SDK - preprocessor defined symbols
1,866 次查看
nickwallis
Senior Contributor I
The SDK uses many symbols to alter the build and behaviour of the software.
Please can someone point me at where these are documented?
As a simple example, ethernet SDK projects might define "FSL_FEATURE_PHYKSZ8081_USE_RMII50M_MODE", but there are many, many others.
thanks
Nick
1,852 次查看
jeremyzhou
1) Please can someone point me at where these are documented?
-- Maybe you can try to search these symbol in MCUXpresso SDK API Reference Manual.
Hope it helps.
TIC
1,844 次查看
nickwallis
thanks @jeremyzhou but it's hard to know what to search for if you don't know the names of the symbols in advance!
-Nick
