Hi Sir,
Can send us a copy of example code for fsl_tsc driver? We can not find it in SDK (directory <SDK_ROOT>/boards/<BOARD>/driver_examples/fsl_tsc ) or even the SDK builder?
Solved! Go to Solution.
Hi @danielsu ,
Already share you the TSC demo in the private message attachment, please check it.
Wish it helps you!Best Regards,
kerry
Hi Kerry,
Got it,thanks.
Can send us a copy of example code for fsl_tsc driver? RT1052 电阻触摸例子
thank you
[email protected]
