 EVK conection Problems
Derek3
I'm currently using a MIMXRT1060-EVK and IDE Version 11.6.0
Working with the Easy Evse projrct
I'm Having connectivity issues with the board and the system. I'm following the guide that is provided but I can't seem to make it work. I get a series of Errors but I can't seem to find anything about them in the User guide provided.
These are the Errors I'm getting
How can I correct these errors?
Thanks.
Hui_Ma
First of all, sorry for the later reply.
I am connecting the RT1060-EVK board with a TP-LINK router (no Internet access).
I am not sure if the LAN cause the issue, maybe you could try to connect the RT1060 with an Internet router.
Below is my tested serial info, the output is quite same:
Please let me know if you met the same issue with an Internet router. Then I will check this issue with product team. Thanks.
best regards,
Mike
