Serial Downloader / Baud Rate
6,677 次查看
jaredm
What is the default Serial Downloader baud rate for the RT1052?
I am trying to program RT1052 fuses using blhost and LPUART1. The default baud rate of blhost is 57600, but this does not work. I have tried 115200 and I get a reasonable response, but blhost still has issues:
    blhost -p COM6,115200 -t 50000 -d -- get-property 1
    [5a a6]
    <5a>
    Ping responded in 1 attempt(s)
    <a8>
    Error: Initial ping failure: Invalid packet type.
Why am I getting this error? Is it due to baud rate or something else?
I looked at the serial lines with a logic analyzer, and everything appears to be OK. Image attached.
6,656 次查看
kerryzhou
Hi jaredm,
   If you want to connect the RT in serail download mode, I suggest you can try the MCUbootutility tool at first, that tool use the blhost and print the log:
Executing: C:\KerryPC\tool\NXP-MCUBootUtility-2.4.0\tools\sdphost\win\sdphost -t 50000 -p COM49,115200 -j -- write-file 539001344 C:\KerryPC\tool\NXP-MCUBootUtility-2.4.0\src\targets\MIMXRT1052\ivt_flashloader.bin
toolStatus: 0
commandOutput: {
"command" : "write-file",
"response" : [ 2290649224 ],
"status" : {
"description" : "1450735702 (0x56787856) HAB disabled.",
"value" : 1450735702
Executing: C:\KerryPC\tool\NXP-MCUBootUtility-2.4.0\tools\sdphost\win\sdphost -t 50000 -p COM49,115200 -j -- jump-address 539001344
toolStatus: 0
commandOutput: {
"command" : "jump-address",
"response" : [],
"status" : {
Executing: C:\KerryPC\tool\NXP-MCUBootUtility-2.4.0\tools\blhost2_3\win\blhost -t 50000 -p COM49,115200 -j -- get-property 1 0
toolStatus: 0
commandOutput: {
"command" : "get-property",
"response" : [ 1258422528 ],
"status" : {
"description" : "0 (0x0) Success.",
"value" : 0
toolStatus: 0
commandOutput: {
"status" : {
"value" : 0
Executing: C:\KerryPC\tool\NXP-MCUBootUtility-2.4.0\tools\blhost2_3\win\blhost -t 50000 -p COM49,115200 -j -- get-property 24 0
toolStatus: 0
commandOutput: {
"response" : [ 1409351680 ],
"status" : {
"value" : 0
You can download that tool from this link:
https://github.com/JayHeng/NXP-MCUBootUtility/releases/tag/v3.0.0
the related user manual is:
Please try it at first, whether this tool can connect your chip or not? Normally, we use 115200bps.
If the mcubootutility works on your side, you can compare your log with the mcubootutility log, which detail things you have lost.
If you still have questions about it after you test with the mcubootutility tool, just kindly let me know.
Kerry
5 回复数
6,647 次查看
jaredm
Hi Kerry,
I tried what you suggested. Using sdphost was successful, but blhost still fails. Do you think it is because I am using LPUART1 instead of USB1?
Below is the response I get.
sdphost -t 15000 -p COM6,115200 -j -- write-file 539001344 ivt_flashloader.bin
"status" : {
sdphost -t 1000 -p COM6,115200 -j -- jump-address 539001344
"response" : [],
"status" : {
blhost -t 1000 -p COM6,115200 -j -- get-property 1 0
"command" : "ping",
"response" : [],
"status" : {
"description" : "10501 (0x2905) Invalid packet type.",
"value" : 10501
6,639 次查看
kerryzhou
Hi jaredm
  Do you use the MCUbootUtility tool directly?  Instead of your own input the log, can you connect it or not?
  Please also share me your MCUBootUtility tool test result and the log.
kerry
6,628 次查看
jaredm
Hi Kerry,
I have found the problem, it was the file ivt_flashloader.bin. The file included with Flashloader_RT1050_1.1 FAILS, but the file included with MCUBootUtility SUCCEEDS.
Flashloader_RT1050_1.1\Tools\mfgtools-rel\Profiles\MXRT105X\OS Firmware\ivt_flashloader.bin   -   FAILURE
NXP-MCUBootUtility-3.0.0\src\targets\MIMXRT1052\ivt_flashloader.bin   -   SUCCESS
Thanks for helping me debug this problem.
jaredm
6,621 次查看
kerryzhou
Hi jaredm,
   The Flashloader_RT1050_1.1 is old, and normally, we use the newest SDK flashloader.
   To me, I prefer to use the MCUbootUtility tool to check the downloading, as that is very simple and easy to use, that's why I suggest you try it at first. Then you even can totally follow the MCUbootUtility tool command to write the detail command to your board.
  Anyway, that's good to hear you already make it works.
  If you have any questions in the future, welcome to create a new question post.
Kerry
6,657 次查看
kerryzhou
Hi jaredm,
toolStatus: 0
commandOutput: {
"status" : {
toolStatus: 0
commandOutput: {
"response" : [],
"status" : {
toolStatus: 0
commandOutput: {
"status" : {
"value" : 0
toolStatus: 0
commandOutput: {
"status" : {
"value" : 0
toolStatus: 0
commandOutput: {
"status" : {
"value" : 0
Kerry
