TSC examples
TSC examples
danielsu
Hi Sir,
  Can send us a copy of example code for fsl_tsc driver?  We can not find it in SDK (directory  <SDK_ROOT>/boards/<BOARD>/driver_examples/fsl_tsc ) or even the SDK builder?
kerryzhou
Hi @danielsu ,
  Already share you the TSC demo in the private message attachment, please check it.
Wish it helps you!
kerry
danielsu
Hi Kerry,
   Got it,thanks.
kerryzhou
Hi @danielsu ,
Wish it helps you!
kerry
arm7744
Can send us a copy of example code for fsl_tsc driver? RT1052 电阻触摸例子
thank you
[email protected]
