Using iMXRT1170 GPU
Using iMXRT1170 GPU
2,784 次查看
Abisheikv2
Hello, I see that iMXRT1170 has a 2D GPU which is used for rendering in LVGL. Can this GPU be used to run any user defined functions? For ex To run a CPU intensive application like a format conversion in GPU. Is there an option to do that or this GPU is purely for video rendering?
Abisheik S.
标记 (2)
2,767 次查看
Omar_Anguiano
Hello
Please be noted that GPU on i.MX RT1170 is only 2D for vector graphics rendering. I apologize for the inconvenience this may cause you.
If you have more questions do not hesitate to ask me.
Omar
2,768 次查看
Omar_Anguiano
Hello
Omar
