The Industrial Communication Explorer cannot enable EtherCAT
已解决
跳至解决方案
1,071 次查看
ethan_dang1
When I was using Industrial Communication Explorer, I failed to enable the EtherCAT function for the network card. JDK 21.0.8.9 and Npcap 1.84 have been installed and added to the system environment variables.
Please help me figure out what the problem is. Thanks!
1 解答
976 次查看
Pablo_Ramos
Hi @ethan_dang1,
I noticed that in the first image you shared, the folder containing ecatproxy.exe is named “ect.”
Could you please help me by renaming this folder to “ecat“ and testing it this way?
Pablo
在原帖中查看解决方案
4 回复数
1,010 次查看
Pablo_Ramos
Hi @ethan_dang1,
What device are you using?
Are you using an example project? If so, which one?
Could you share the steps you follow to set up EtherCAT in the Industrial Communication Explorer?
We also have the following training resource that shows the initial configuration of the ICE tool for EtherCAT.
Industrial Communication Explorer (ICE) EtherCAT Training: Windows, Linux Setup, i.MX RT1180 Flashin...
Pablo
998 次查看
ethan_dang1
Ethan:MIMXRT1180-EVK
Ethan:Yes,  It's EtherCAT Stack Library EtherCAT Industrial Ethernet Protocol Software | NXP Semiconductors
Ethan:
Following UG_10361  & UG10322_Rev.2.0
step1: download rt1180_cm33_cm33.elf to MIMXRT1180-EVK using MCUXpresso Secure Provisioning.
step2: Switch to QSPI FLASH mode, Connect ETH0 to the PC(WIN10), power on
step3: In the decompressed "Industrial-Communications-Explorer\ICE\port-ICE-202509180853-lwin32.win32.x86-64" directory, create the directory "ecat".
step4: Copy the ecatproxy.exe file located in the Industrial-Communications-ExplorerICE ecatproxy-rel-20252609v2|ecatproxy |win directory to the Industrial-CommunicationsExplorer\ICE\port-ICE-202509180853-win32.win32.x86_64\ecat directory.
step5: Open ICE, Select the network card, right-click, and click Enable EtherCAT,
Pop-up message: EtherCAT proxy could not be started
977 次查看
Pablo_Ramos
Hi @ethan_dang1,
Pablo
925 次查看
ethan_dang1
It's OK after changing "ect" to "ecat". Thank you very much!
%3CLINGO-SUB%20id%3D%22lingo-sub-2333689%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%B7%A5%E4%B8%9A%E9%80%9A%E4%BF%A1%E8%B5%84%E6%BA%90%E7%AE%A1%E7%90%86%E5%99%A8%E6%97%A0%E6%B3%95%E5%90%AF%E7%94%A8%20EtherCAT%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2333689%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%9C%A8%E4%BD%BF%E7%94%A8%E5%B7%A5%E4%B8%9A%E9%80%9A%E4%BF%A1%E8%B5%84%E6%BA%90%E7%AE%A1%E7%90%86%E5%99%A8%E6%97%B6%EF%BC%8C%E6%88%91%E6%9C%AA%E8%83%BD%E5%90%AF%E7%94%A8%E7%BD%91%E5%8D%A1%E7%9A%84%20EtherCAT%20%E5%8A%9F%E8%83%BD%E3%80%82JDK%2021.0.8.9%20%E5%92%8C%20Npcap%201.84%20%E5%B7%B2%E5%AE%89%E8%A3%85%E5%B9%B6%E6%B7%BB%E5%8A%A0%E5%88%B0%E7%B3%BB%E7%BB%9F%E7%8E%AF%E5%A2%83%E5%8F%98%E9%87%8F%E4%B8%AD%E3%80%82%3C%2FP%3E%3CP%3E%E8%AF%B7%E5%B8%AE%E6%88%91%E6%89%BE%E5%87%BA%E9%97%AE%E9%A2%98%E6%89%80%E5%9C%A8%E3%80%82%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3CDIV%20class%3D%22%22%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%20class%3D%22%22%3E%26nbsp%3B%3C%2FDIV%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2335393%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20The%20Industrial%20Communication%20Explorer%20cannot%20enable%20EtherCAT%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2335393%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%EF%BC%8C%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F214798%22%20target%3D%22_blank%22%3E%40ethan_dang1%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CP%3E%E4%BD%A0%E5%9C%A8%E7%94%A8%E4%BB%80%E4%B9%88%E8%AE%BE%E5%A4%87%EF%BC%9F%3C%2FP%3E%0A%3CP%3E%E6%82%A8%E4%BD%BF%E7%94%A8%E7%9A%84%E6%98%AF%E7%A4%BA%E4%BE%8B%E9%A1%B9%E7%9B%AE%E5%90%97%EF%BC%9F%E5%A6%82%E6%9E%9C%E6%9C%89%EF%BC%8C%E6%98%AF%E5%93%AA%E4%B8%80%E4%B8%AA%EF%BC%9F%3C%2FP%3E%0A%3CP%3E%E8%83%BD%E5%90%A6%E5%88%86%E4%BA%AB%E4%B8%80%E4%B8%8B%E5%9C%A8%20%E2%80%9C%E5%B7%A5%E4%B8%9A%E9%80%9A%E4%BF%A1%E8%B5%84%E6%BA%90%E7%AE%A1%E7%90%86%E5%99%A8%E2%80%9D%20%E4%B8%AD%E8%AE%BE%E7%BD%AE%20EtherCAT%20%E6%89%80%E9%81%B5%E5%BE%AA%E7%9A%84%E6%AD%A5%E9%AA%A4%EF%BC%9F%3C%2FP%3E%0A%3CP%3E%E6%88%91%E4%BB%AC%E8%BF%98%E6%8F%90%E4%BE%9B%E4%BA%86%E4%BB%A5%E4%B8%8B%E5%9F%B9%E8%AE%AD%E8%B5%84%E6%BA%90%EF%BC%8C%E7%94%A8%E4%BA%8E%E4%BB%8B%E7%BB%8D%20EtherCAT%20ICE%20%E5%B7%A5%E5%85%B7%E7%9A%84%E5%88%9D%E5%A7%8B%E9%85%8D%E7%BD%AE%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdesign%2Fdesign-center%2Ftraining%2FTIP-ICE-ETHERCAT-WINDOWS-LINUX-SETUP-IMXRT1180%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%E5%B7%A5%E4%B8%9A%E9%80%9A%E4%BF%A1%E6%B5%8F%E8%A7%88%E5%99%A8%20(ICE)%20EtherCAT%20%E5%9F%B9%E8%AE%AD%EF%BC%9AWindows%E3%80%81Linux%20%E8%AE%BE%E7%BD%AE%E3%80%81i.MX%20RT1180%20%E9%97%AA%E5%AD%98%E5%92%8C%E5%BE%AA%E7%8E%AF%E9%80%9A%E4%BF%A1%20%7C%20%E6%81%A9%E6%99%BA%E6%B5%A6%E5%8D%8A%E5%AF%BC%E4%BD%93%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E6%95%AC%E4%B8%8A%EF%BC%8C%3CBR%20%2F%3EPablo%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2335633%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20The%20Industrial%20Communication%20Explorer%20cannot%20enable%20EtherCAT%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2335633%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%9C%A8%E7%94%A8%E4%BB%80%E4%B9%88%E8%AE%BE%E5%A4%87%EF%BC%9F%3C%2FP%3E%3CP%3E%3CSPAN%3E%E4%BC%8A%E6%A1%91%EF%BC%9AMIMXRT1180-EVK%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E6%82%A8%E4%BD%BF%E7%94%A8%E7%9A%84%E6%98%AF%E7%A4%BA%E4%BE%8B%E9%A1%B9%E7%9B%AE%E5%90%97%EF%BC%9F%E5%A6%82%E6%9E%9C%E6%9C%89%EF%BC%8C%E6%98%AF%E5%93%AA%E4%B8%80%E4%B8%AA%EF%BC%9F%3C%2FP%3E%3CP%3EEthan%EF%BC%9A%E6%98%AF%E7%9A%84%EF%BC%8C%E8%BF%99%E6%98%AFEtherCAT%20%3CSPAN%3E%E5%A0%86%E6%A0%88%E5%BA%93%20EtherC%20%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdesign%2Fdesign-center%2Fsoftware%2Fdevelopment-software%2Fsoftware-for-industrial-networking%2Fethercat-industrial-ethernet-protocol-software%3AETHERCAT-INDUSTRIAL-COMMUNICATIONS-SOFTWARE%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EAT%E5%B7%A5%E4%B8%9A%E4%BB%A5%E5%A4%AA%E7%BD%91%E5%8D%8F%E8%AE%AE%E8%BD%AF%E4%BB%B6%3C%2FA%3E%3C%2FSPAN%3E%20%7C%E6%81%A9%E6%99%BA%E6%B5%A6%E5%8D%8A%E5%AF%BC%E4%BD%93%3C%2FP%3E%3CP%3E%E8%83%BD%E5%90%A6%E5%88%86%E4%BA%AB%E4%B8%80%E4%B8%8B%E5%9C%A8%20%E2%80%9C%E5%B7%A5%E4%B8%9A%E9%80%9A%E4%BF%A1%E8%B5%84%E6%BA%90%E7%AE%A1%E7%90%86%E5%99%A8%E2%80%9D%20%E4%B8%AD%E8%AE%BE%E7%BD%AE%20EtherCAT%20%E6%89%80%E9%81%B5%E5%BE%AA%E7%9A%84%E6%AD%A5%E9%AA%A4%EF%BC%9F%3C%2FP%3E%3CP%3E%E4%BC%8A%E6%A1%91%EF%BC%9A%3C%2FP%3E%3CP%3E%E9%81%B5%E5%BE%AA%20UG_10361%26amp%3B%20UG10322_Rev.2.0%3C%2FP%3E%3CP%3E%3CSPAN%3E%E7%AC%AC%201%20%E6%AD%A5%EF%BC%9A%E4%BD%BF%E7%94%A8%20mcuXpresso%20%E5%AE%89%E5%85%A8%E9%85%8D%E7%BD%AE%E5%B0%86%20rt1180_cm33_cm33.elf%20%E4%B8%8B%E8%BD%BD%E5%88%B0%20MIMXRT1180-EVK%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E6%AD%A5%E9%AA%A4%202%EF%BC%9A%E5%88%87%E6%8D%A2%E5%88%B0%20QSPI%20FLASH%20%E6%A8%A1%E5%BC%8F%EF%BC%8C%E5%B0%86%20ETH0%20%E8%BF%9E%E6%8E%A5%E5%88%B0%20PC%EF%BC%88WIN10%EF%BC%89%EF%BC%8C%E6%89%93%E5%BC%80%E7%94%B5%E6%BA%90%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E6%AD%A5%E9%AA%A43%EF%BC%9A%E5%9C%A8%E8%A7%A3%E5%8E%8B%E5%90%8E%E7%9A%84%22Industrial-Communications-Explorer%5CICE%2Fport-ICE-202509180853-lwin32.win32.x86-64%22%E7%9B%AE%E5%BD%95%EF%BC%8C%E5%88%9B%E5%BB%BA%22ecat%22%20%E7%9B%AE%E5%BD%95%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E6%AD%A5%E9%AA%A4%204%EF%BC%9A%E5%B0%86%E4%BD%8D%E4%BA%8E%20Industrial-Communications-ExplorerICE%20ecatproxy-rel-20252609v2%7Cecatproxy%20%7Cwin%20%E7%9B%AE%E5%BD%95%E4%B8%AD%E7%9A%84%20ecatproxy.exe%20%E6%96%87%E4%BB%B6%E5%A4%8D%E5%88%B6%E5%88%B0%20Industrial-CommunicationsExplorer%5CICE%5Cport-ICE-202509180853-win32.win32.x86_64%5Cecat%20%E7%9B%AE%E5%BD%95%E4%B8%AD%E3%80%82%E7%9B%AE%E5%BD%95%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E6%AD%A5%E9%AA%A4%205%EF%BC%9A%E6%89%93%E5%BC%80%20ICE%EF%BC%8C%E9%80%89%E6%8B%A9%E7%BD%91%E5%8D%A1%EF%BC%8C%E5%8F%B3%E5%87%BB%E5%B9%B6%E5%8D%95%E5%87%BB%E5%90%AF%E7%94%A8%20EtherCAT%E3%80%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E5%BC%B9%E5%87%BA%E6%B6%88%E6%81%AF%EF%BC%9AEtherCAT%20%E4%BB%A3%E7%90%86%E6%97%A0%E6%B3%95%E5%90%AF%E5%8A%A8%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2336759%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20The%20Industrial%20Communication%20Explorer%20cannot%20enable%20EtherCAT%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2336759%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%EF%BC%8C%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F214798%22%20target%3D%22_blank%22%3E%40ethan_dang1%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CP%3E%E6%88%91%E6%B3%A8%E6%84%8F%E5%88%B0%EF%BC%8C%E5%9C%A8%E6%82%A8%E5%85%B1%E4%BA%AB%E7%9A%84%E7%AC%AC%E4%B8%80%E5%BC%A0%E5%9B%BE%E7%89%87%E4%B8%AD%EF%BC%8C%E5%8C%85%E5%90%AB%20ecatproxy.exe%20%E7%9A%84%E6%96%87%E4%BB%B6%E5%A4%B9%E5%90%8D%E4%B8%BA%20%22ect%22%E3%80%82%3C%2FP%3E%0A%3CP%3E%E8%83%BD%E5%90%A6%E8%AF%B7%E6%82%A8%E5%B8%AE%E6%88%91%E5%B0%86%E8%AF%A5%E6%96%87%E4%BB%B6%E5%A4%B9%E9%87%8D%E5%91%BD%E5%90%8D%E4%B8%BA%20%22ecat%22%EF%BC%8C%E5%B9%B6%E4%BB%A5%E8%BF%99%E7%A7%8D%E6%96%B9%E5%BC%8F%E8%BF%9B%E8%A1%8C%E6%B5%8B%E8%AF%95%EF%BC%9F%3C%2FP%3E%0A%3CP%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FP%3E%0A%3CP%3E%E5%B7%B4%E5%8B%83%E7%BD%97%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2337305%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20The%20Industrial%20Communication%20Explorer%20cannot%20enable%20EtherCAT%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2337305%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%B0%86%22ect%22%20%E6%94%B9%E4%B8%BA%22ecat%22%20%E5%90%8E%EF%BC%8C%E4%B8%80%E5%88%87%E6%AD%A3%E5%B8%B8%E3%80%82%E9%9D%9E%E5%B8%B8%E6%84%9F%E8%B0%A2%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E
