Running MicroPython on RT10xx
3,125 次查看
shai_b
Senior Contributor II
Dear Team,
My customer needs to run MicroPython on his environment (I am working on RT1064-EVK), I followed App note AN13242 and Micropython online guide but after flashing the ready image
Download from here: https://micropython.org/download/MIMXRT1064_EVK/
I did not get anything on the USB OTG (J9 on the RT106x-EVK).
After plugging the USB into my Windows (11 and 10) it also did not recognize the USB descriptor (maybe it could be a CDC USB Driver issue as well).
Do you have any new AN or can you guide us on implementing MicroPython correctly?
Waiting for your kind feedback, Thanks a lot.
KR,
Shai
标签 (4)
标记 (1)
3,095 次查看
shai_b
Thanks, your fast response will be highly appreciated.
KR,
Shai
4 回复数
3,020 次查看
Pavel_Hernandez
Hello, sorry for the late response, could you review if the LED [D3] of power is ON, if not I suggest changing the jumper of the J1 to the second position when the led turns green.
Pavel
2,988 次查看
shai_b
Dear @Pavel,
I have managed to run the Micropyhton on top of iMX RT1064.
Thank you for your effort, you may close this thread.
Kind regards,
Shai
3,096 次查看
shai_b
KR,
Shai
3,098 次查看
Pavel_Hernandez
Hello, my name is Pavel, and I will be supporting your case, let me get into your case and when I have more information, I will contact you.
Pavel
