Using SDRAM for large data on imxRT1050 EVKB
3,243 次查看
rajtend
I am using iMXRT1050 EVKB.
I have an application which has large data arrays.
I cannot allocate them over heap or stack as the size is quite small.
When I tried to allocate the arrays in NCACHE region, then the application compiles.
However I get hard fault accessing the region.
How to solve this problem?
AT_NONCACHEABLE_SECTION_ALIGN(double arrA[100], 8);
AT_NONCACHEABLE_SECTION_ALIGN(uint32_t arrA1[100], 8);
AT_NONCACHEABLE_SECTION_ALIGN(double arrB[100], 8);
AT_NONCACHEABLE_SECTION_ALIGN(uint32_t arrB1[100], 8);
AT_NONCACHEABLE_SECTION_ALIGN(double arrC[200], 8);
AT_NONCACHEABLE_SECTION_ALIGN(uint32_t arrC1[200], 8);
AT_NONCACHEABLE_SECTION_ALIGN(double arrD[100], 8);
AT_NONCACHEABLE_SECTION_ALIGN(uint32_t arrD1[100], 8);
Linker configuration:
Hard fault:
3,080 次查看
EdwinHz
Hi @rajtend,
I'm afraid I wouldn't be able to tell you what preprocessor definitions are not needed, since this depends on your specific application.
I would recommend you compare your project with one in our SDK examples and go from there.
BR,
Edwin.
7 回复数
3,230 次查看
EdwinHz
Hi @rajtend,
Please make sure you follow the steps listed on the following blog post: Placing Code in Sections with managed GNU Linker Scripts | MCU on Eclipse
BR,
Edwin.
3,191 次查看
rajtend
I have followed the steps, however the hard fault doesn't go away.
3,170 次查看
EdwinHz
Hi @rajtend,
How are you accessing the arrays? Are I tried to recreate the issue, but I am not able to; it works OK for me. I have the following arrays as global variables:
And under main, I set a value of 8 to all of them at their last position:
    arrA[100] = 8;
    arrA1[100] = 8;
    arrB[100] = 8;
    arrB1[100] = 8;
    arrC[200] = 8;
    arrC1[200] = 8;
    arrD[100] = 8;
    arrD1[100] = 8;
This results in no compilation error or hard fault either.
Take a look into the following community post: Solved: Re: Imprecise Bus Error when trying to make use of SDRAM on RT1020 EVK - NXP Community
As well as the following application note (specifically section "4.3.2. Use non-cacheable buffers"): Using the i.MXRT L1 Cache
BR,
Edwin.
3,160 次查看
rajtend
Can you please tell me?
1. What is the starting address for SDRAM for imx RT1050 evkb? where can i find it?
2. What does the following code means? I saw it asserted in one time while running.
/* The MPU region size should be 2^N, 5<=N<=32, region base should be multiples of size. */
assert(!(nonCacheStart % size));
assert(size == (uint32_t)(1 << i));
3,097 次查看
EdwinHz
Hi @rajtend,
The available size for the RT1050 can be found on its Reference Manual, specifically on "Table 3-1. System memory map (CM7)":
The code you mention makes sure of two things: The first like asserts that the region base (nonCacheStart) is a multiple of size. The second makes sure that size is no larger than 2^32, since the variable 'i' will have the base-2 order of size due to the previous "while()":
    while ((size >> i) > 0x1U)
        i++;
If the code asserts and breaks at that point, it means that the MPU region size does not comply with the condition where it is a multiple of size, or that it is bigger than 2^32.
BR,
Edwin.
3,084 次查看
rajtend
Thanks a lot for the steps.
I am able to make it work. I have added several preprocessor defines:
Can you tell me which are not needed?
3,081 次查看
EdwinHz
Hi @rajtend,
BR,
Edwin.
%3CLINGO-SUB%20id%3D%22lingo-sub-1990428%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9C%A8%20imxRT1050%20EVKB%20%E4%B8%8A%E4%BD%BF%E7%94%A8%20SDRAM%20%E5%AD%98%E5%82%A8%E5%A4%A7%E6%95%B0%E6%8D%AE%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1990428%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%3CP%3E%E6%88%91%E6%AD%A3%E5%9C%A8%E4%BD%BF%E7%94%A8%20iMXRT1050%20EVKB%E3%80%82%3CBR%20%2F%3E%E6%88%91%E6%9C%89%E4%B8%80%E4%B8%AA%E5%8C%85%E5%90%AB%E5%A4%A7%E9%87%8F%E6%95%B0%E6%8D%AE%E9%98%B5%E5%88%97%E7%9A%84%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E3%80%82%3CBR%20%2F%3E%E7%94%B1%E4%BA%8E%E5%B0%BA%E5%AF%B8%E5%A4%AA%E5%B0%8F%EF%BC%8C%E6%88%91%E6%97%A0%E6%B3%95%E5%9C%A8%E5%A0%86%E6%88%96%E5%A0%86%E6%A0%88%E4%B8%8A%E5%88%86%E9%85%8D%E5%AE%83%E4%BB%AC%E3%80%82%3C%2FP%3E%3CP%3E%E5%BD%93%E6%88%91%E5%B0%9D%E8%AF%95%E5%9C%A8%20NCACHE%20%E5%8C%BA%E5%9F%9F%E5%88%86%E9%85%8D%E6%95%B0%E7%BB%84%E6%97%B6%EF%BC%8C%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E5%B0%B1%E4%BC%9A%E7%BC%96%E8%AF%91%E3%80%82%3CBR%20%2F%3E%E7%84%B6%E8%80%8C%EF%BC%8C%E6%88%91%E5%9C%A8%E8%AE%BF%E9%97%AE%E8%AF%A5%E5%9C%B0%E5%8C%BA%E6%97%B6%E9%81%87%E5%88%B0%E4%BA%86%E5%9B%B0%E9%9A%BE%E6%95%85%E9%9A%9C%E3%80%82%3CBR%20%2F%3E%E5%A6%82%E4%BD%95%E8%A7%A3%E5%86%B3%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%EF%BC%9F%3C%2FP%3E%3CDIV%3E%3CDIV%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3EAT_NONCACHEABLE_SECTION_ALIGN(%3C%2FSPAN%3E%3CSPAN%3Edouble%3C%2FSPAN%3E%3CSPAN%3E%20arrA%5B100%5D%2C%208)%3B%3CBR%20%2F%3E%3C%2FSPAN%3E%3CSPAN%3EAT_NONCACHEABLE_SECTION_ALIGN(%3C%2FSPAN%3E%3CSPAN%3Euint32_t%3C%2FSPAN%3E%3CSPAN%3E%20arrA1%5B100%5D%2C%208)%3B%3CBR%20%2F%3E%3C%2FSPAN%3E%3CSPAN%3EAT_NONCACHEABLE_SECTION_ALIGN(%3C%2FSPAN%3E%3CSPAN%3Edouble%3C%2FSPAN%3E%3CSPAN%3E%20arrB%5B100%5D%2C%208)%3B%3CBR%20%2F%3E%3C%2FSPAN%3E%3CSPAN%3EAT_NONCACHEABLE_SECTION_ALIGN(%3C%2FSPAN%3E%3CSPAN%3Euint32_t%3C%2FSPAN%3E%3CSPAN%3E%20arrB1%5B100%5D%2C%208)%3B%3CBR%20%2F%3E%3C%2FSPAN%3E%3CSPAN%3EAT_NONCACHEABLE_SECTION_ALIGN(%3C%2FSPAN%3E%3CSPAN%3Edouble%3C%2FSPAN%3E%3CSPAN%3E%20arrC%5B200%5D%2C%208)%3B%3CBR%20%2F%3E%3C%2FSPAN%3E%3CSPAN%3EAT_NONCACHEABLE_SECTION_ALIGN(%3C%2FSPAN%3E%3CSPAN%3Euint32_t%3C%2FSPAN%3E%3CSPAN%3E%20arrC1%5B200%5D%2C%208)%3B%3CBR%20%2F%3E%3C%2FSPAN%3E%3CSPAN%3EAT_NONCACHEABLE_SECTION_ALIGN(%3C%2FSPAN%3E%3CSPAN%3Edouble%3C%2FSPAN%3E%20%3CSPAN%3EarrD%3C%2FSPAN%3E%3CSPAN%3E%5B100%5D%2C%208)%3B%3CBR%20%2F%3E%3C%2FSPAN%3E%3CSPAN%3EAT_NONCACHEABLE_SECTION_ALIGN(%3C%2FSPAN%3E%3CSPAN%3Euint32_t%3C%2FSPAN%3E%3CSPAN%3E%20arrD1%5B100%5D%2C%208)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E9%93%BE%E6%8E%A5%E5%99%A8%E9%85%8D%E7%BD%AE%EF%BC%9A%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22rajtend_1-1731002407700.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22rajtend_1-1731002407700.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F309275i04AB5AA5190FEAB5%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22rajtend_1-1731002407700.png%22%20alt%3D%22rajtend_1-1731002407700.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CP%3E%E7%A1%AC%E6%95%85%E9%9A%9C%EF%BC%9A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22rajtend_0-1731002160163.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22rajtend_0-1731002160163.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F309274i476012B023EF2197%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22rajtend_0-1731002160163.png%22%20alt%3D%22rajtend_0-1731002160163.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1992208%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%9C%A8%20imxRT1050%20EVKB%20%E4%B8%8A%E4%BD%BF%E7%94%A8%20SDRAM%20%E5%AD%98%E5%82%A8%E5%A4%A7%E6%95%B0%E6%8D%AE%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1992208%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F242788%22%20target%3D%22_blank%22%3E%40rajtend%3C%2FA%3E%2C%3C%2FP%3E%0A%3CP%3E%E6%81%90%E6%80%95%E6%88%91%E6%97%A0%E6%B3%95%E5%91%8A%E8%AF%89%E6%82%A8%E5%93%AA%E4%BA%9B%E9%A2%84%E5%A4%84%E7%90%86%E5%99%A8%E5%AE%9A%E4%B9%89%E6%98%AF%E4%B8%8D%E9%9C%80%E8%A6%81%E7%9A%84%EF%BC%8C%E5%9B%A0%E4%B8%BA%E8%BF%99%E5%8F%96%E5%86%B3%E4%BA%8E%E6%82%A8%E7%9A%84%E5%85%B7%E4%BD%93%E5%BA%94%E7%94%A8%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%88%91%E5%BB%BA%E8%AE%AE%E6%82%A8%E5%B0%86%E6%82%A8%E7%9A%84%E9%A1%B9%E7%9B%AE%E4%B8%8E%E6%88%91%E4%BB%AC%E7%9A%84%20SDK%20%E7%A4%BA%E4%BE%8B%E4%B8%AD%E7%9A%84%E9%A1%B9%E7%9B%AE%E8%BF%9B%E8%A1%8C%E6%AF%94%E8%BE%83%EF%BC%8C%E7%84%B6%E5%90%8E%E4%BB%8E%E9%82%A3%E9%87%8C%E5%BC%80%E5%A7%8B%E3%80%82%3C%2FP%3E%0A%3CP%3EBR%2C%3CBR%20%2F%3EEdwin.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1992174%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%9C%A8%20imxRT1050%20EVKB%20%E4%B8%8A%E4%BD%BF%E7%94%A8%20SDRAM%20%E5%AD%98%E5%82%A8%E5%A4%A7%E6%95%B0%E6%8D%AE%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1992174%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%3CBR%20%2F%3E%3CBR%20%2F%3E%E9%9D%9E%E5%B8%B8%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E6%AD%A5%E9%AA%A4%E3%80%82%3CBR%20%2F%3E%E6%88%91%E8%83%BD%E8%AE%A9%E5%AE%83%E5%B7%A5%E4%BD%9C%E3%80%82%E6%88%91%E6%B7%BB%E5%8A%A0%E4%BA%86%E5%87%A0%E4%B8%AA%E9%A2%84%E5%A4%84%E7%90%86%E5%99%A8%E5%AE%9A%E4%B9%89%EF%BC%9A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22rajtend_0-1731348658298.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22rajtend_0-1731348658298.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F309828iBFD941E151C486A7%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22rajtend_0-1731348658298.png%22%20alt%3D%22rajtend_0-1731348658298.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%E4%BD%A0%E8%83%BD%E5%91%8A%E8%AF%89%E6%88%91%E5%93%AA%E4%BA%9B%E6%98%AF%E4%B8%8D%E9%9C%80%E8%A6%81%E7%9A%84%E5%90%97%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1992119%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%9C%A8%20imxRT1050%20EVKB%20%E4%B8%8A%E4%BD%BF%E7%94%A8%20SDRAM%20%E5%AD%98%E5%82%A8%E5%A4%A7%E6%95%B0%E6%8D%AE%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1992119%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F242788%22%20target%3D%22_blank%22%3E%40rajtend%3C%2FA%3E%2C%3C%2FP%3E%0A%3CP%3ERT1050%20%E7%9A%84%E5%8F%AF%E7%94%A8%E5%B0%BA%E5%AF%B8%E5%8F%AF%E4%BB%A5%E5%9C%A8%E5%85%B6%E5%8F%82%E8%80%83%E6%89%8B%E5%86%8C%E4%B8%AD%E6%89%BE%E5%88%B0%EF%BC%8C%E5%85%B7%E4%BD%93%E4%B8%BA%E2%80%9C%E8%A1%A8%203-1%E2%80%9D%E3%80%82%E7%B3%BB%E7%BB%9F%E5%86%85%E5%AD%98%E6%98%A0%E5%B0%84%EF%BC%88CM7%EF%BC%89%E2%80%9D%EF%BC%9A%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22EdwinHz_0-1731342554755.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22EdwinHz_0-1731342554755.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F309816iCC418B59D85DE79E%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22EdwinHz_0-1731342554755.png%22%20alt%3D%22EdwinHz_0-1731342554755.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E6%82%A8%E6%8F%90%E5%88%B0%E7%9A%84%E4%BB%A3%E7%A0%81%E7%A1%AE%E4%BF%9D%E4%BA%86%E4%B8%A4%E4%BB%B6%E4%BA%8B%EF%BC%9A%E7%AC%AC%E4%B8%80%E4%BB%B6%E4%BA%8B%E6%98%AF%E6%96%AD%E8%A8%80%E5%8C%BA%E5%9F%9F%E5%9F%BA%E7%A1%80%EF%BC%88nonCacheStart%EF%BC%89%E6%98%AF%E5%A4%A7%E5%B0%8F%E7%9A%84%E5%80%8D%E6%95%B0%E3%80%82%E7%AC%AC%E4%BA%8C%E4%B8%AA%E7%A1%AE%E4%BF%9D%E5%A4%A7%E5%B0%8F%E4%B8%8D%E5%A4%A7%E4%BA%8E%202%5E32%EF%BC%8C%E5%9B%A0%E4%B8%BA%E7%94%B1%E4%BA%8E%E5%89%8D%E9%9D%A2%E7%9A%84%E2%80%9Cwhile()%E2%80%9D%EF%BC%8C%E5%8F%98%E9%87%8F%E2%80%9Ci%E2%80%9D%E5%B0%86%E5%85%B7%E6%9C%89%E4%BB%A5%202%20%E4%B8%BA%E5%BA%95%E7%9A%84%E5%A4%A7%E5%B0%8F%E9%A1%BA%E5%BA%8F%EF%BC%9A%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CPRE%20class%3D%22lia-code-sample%20language-c%22%3E%3CCODE%20translate%3D%22no%22%3E%20%20%20%20while%20((size%20%26gt%3B%26gt%3B%20i)%20%26gt%3B%200x1U)%0A%20%20%20%20%7B%0A%20%20%20%20%20%20%20%20i%2B%2B%3B%0A%20%20%20%20%7D%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E5%A6%82%E6%9E%9C%E4%BB%A3%E7%A0%81%E5%9C%A8%E8%AF%A5%E7%82%B9%E6%96%AD%E8%A8%80%E5%B9%B6%E4%B8%AD%E6%96%AD%EF%BC%8C%E5%88%99%E6%84%8F%E5%91%B3%E7%9D%80%20MPU%20%E5%8C%BA%E5%9F%9F%E5%A4%A7%E5%B0%8F%E4%B8%8D%E7%AC%A6%E5%90%88%E5%A4%A7%E5%B0%8F%E5%80%8D%E6%95%B0%E7%9A%84%E6%9D%A1%E4%BB%B6%EF%BC%8C%E6%88%96%E8%80%85%E5%A4%A7%E4%BA%8E%202%5E32%E3%80%82%3C%2FP%3E%0A%3CP%3EBR%2C%3CBR%20%2F%3EEdwin.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1991323%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%9C%A8%20imxRT1050%20EVKB%20%E4%B8%8A%E4%BD%BF%E7%94%A8%20SDRAM%20%E5%AD%98%E5%82%A8%E5%A4%A7%E6%95%B0%E6%8D%AE%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1991323%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E4%BD%A0%E8%83%BD%E5%91%8A%E8%AF%89%E6%88%91%E5%90%97%EF%BC%9F%3CBR%20%2F%3E%201.imx%20RT1050%20evkb%20%E7%9A%84%20SDRAM%20%E8%B5%B7%E5%A7%8B%E5%9C%B0%E5%9D%80%E6%98%AF%E5%A4%9A%E5%B0%91%EF%BC%9F%E6%88%91%E5%9C%A8%E5%93%AA%E9%87%8C%E5%8F%AF%E4%BB%A5%E6%89%BE%E5%88%B0%E5%AE%83%EF%BC%9F%3CBR%20%2F%3E2.%20%E4%BB%A5%E4%B8%8B%E4%BB%A3%E7%A0%81%E6%98%AF%E4%BB%80%E4%B9%88%E6%84%8F%E6%80%9D%EF%BC%9F%E6%88%91%E5%9C%A8%E8%BF%90%E8%A1%8C%E6%97%B6%E6%9B%BE%E7%9C%8B%E5%88%B0%E8%BF%87%E5%AE%83%E7%9A%84%E6%96%AD%E8%A8%80%E3%80%82%3CBR%20%2F%3E%2F*%20MPU%20%E5%8C%BA%E5%9F%9F%E5%A4%A7%E5%B0%8F%E5%BA%94%E4%B8%BA%202%5EN%EF%BC%8C5%26lt%3B%3DN%26lt%3B%3D32%EF%BC%8C%E5%8C%BA%E5%9F%9F%E5%9F%BA%E6%95%B0%E5%BA%94%E4%B8%BA%E5%A4%A7%E5%B0%8F%E7%9A%84%E5%80%8D%E6%95%B0%E3%80%82*%2F%3CBR%20%2F%3E%E6%96%AD%E8%A8%80%EF%BC%88%EF%BC%81%EF%BC%88nonCacheStart%EF%BC%85%E5%A4%A7%E5%B0%8F%EF%BC%89%EF%BC%89%EF%BC%9B%3CBR%20%2F%3E%E6%96%AD%E8%A8%80%EF%BC%88size%20%3D%3D%20(uint32_t)(1%20%26lt%3B%26lt%3B%20i))%3B%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1991292%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%9C%A8%20imxRT1050%20EVKB%20%E4%B8%8A%E4%BD%BF%E7%94%A8%20SDRAM%20%E5%AD%98%E5%82%A8%E5%A4%A7%E6%95%B0%E6%8D%AE%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1991292%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F242788%22%20target%3D%22_blank%22%3E%40rajtend%3C%2FA%3E%2C%3C%2FP%3E%0A%3CP%3E%E6%82%A8%E5%A6%82%E4%BD%95%E8%AE%BF%E9%97%AE%E6%95%B0%E7%BB%84%EF%BC%9F%E6%88%91%E6%98%AF%E5%90%A6%E5%B0%9D%E8%AF%95%E9%87%8D%E6%96%B0%E5%88%9B%E5%BB%BA%E8%AF%A5%E9%97%AE%E9%A2%98%EF%BC%8C%E4%BD%86%E6%88%91%E6%97%A0%E6%B3%95%E5%81%9A%E5%88%B0%EF%BC%9B%E5%AE%83%E5%AF%B9%E6%88%91%E6%9D%A5%E8%AF%B4%E6%B2%A1%E9%97%AE%E9%A2%98%E3%80%82%E6%88%91%E6%9C%89%E4%BB%A5%E4%B8%8B%E6%95%B0%E7%BB%84%E4%BD%9C%E4%B8%BA%E5%85%A8%E5%B1%80%E5%8F%98%E9%87%8F%EF%BC%9A%3C%2FP%3E%0A%3CPRE%20class%3D%22lia-code-sample%20language-c%22%3E%3CCODE%20translate%3D%22no%22%3EAT_NONCACHEABLE_SECTION_ALIGN(double%20arrA%5B100%5D%2C%208)%3B%0AAT_NONCACHEABLE_SECTION_ALIGN(uint32_t%20arrA1%5B100%5D%2C%208)%3B%0AAT_NONCACHEABLE_SECTION_ALIGN(double%20arrB%5B100%5D%2C%208)%3B%0AAT_NONCACHEABLE_SECTION_ALIGN(uint32_t%20arrB1%5B100%5D%2C%208)%3B%0AAT_NONCACHEABLE_SECTION_ALIGN(double%20arrC%5B200%5D%2C%208)%3B%0AAT_NONCACHEABLE_SECTION_ALIGN(uint32_t%20arrC1%5B200%5D%2C%208)%3B%0AAT_NONCACHEABLE_SECTION_ALIGN(double%20arrD%5B100%5D%2C%208)%3B%0AAT_NONCACHEABLE_SECTION_ALIGN(uint32_t%20arrD1%5B100%5D%2C%208)%3B%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CP%3E%E5%9C%A8%E4%B8%BB%E7%A8%8B%E5%BA%8F%E4%B8%8B%EF%BC%8C%E6%88%91%E5%B0%86%E5%AE%83%E4%BB%AC%E7%9A%84%E6%9C%80%E5%90%8E%E4%B8%80%E4%B8%AA%E4%BD%8D%E7%BD%AE%E7%9A%84%E5%80%BC%E5%85%A8%E9%83%A8%E8%AE%BE%E7%BD%AE%E4%B8%BA%208%EF%BC%9A%3C%2FP%3E%0A%3CPRE%20class%3D%22lia-code-sample%20language-c%22%3E%3CCODE%20translate%3D%22no%22%3E%20%20%20%20arrA%5B100%5D%20%3D%208%3B%0A%20%20%20%20arrA1%5B100%5D%20%3D%208%3B%0A%20%20%20%20arrB%5B100%5D%20%3D%208%3B%0A%20%20%20%20arrB1%5B100%5D%20%3D%208%3B%0A%20%20%20%20arrC%5B200%5D%20%3D%208%3B%0A%20%20%20%20arrC1%5B200%5D%20%3D%208%3B%0A%20%20%20%20arrD%5B100%5D%20%3D%208%3B%0A%20%20%20%20arrD1%5B100%5D%20%3D%208%3B%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CP%3E%E8%BF%99%E4%B9%9F%E4%B8%8D%E4%BC%9A%E5%AF%BC%E8%87%B4%E7%BC%96%E8%AF%91%E9%94%99%E8%AF%AF%E6%88%96%E7%A1%AC%E6%95%85%E9%9A%9C%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E8%AF%B7%E6%9F%A5%E7%9C%8B%E4%BB%A5%E4%B8%8B%E7%A4%BE%E5%8C%BA%E5%B8%96%E5%AD%90%EF%BC%9A%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-RT-Crossover-MCUs%2FImprecise-Bus-Error-when-trying-to-make-use-of-SDRAM-on-RT1020%2Fm-p%2F1561226%22%20target%3D%22_blank%22%3E%E5%B7%B2%E8%A7%A3%E5%86%B3%EF%BC%9A%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%B0%9D%E8%AF%95%E5%9C%A8%20RT1020%20EVK%20%E4%B8%8A%E4%BD%BF%E7%94%A8%20SDRAM%20%E6%97%B6%E5%87%BA%E7%8E%B0%E4%B8%8D%E7%B2%BE%E7%A1%AE%E7%9A%84%E6%80%BB%E7%BA%BF%E9%94%99%E8%AF%AF%20-%20NXP%20%E7%A4%BE%E5%8C%BA%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E4%BB%A5%E5%8F%8A%E4%BB%A5%E4%B8%8B%E5%BA%94%E7%94%A8%E8%AF%B4%E6%98%8E%EF%BC%88%E7%89%B9%E5%88%AB%E6%98%AF%E2%80%9C4.3.2%E2%80%9D%E9%83%A8%E5%88%86%EF%BC%89%E3%80%82%E4%BD%BF%E7%94%A8%E4%B8%8D%E5%8F%AF%E7%BC%93%E5%AD%98%E7%9A%84%E7%BC%93%E5%86%B2%E5%8C%BA%E2%80%9D%EF%BC%89%EF%BC%9A%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN12042.pdf%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%E4%BD%BF%E7%94%A8%20i.MXRT%20L1%20%E7%BC%93%E5%AD%98%3C%2FA%3E%3C%2FP%3E%0A%3CP%3EBR%2C%3CBR%20%2F%3EEdwin.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1991142%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%9C%A8%20imxRT1050%20EVKB%20%E4%B8%8A%E4%BD%BF%E7%94%A8%20SDRAM%20%E5%AD%98%E5%82%A8%E5%A4%A7%E6%95%B0%E6%8D%AE%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1991142%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%88%91%E5%B7%B2%E6%8C%89%E7%85%A7%E6%AD%A5%E9%AA%A4%E6%93%8D%E4%BD%9C%EF%BC%8C%E4%BD%86%E7%A1%AC%E6%95%85%E9%9A%9C%E4%BB%8D%E6%9C%AA%E6%B6%88%E5%A4%B1%E3%80%82%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1990481%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%9C%A8%20imxRT1050%20EVKB%20%E4%B8%8A%E4%BD%BF%E7%94%A8%20SDRAM%20%E5%AD%98%E5%82%A8%E5%A4%A7%E6%95%B0%E6%8D%AE%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1990481%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F242788%22%20target%3D%22_blank%22%3E%40rajtend%3C%2FA%3E%2C%3C%2FP%3E%0A%3CP%3E%E8%AF%B7%E7%A1%AE%E4%BF%9D%E9%81%B5%E5%BE%AA%E4%BB%A5%E4%B8%8B%E5%8D%9A%E5%AE%A2%E6%96%87%E7%AB%A0%E4%B8%AD%E5%88%97%E5%87%BA%E7%9A%84%E6%AD%A5%E9%AA%A4%EF%BC%9A%3CA%20href%3D%22https%3A%2F%2Fmcuoneclipse.com%2F2021%2F05%2F26%2Fplacing-code-in-sections-with-managed-gnu-linker-scripts%2F%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%E4%BD%BF%E7%94%A8%E6%89%98%E7%AE%A1%20GNU%20%E9%93%BE%E6%8E%A5%E5%99%A8%E8%84%9A%E6%9C%AC%E5%B0%86%E4%BB%A3%E7%A0%81%E6%94%BE%E7%BD%AE%E5%9C%A8%E9%83%A8%E5%88%86%E4%B8%AD%20%7C%20Eclipse%20%E4%B8%8A%E7%9A%84%20MCU%3C%2FA%3E%3C%2FP%3E%0A%3CP%3EBR%2C%3CBR%20%2F%3EEdwin.%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E
