SFW | nothing happens when i use python to generate bin file
1,216件の閲覧回数
czmyouyu
<MCU-OTA SBL and SFW user guide.pdf>,I follow the following method. but nothing happens,no bin files or errors gengerated。
1,202件の閲覧回数
CarlosGarabito
Hi Chen zhaoming,
In order to get more suport, could you bring us more details about what are you doing?, if you are working with linux or windows?, what board are you try to put micropython?.
so, maybe this tech article can help.
https://www.nxp.com/docs/en/application-note/AN13242.pdf
To update this case, you may reply by email.
To provide confidential information or attachments, you may add that online.
Please login to our NXP technical support portal:
https://support.nxp.com/s/case/5002p00002e6U9VAAU
The portal allows access to the full details of the case, including the previous communication.
Thank you for your interest in NXP Semiconductor products and for the opportunity to serve you.
I hope this will help you
Have a good day
Carlos Enrique
Technical Support
NXP Semiconductor
PS: Please check the NXP Communities at https://community.nxp.com/. Here you will find thousands of technical discussions instantly available for you.
