USB Audio Descriptor - multiple devices, one usb connection
4,352 次查看
mrecoskie
I am attempting to manually create a USB descriptor for two devices behind a single USB Audio Class 2.0 connection.  Does anyone know whether or not the Terminals, Clock and Unit should all be unique IDs when utilizing multiple Interface Association Descriptors (IAD)?  I would assume so.  Does anyone have a working example of this type of descriptor?
Below is my attempt however the linux host has complaints.  Is there someone with experience in this area to review the descriptor below?  Thank you.
Mark
Bus 001 Device 029: ID 1fc9:00a4 NXP Semiconductors
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceClass          239 Miscellaneous Device
  bDeviceSubClass         2
  bDeviceProtocol         1 Interface Association
  bMaxPacketSize0        64
  idVendor           0x1fc9 NXP Semiconductors
  idProduct          0x00a4
  bcdDevice            1.01
  iManufacturer           1
  iProduct                2
  iSerial                 0
  bNumConfigurations      1
  Configuration Descriptor:
    bLength                 9
    bDescriptorType         2
    wTotalLength       0x01f3
    bNumInterfaces          6
    bConfigurationValue     1
    iConfiguration          0
    bmAttributes         0xc0
      Self Powered
    MaxPower              500mA
    Interface Association:
      bLength                 8
      bDescriptorType        11
      bFirstInterface         0
      bInterfaceCount         3
      bFunctionClass          1 Audio
      bFunctionSubClass       0
      bFunctionProtocol      32
      iFunction               0
    Interface Descriptor:
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           0
      bInterfaceClass         1 Audio
      bInterfaceSubClass      1 Control Device
      bInterfaceProtocol     32
      iInterface              0
      AudioControl Interface Descriptor:
        bLength                 9
        bDescriptorType        36
        bDescriptorSubtype      1 (HEADER)
        bcdADC               2.00
        bCategory               4
        wTotalLength       0x006f
        bmControls           0x00
        bLength                 8
        bDescriptorType        36
        bDescriptorSubtype     10 (CLOCK_SOURCE)
        bClockID               16
        bmAttributes            3 Internal programmable clock
        bmControls           0x07
          Clock Frequency Control (read/write)
          Clock Validity Control (read-only)
        bAssocTerminal          0
        iClockSource            0
        bLength                17
        bDescriptorType        36
        bDescriptorSubtype      2 (INPUT_TERMINAL)
        bTerminalID             1
        wTerminalType      0x0201 Microphone
        bAssocTerminal          0
        bCSourceID             16
        bNrChannels             2
        bmChannelConfig    0x00000003
          Front Left (FL)
          Front Right (FR)
        iChannelNames           0
        bmControls         0x0000
        iTerminal               0
        bLength                18
        bDescriptorType        36
        bDescriptorSubtype      6 (FEATURE_UNIT)
        bUnitID                 2
        bSourceID               1
        bmaControls(0)     0x00000000
        bmaControls(1)     0x00000000
        bmaControls(2)     0x00000000
        iFeature                0
        bLength                12
        bDescriptorType        36
        bDescriptorSubtype      3 (OUTPUT_TERMINAL)
        bTerminalID             3
        wTerminalType      0x0101 USB Streaming
        bAssocTerminal          0
        bSourceID               2
        bCSourceID             16
        bmControls         0x0000
        iTerminal               0
        bLength                17
        bDescriptorType        36
        bTerminalID             4
        bAssocTerminal          0
        bCSourceID             16
        bNrChannels             2
          Front Left (FL)
          Front Right (FR)
        iChannelNames           0
        bmControls         0x0000
        iTerminal               0
        bLength                18
        bDescriptorType        36
        bUnitID                 5
        bSourceID               4
        bmaControls(0)     0x0000000f
          Mute Control (read/write)
          Volume Control (read/write)
        iFeature                0
        bLength                12
        bDescriptorType        36
        bTerminalID             6
        wTerminalType      0x0301 Speaker
        bAssocTerminal          0
        bSourceID               5
        bCSourceID             16
        bmControls         0x0000
        iTerminal               0
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        1
      bAlternateSetting       0
      bNumEndpoints           0
      bInterfaceSubClass      2 Streaming
      iInterface              0
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        1
      bAlternateSetting       1
      bNumEndpoints           1
      iInterface              0
      AudioStreaming Interface Descriptor:
        bLength                16
        bDescriptorType        36
        bDescriptorSubtype      1 (AS_GENERAL)
        bTerminalLink           3
        bmControls           0x00
        bFormatType             1
        bmFormats          0x00000001
          PCM
        bNrChannels             2
          Front Left (FL)
          Front Right (FR)
        iChannelNames           0
        bLength                 6
        bDescriptorType        36
        bDescriptorSubtype      2 (FORMAT_TYPE)
        bFormatType             1 (FORMAT_TYPE_I)
        bSubslotSize            2
        bBitResolution         16
      Endpoint Descriptor:
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x83  EP 3 IN
        bmAttributes           13
          Transfer Type            Isochronous
          Synch Type               Synchronous
          Usage Type               Data
        wMaxPacketSize     0x00c4  1x 196 bytes
        bInterval               4
        AudioStreaming Endpoint Descriptor:
          bLength                 8
          bDescriptorType        37
          bDescriptorSubtype      1 (EP_GENERAL)
          bmAttributes         0x00
          bmControls           0x00
          bLockDelayUnits         0 Undefined
          wLockDelay         0x0000
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        2
      bAlternateSetting       0
      bNumEndpoints           0
      iInterface              0
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        2
      bAlternateSetting       1
      bNumEndpoints           2
      iInterface              0
        bLength                16
        bDescriptorType        36
        bTerminalLink           4
        bmControls           0x00
        bFormatType             1
          PCM
        bNrChannels             2
          Front Left (FL)
          Front Right (FR)
        iChannelNames           0
        bLength                 6
        bDescriptorType        36
        bSubslotSize            2
        bBitResolution         16
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x02  EP 2 OUT
        bmAttributes            5
          Synch Type               Asynchronous
          Usage Type               Data
        wMaxPacketSize     0x001c  1x 28 bytes
        bInterval               1
          bLength                 8
          bDescriptorType        37
          bmAttributes         0x00
          bmControls           0x00
          wLockDelay         0x0000
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x82  EP 2 IN
        bmAttributes           17
          Synch Type               None
          Usage Type               Feedback
        wMaxPacketSize     0x0004  1x 4 bytes
        bInterval               4
      bLength                 8
      bDescriptorType        11
      bFirstInterface         3
      bInterfaceCount         3
      bFunctionSubClass       0
      iFunction               0
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        3
      bAlternateSetting       0
      bNumEndpoints           0
      iInterface              0
        bLength                 9
        bDescriptorType        36
        bcdADC               2.00
        bCategory               4
        wTotalLength       0x006f
        bmControls           0x00
        bLength                 8
        bDescriptorType        36
        bClockID               17
        bmControls           0x07
        bAssocTerminal          0
        iClockSource            0
        bLength                17
        bDescriptorType        36
        bTerminalID             7
        bAssocTerminal          0
        bCSourceID             17
        bNrChannels             2
          Front Left (FL)
          Front Right (FR)
        iChannelNames           0
        bmControls         0x0000
        iTerminal               0
        bLength                18
        bDescriptorType        36
        bUnitID                 8
        bSourceID               7
        iFeature                0
        bLength                12
        bDescriptorType        36
        bTerminalID             9
        bAssocTerminal          0
        bSourceID               8
        bCSourceID             17
        bmControls         0x0000
        iTerminal               0
        bLength                17
        bDescriptorType        36
        bTerminalID            10
        bAssocTerminal          0
        bCSourceID             17
        bNrChannels             2
          Front Left (FL)
          Front Right (FR)
        iChannelNames           0
        bmControls         0x0000
        iTerminal               0
        bLength                18
        bDescriptorType        36
        bUnitID                11
        bSourceID              10
        iFeature                0
        bLength                12
        bDescriptorType        36
        bTerminalID            12
        bAssocTerminal          0
        bSourceID              11
        bCSourceID             17
        bmControls         0x0000
        iTerminal               0
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        4
      bAlternateSetting       0
      bNumEndpoints           0
      iInterface              0
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        4
      bAlternateSetting       1
      bNumEndpoints           1
      iInterface              0
        bLength                16
        bDescriptorType        36
        bTerminalLink           9
        bmControls           0x00
        bFormatType             1
          PCM
        bNrChannels             2
          Front Left (FL)
          Front Right (FR)
        iChannelNames           0
        bLength                 6
        bDescriptorType        36
        bSubslotSize            2
        bBitResolution         16
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x85  EP 5 IN
        bmAttributes           13
          Usage Type               Data
        wMaxPacketSize     0x00c0  1x 192 bytes
        bInterval               1
          bLength                 8
          bDescriptorType        37
          bmAttributes         0x00
          bmControls           0x00
          wLockDelay         0x0000
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        5
      bAlternateSetting       0
      bNumEndpoints           0
      iInterface              0
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        5
      bAlternateSetting       1
      bNumEndpoints           2
      iInterface              0
        bLength                16
        bDescriptorType        36
        bTerminalLink          10
        bmControls           0x00
        bFormatType             1
          PCM
        bNrChannels             2
          Front Left (FL)
          Front Right (FR)
        iChannelNames           0
        bLength                 6
        bDescriptorType        36
        bSubslotSize            2
        bBitResolution         16
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x04  EP 4 OUT
        bmAttributes            5
          Usage Type               Data
        bInterval               1
          bLength                 8
          bDescriptorType        37
          bmAttributes         0x00
          bmControls           0x00
          wLockDelay         0x0000
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x84  EP 4 IN
        bmAttributes           17
          Synch Type               None
          Usage Type               Feedback
        wMaxPacketSize     0x0008  1x 8 bytes
        bInterval              16
5 回复数
4,325 次查看
mrecoskie
Below are some of the messages Linux is reporting.  I am digging through the kernel code to try to decode them.
[233102.781298] usb 1-7: New USB device found, idVendor=1fc9, idProduct=00a4, bcdDevice= 1.01
[233102.781299] usb 1-7: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[233108.354021] usb 1-7: parse_audio_format_rates_v2v3(): unable to retrieve number of sample rates (clock 16)
[233113.474359] usb 1-7: parse_audio_format_rates_v2v3(): unable to retrieve number of sample rates (clock 16)
[233118.593224] usb 1-7: cannot get ctl value: req = 0x83, wValue = 0x200, wIndex = 0x200, type = 4
[233118.593228] usb 1-7: 2:0: cannot get min/max values for control 2 (id 2)
[233123.714658] usb 1-7: cannot get ctl value: req = 0x83, wValue = 0x200, wIndex = 0x500, type = 4
[233123.714665] usb 1-7: 5:0: cannot get min/max values for control 2 (id 5)
[233123.715896] usb 1-7: 4:1 : bogus bTerminalLink 9
[233124.117917] usb 1-7: 5:1 : bogus bTerminalLink 10
[233129.344734] usb 1-7: cannot get ctl value: req = 0x83, wValue = 0x200, wIndex = 0x803, type = 4
[233129.344739] usb 1-7: 8:3: cannot get min/max values for control 2 (id 8)
[233134.464652] usb 1-7: cannot get ctl value: req = 0x83, wValue = 0x200, wIndex = 0xb03, type = 4
[233134.464657] usb 1-7: 11:3: cannot get min/max values for control 2 (id 11)
[233139.584766] usb 1-7: cannot get ctl value: req = 0x83, wValue = 0x200, wIndex = 0x500, type = 4
[233139.584770] usb 1-7: 5:0: cannot get min/max values for control 2 (id 5)
[233144.704744] usb 1-7: cannot get ctl value: req = 0x83, wValue = 0x200, wIndex = 0x500, type = 4
[233144.704749] usb 1-7: 5:0: cannot get min/max values for control 2 (id 5)
[233149.825169] usb 1-7: cannot get ctl value: req = 0x83, wValue = 0x200, wIndex = 0x500, type = 4
[233149.825173] usb 1-7: 5:0: cannot get min/max values for control 2 (id 5)
[233154.945395] usb 1-7: cannot get ctl value: req = 0x83, wValue = 0x200, wIndex = 0x500, type = 4
[233154.945400] usb 1-7: 5:0: cannot get min/max values for control 2 (id 5)
[233160.065816] usb 1-7: cannot get ctl value: req = 0x83, wValue = 0x200, wIndex = 0x500, type = 4
[233160.065821] usb 1-7: 5:0: cannot get min/max values for control 2 (id 5)
[233165.185114] usb 1-7: cannot get ctl value: req = 0x83, wValue = 0x200, wIndex = 0x500, type = 4
[233165.185119] usb 1-7: 5:0: cannot get min/max values for control 2 (id 5)
[233165.680270] usb 1-7: cannot get ctl value: req = 0x81, wValue = 0x200, wIndex = 0x500, type = 4
[233165.680667] usb 1-7: cannot get ctl value: req = 0x81, wValue = 0x200, wIndex = 0x500, type = 4
[233165.681407] usb 1-7: cannot get ctl value: req = 0x81, wValue = 0x200, wIndex = 0x500, type = 4
[233165.682086] usb 1-7: cannot get ctl value: req = 0x81, wValue = 0x100, wIndex = 0x500, type = 1
[233165.682427] usb 1-7: cannot get ctl value: req = 0x83, wValue = 0x200, wIndex = 0xb03, type = 4
[233165.682430] usb 1-7: 11:3: cannot get min/max values for control 2 (id 11)
4,331 次查看
mrecoskie
True.  However there are multiple Audio Control Interfaces in the definition above - one for each device.  Interface 0 and 3.  In theory the same IDs could be used because they are in different Audio Control interfaces?
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           0
      iInterface              0
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        3
      bAlternateSetting       0
      bNumEndpoints           0
      iInterface              0
4,317 次查看
jingpan
Hi @mrecoskie ,
Yes, I think so.
Jing
4,298 次查看
mrecoskie
Hi Jing.  Mirroring the indices from the first device to the second device did in fact work.
4,336 次查看
jingpan
Hi @mrecoskie ,
I'm not familiar with UAC. But I see in USB Audio Class 2.0 spec, it says
Jing
