RT1176 Qbv scheduling sequence
anjun
Hi, I have a problem right now and I need support
When I tested Qbv on RT1176, I found the following problems:
My GCL configuration list is Q0-100us, Q1-200us, Q2-300uS, Q3-400uS.
However, when BaseTime is set to 0, the scheduling order of Qbv is Q3->.Q2->Q1->Q0......... Q3->Q2->Q1->Q0.
However, when the baseTime configuration is greater than 0, the scheduling order of Qbv is Q0->Q1->Q2->Q3......... Q0->Q1->Q2->Q3.
The scheduling order is reversed.
Please confirm if this is the case.
Hui_Ma
Could you help to share the test project? We would like to do a similar test. Thanks.
best regards,
Mike
