To fetch the RAM and CPU usage of i. MX RT1064
382 次查看
Prabhuraj
Hi, I'm using i.MX RT1064, and I need to calculate RAM and CPU usage. Is there any SDK example available to fetch the details or suggest the recommended method, Could you please help me in this?
NOTE : we are using malloc not vPortMalloc .
358 次查看
mayliu1
Hi @Prabhuraj ,
Thank you so much for your interest in our products and for using our community.
I suggest you can use MCUXPresso IDE. I suggest you can refer to User Guide for more detail information.
The memory regions displayed here match up to the memory banks displayed in the memory configuration editor when the managed linker script mechanism is being used.
in Heap and Stack Usage window, It shows Heap and Stack usage information.
Wish it helps you.
Wish you a nice day!
Best Regards
MayLiu
