Target error from Register access
3,009件の閲覧回数
vasudhevan
     Board - imx rt 1064 evk.
     I created free rtos software timer inside timer callback called PHY_GetLinkStatus(ENET, BOARD_ENET0_PHY_ADDRESS, &link); api.
     If i put this api in free rtos timer callback giving target error from Register access and stopped debugger.
     We want to monitor ethernet link status every one second timer.
     Refereed link - Best way to check Ethernet link
Any other way can we monitor ethernet link status every one second ?
Why i am getting  target error from Register access from timer callback ?
Thanks & Regards
        Vasu
2,930件の閲覧回数
danielchen
Hi Vasu:
Please make sure that you have initialized the enet module before you access the PHY register.
If this issue still exists, could you please let me know how to reproduce your issue on my side?
3 返答(返信)
2,930件の閲覧回数
vasudhevan
Any updates ?
  Vasu
2,931件の閲覧回数
danielchen
Hi Vasu:
2,930件の閲覧回数
vasudhevan
Hi Daniel,
      Thank you for your response.
      You are right enet module not initialized.
Thanks & Regards
        Vasu
