RT1176 Parallel Camera Driver Example
christinad
Hello!
For the RT1176, are there any driver examples to talk to a 8/10/12 bit camera over the parallel camera interface? I only see a MIPI CSI2 example in the SDK. Thank you.
Habib_MS
Hello @christinad,
the RT1176 does not support Parallel Camera Interface. However, in this app note this protocol is emulated with FlexIO. Although this app note uses RT1010 you can take by reference.
Habib.
