Hi @jautry
If your code still stuck in the ROM, it means your code didn't boot normally.
Please check the following points at first:
1. whether you can use the JLINK to find the ARM core?
2. Use the debugger download the code to the internal RAM, test this SDK code:
\SDK_2_11_0_EVK-MIMXRT1060\boards\evkmimxrt1060\driver_examples\flexspi\nor\polling_transfer
Whether you can finish the external flash operation?
3. check the BOOT_CFG pin, BOOT_MOD pin with the MIMXRT1060-EVK board, make sure your boot mode is correct, boot CFG pin is correct.
Wish it helps you!
If you still have questions about it, please kindly let me know.
Kerry
