We recently updated to SDK 25.12 and noticed that our TLS decryption rate has been cut in half.
mbedTLS v3.x is no longer accelerated using the fsl_hashcrypt hardware features.
Here is the callstack of calling mbedtls_ssl_read using the previous SDK 25.09. As you can see, HASHCRYPT_AES_EncryptEcb is eventually used.
hashcrypt_aes_one_block_aligned() at fsl_hashcrypt.c:437
hashcrypt_aes_one_block() at fsl_hashcrypt.c:581
HASHCRYPT_AES_EncryptEcb() at fsl_hashcrypt.c:1,284
mbedtls_internal_aes_encrypt() at aes_alt.c:1,959
mbedtls_aes_crypt_ecb() at aes_alt.c:1,323
aes_crypt_ecb_wrap() at cipher_wrap.c:114
mbedtls_cipher_update() at cipher.c:521
mbedtls_gcm_update() at gcm.c:358
mbedtls_gcm_crypt_and_tag() at gcm.c:456
mbedtls_gcm_auth_decrypt() at gcm.c:491
mbedtls_cipher_aead_decrypt() at cipher.c:1,407
mbedtls_cipher_auth_decrypt_ext() at cipher.c:1,613
mbedtls_ssl_decrypt_buf() at ssl_msg.c:1,242
ssl_prepare_record_content() at ssl_msg.c:3,667
ssl_get_next_record() at ssl_msg.c:4,551
mbedtls_ssl_read_record() at ssl_msg.c:3,817
mbedtls_ssl_read() at ssl_msg.c:5,237
<...more frames...>
Here is the callstack of SDK 25.12 with MBEDTLS_USE_PSA_CRYPTO defined. In this version, mbedtls_internal_aes_encrypt is all C code with no HW acceleration.
mbedtls_internal_aes_encrypt() at aes.c:894
mbedtls_aes_crypt_ecb() at aes.c:1,062
aes_crypt_ecb_wrap() at cipher_wrap.c:166
mbedtls_cipher_update() at cipher.c:611
gcm_mask() at gcm.c:546
mbedtls_gcm_update() at gcm.c:641
mbedtls_gcm_crypt_and_tag() at gcm.c:726
mbedtls_gcm_auth_decrypt() at gcm.c:753
mbedtls_psa_aead_decrypt() at psa_crypto_aead.c:270
psa_driver_wrapper_aead_decrypt() at psa_crypto_driver_wrappers.h:4,114
psa_aead_decrypt() at psa_crypto.c:5,023
mbedtls_ssl_decrypt_buf() at ssl_msg.c:1,625
ssl_prepare_record_content() at ssl_msg.c:4,093
ssl_get_next_record() at ssl_msg.c:5,068
mbedtls_ssl_read_record() at ssl_msg.c:4,323
mbedtls_ssl_read() at ssl_msg.c:5,983
<...more frames...>
And here is the callstack of SDK 25.12 withoutMBEDTLS_USE_PSA_CRYPTO defined. In this version, mbedtls_internal_aes_encrypt is all C code with no HW acceleration and PSA is not involved.
mbedtls_internal_aes_encrypt() at aes.c:899
mbedtls_gcm_update() at gcm.c:628
mbedtls_cipher_aead_decrypt() at cipher.c:1,528
mbedtls_cipher_auth_decrypt_ext() at cipher.c:1,674
mbedtls_ssl_decrypt_buf() at ssl_msg.c:1,639
<...more frames...>
Are there plans to restore RT685 HASHCRYPT hardware acceleration to mbedTLS? It seems certain PSA Crypto drivers are not implemented.
Thank you.
