RT1176 Custom Board – LED blink app does not run after reset
523 次查看
JoshuaV
I am working on a custom i.MX RT1176 board (based very closely on the FMU design, same memory set up). I am trying to bring up the MCU by blinking a simple LED. The LED is on GPIO_AD_33, which I have configured using the MCUXpresso Config Tools to GPIO10_IO00.
What I have done so far:
  1. Project setup
    • Created a simple LED blink project in MCUXpresso IDE using the SDK for MIMXRT1176.
    • Configured GPIO as output and toggled it every 1s using SysTick.
    • Used MCUXpresso Config Tools 25.06 to configure the pins
  2. Binary output
    • The project builds successfully and produces a .bin file.
  3. Programming method
    • Since this is a custom board, I only have USB-C access to the serial downloader.
    • I used the NXP Secure Provisioning Tool (blhost) to erase flash, write the AXF and binary from the project build.
    • All operations succeed with status 0x0 Success.
  4. The issue
    • After power-cycling the board, nothing happens.
      • I verified the programmed image by using blhost read-memory commands at the FlexSPI NOR addresses. The data at 0x30000400 (FCB), 0x30000600 (image version), and 0x30001000 (application image) matches what I expect
    • The LED on GPIO_AD_33 does not blink.
    • The board always re-enters Serial Downloader mode.
    • I do not have JTAG/SWD access, only USB-C serial downloader.This is the first time I have posted in a forum so I apologize if my ettiquette is off. Thank you.
标记 (3)
4 回复数
402 次查看
Littell
Do you really have a board design that doesn't include SWD/JTAG? If so, you should fire the designer immediately for abject incompetence - you're guaranteed a miserable experience in trying to develop for that brick.
385 次查看
JoshuaV
lol I will fire myself. It’s a hobby board. I’m new to this. Definitely a learning experience for me. I solved the issue. My problem was that I was selecting “Full FDCB” which for whatever reason was not allowing the program to start properly.
368 次查看
Littell
A hobby board? Hahaha, you tend to swing for the fence, don't you?
On a hobby board I'd submit it's even more important to design in debug facilities (GPIO's, LED's, JTAG/SWD) from beginning so you can get on with the fun stuff and not get wrapped around the axle with time-wasting silliness. Good luck to you - these RT's are riddled with quirks and the further you step away from the EVKB the more problems you'll have. Been there...got the scars.
468 次查看
carlos_o
Hi @JoshuaV
Apologies the late reply.
Could you confirm the boot mode of your pins?
After downloading the program to your board remember to change the boot mode to internal boot
%3CLINGO-SUB%20id%3D%22lingo-sub-2177800%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERT1176%20%E8%87%AA%E5%AE%9A%E4%B9%89%E6%9D%BF%20%E2%80%94%20RESET%20%E5%90%8E%20LED%20%E9%97%AA%E7%83%81%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E6%97%A0%E6%B3%95%E8%BF%90%E8%A1%8C%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2177800%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E6%AD%A3%E5%9C%A8%E5%BC%80%E5%8F%91%E4%B8%80%E6%AC%BE%3CSTRONG%3E%E5%AE%9A%E5%88%B6%E7%9A%84%20i.MX%20RT1176%20%E6%9D%BF%3C%2FSTRONG%3E%EF%BC%88%E9%9D%9E%E5%B8%B8%E6%8E%A5%E8%BF%91%E4%BA%8E%20FMU%20%E7%9A%84%E8%AE%BE%E8%AE%A1%EF%BC%8C%E7%9B%B8%E5%90%8C%E7%9A%84%E5%86%85%E5%AD%98%E8%AE%BE%E7%BD%AE%EF%BC%89%E3%80%82%E6%88%91%E6%AD%A3%E8%AF%95%E5%9B%BE%E9%80%9A%E8%BF%87%E9%97%AA%E7%83%81%E4%B8%80%E4%B8%AA%E7%AE%80%E5%8D%95%E7%9A%84%20LED%20%E6%9D%A5%E8%B0%83%E7%94%A8%20MCU%E3%80%82LED%20%E4%BD%8D%E4%BA%8E%3CSTRONG%3EGPIO_AD_33%3C%2FSTRONG%3E%20%E4%B8%8A%EF%BC%8C%E6%88%91%E4%BD%BF%E7%94%A8%3CSTRONG%3EMCUXpresso%20%E9%85%8D%E7%BD%AE%E5%B7%A5%E5%85%B7%3C%2FSTRONG%3E%E5%B0%86%E5%85%B6%E9%85%8D%E7%BD%AE%E4%B8%BA%20GPIO10_IO00%E3%80%82%3C%2FP%3E%3CH4%20id%3D%22toc-hId-178782747%22%20id%3D%22toc-hId-203501751%22%3E%E6%88%91%E7%9B%AE%E5%89%8D%E6%89%80%E5%81%9A%E7%9A%84%3C%2FH4%3E%3COL%3E%3CLI%3E%3CP%3E%3CSTRONG%3E%E9%A1%B9%E7%9B%AE%E8%AE%BE%E7%BD%AE%3C%2FSTRONG%3E%3C%2FP%3E%3CUL%3E%3CLI%3E%3CP%3E%E4%BD%BF%E7%94%A8%20MIMXRT1176%20%E7%9A%84%20SDK%20%E5%9C%A8%20MCUXpresso%20IDE%20%E4%B8%AD%E5%88%9B%E5%BB%BA%E4%BA%86%E4%B8%80%E4%B8%AA%E7%AE%80%E5%8D%95%E7%9A%84%20LED%20%E9%97%AA%E7%83%81%E9%A1%B9%E7%9B%AE%E3%80%82%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%E5%B0%86%20GPIO%20%E9%85%8D%E7%BD%AE%E4%B8%BA%E8%BE%93%E5%87%BA%EF%BC%8C%E5%B9%B6%E4%BD%BF%E7%94%A8%20SysTick%20%E6%AF%8F%201%20%E7%A7%92%E5%88%87%E6%8D%A2%E4%B8%80%E6%AC%A1%E3%80%82%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%E4%BD%BF%E7%94%A8%20MCUXpresso%20%E9%85%8D%E7%BD%AE%E5%B7%A5%E5%85%B7%2025.06%20%E9%85%8D%E7%BD%AE%E5%BC%95%E8%84%9A%3C%2FLI%3E%3C%2FUL%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%3CSTRONG%3E%E4%BA%8C%E8%BF%9B%E5%88%B6%E8%BE%93%E5%87%BA%3C%2FSTRONG%3E%3C%2FP%3E%3CUL%3E%3CLI%3E%3CP%3E%E8%AF%A5%E9%A1%B9%E7%9B%AE%E6%88%90%E5%8A%9F%E7%89%88%E6%9C%AC%E5%B9%B6%E7%94%9F%E6%88%90%E4%BA%86%20.bin%E9%94%89%E5%88%80%3C%2FP%3E%3C%2FLI%3E%3C%2FUL%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%3CSTRONG%3E%E7%BC%96%E7%A8%8B%E6%96%B9%E6%B3%95%3C%2FSTRONG%3E%3C%2FP%3E%3CUL%3E%3CLI%3E%3CP%3E%E7%94%B1%E4%BA%8E%E8%BF%99%E6%98%AF%E4%B8%80%E5%9D%97%E8%87%AA%E5%AE%9A%E4%B9%89%E6%9D%BF%EF%BC%8C%E6%88%91%E5%8F%AA%E8%83%BD%3CSTRONG%3E%E9%80%9A%E8%BF%87%20USB-C%20%E8%AE%BF%E9%97%AE%E4%B8%B2%E8%A1%8C%E4%B8%8B%E8%BD%BD%E5%99%A8%3C%2FSTRONG%3E%E3%80%82%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%E6%88%91%E4%BD%BF%E7%94%A8%3CSTRONG%3E%E6%81%A9%E6%99%BA%E6%B5%A6%E5%AE%89%E5%85%A8%E9%85%8D%E7%BD%AE%E5%B7%A5%E5%85%B7%3C%2FSTRONG%3E%EF%BC%88blhost%EF%BC%89%E4%BB%8E%E9%A1%B9%E7%9B%AE%E7%89%88%E6%9C%AC%E4%B8%AD%E5%88%A0%E9%99%A4%E9%97%AA%E5%AD%98%E3%80%81%E5%86%99%E5%85%A5AXF%E5%92%8C%E4%BA%8C%E8%BF%9B%E5%88%B6%E6%96%87%E4%BB%B6%E3%80%82%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%E6%89%80%E6%9C%89%E6%93%8D%E4%BD%9C%E5%9D%87%E6%88%90%E5%8A%9F%EF%BC%8C%E7%8A%B6%E6%80%81%E4%B8%BA%200x0%20%E6%88%90%E5%8A%9F%E3%80%82%3C%2FP%3E%3C%2FLI%3E%3C%2FUL%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%3CSTRONG%3E%E9%97%AE%E9%A2%98%3C%2FSTRONG%3E%3C%2FP%3E%3CUL%3E%3CLI%3E%3CP%3E%E9%87%8D%E6%96%B0%E5%90%AF%E5%8A%A8%E6%9D%BF%E5%90%8E%EF%BC%8C%E4%BB%80%E4%B9%88%E4%B9%9F%E6%B2%A1%E5%8F%91%E7%94%9F%E3%80%82%3C%2FP%3E%3CUL%3E%3CLI%3E%E6%88%91%E5%9C%A8%20FlexSPI%20%E6%88%96%E9%9D%9E%20%E5%9C%B0%E5%9D%80%E4%B8%8A%E4%BD%BF%E7%94%A8%20%3CSTRONG%3Eblhost%20%E8%AF%BB%E5%8F%96%E5%86%85%E5%AD%98%3C%2FSTRONG%3E%E5%91%BD%E4%BB%A4%E9%AA%8C%E8%AF%81%E4%BA%86%E7%BC%96%E7%A8%8B%E7%9A%84%E5%9B%BE%E5%83%8F%E3%80%820x30000400%EF%BC%88FCB%EF%BC%89%E3%80%810x30000600%EF%BC%88%E5%9B%BE%E5%83%8F%E7%89%88%E6%9C%AC%EF%BC%89%E5%92%8C%200x30001000%EF%BC%88%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E5%9B%BE%E5%83%8F%EF%BC%89%E5%A4%84%E7%9A%84%E6%95%B0%E6%8D%AE%E7%AC%A6%E5%90%88%E6%88%91%E7%9A%84%E9%A2%84%E6%9C%9F%3C%2FLI%3E%3C%2FUL%3E%3C%2FLI%3E%3CLI%3E%3CP%3EGPIO_AD_33%20%E4%B8%8A%E7%9A%84%20LED%20%E4%B8%8D%E9%97%AA%E7%83%81%E3%80%82%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%E6%9D%BF%E6%80%BB%E6%98%AF%E9%87%8D%E6%96%B0%E8%BF%9B%E5%85%A5%3CSTRONG%3E%E4%B8%B2%E8%A1%8C%E4%B8%8B%E8%BD%BD%E5%99%A8%E6%A8%A1%E5%BC%8F%3C%2FSTRONG%3E%E3%80%82%3C%2FP%3E%3C%2FLI%3E%3C%2FUL%3E%3CUL%3E%3CLI%3E%3CP%3E%E6%88%91%E6%B2%A1%E6%9C%89%20JTAG%2FSWD%20%E8%AE%BF%E9%97%AE%E6%9D%83%E9%99%90%EF%BC%8C%E5%8F%AA%E6%9C%89%20USB-C%20%E4%B8%B2%E8%A1%8C%E4%B8%8B%E8%BD%BD%E5%99%A8%E3%80%82%E8%BF%99%E6%98%AF%E6%88%91%E7%AC%AC%E4%B8%80%E6%AC%A1%E5%9C%A8%E8%AE%BA%E5%9D%9B%E4%B8%8A%E5%8F%91%E5%B8%96%EF%BC%8C%E5%A6%82%E6%9E%9C%E6%88%91%E7%9A%84%E7%A4%BC%E4%BB%AA%E6%9C%89%E9%97%AE%E9%A2%98%EF%BC%8C%E8%AF%B7%E5%8E%9F%E8%B0%85%E3%80%82%E8%B0%A2%E8%B0%A2%E3%80%82%20%3C%2FP%3E%3C%2FLI%3E%3C%2FUL%3E%3C%2FLI%3E%3C%2FOL%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2184333%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RT1176%20Custom%20Board%20%E2%80%93%20LED%20blink%20app%20does%20not%20run%20after%20reset%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2184333%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E7%88%B1%E5%A5%BD%E6%9D%BF%EF%BC%9F%E5%93%88%E5%93%88%E5%93%88%EF%BC%8C%E4%BD%A0%E6%80%BB%E6%98%AF%E5%96%9C%E6%AC%A2%E5%9C%A8%E6%A0%85%E6%A0%8F%E4%B8%8A%E6%91%87%E6%91%86%EF%BC%8C%E4%B8%8D%E6%98%AF%E5%90%97%EF%BC%9F%20%3CLI-EMOJI%20id%3D%22lia_winking-face%22%20title%3D%22%3Awinking_face%3A%22%3E%3C%2FLI-EMOJI%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%E5%9C%A8%E4%B8%9A%E4%BD%99%E7%88%B1%E5%A5%BD%E6%9D%BF%E4%B8%8A%EF%BC%8C%E6%88%91%E8%AE%A4%E4%B8%BA%EF%BC%8C%E4%BB%8E%E4%B8%80%E5%BC%80%E5%A7%8B%E5%B0%B1%E4%BD%BF%E7%94%A8%E8%B0%83%E8%AF%95%E8%AE%BE%E6%96%BD%EF%BC%88GPIO%E3%80%81LED%E3%80%81JTAG%2FSWD%EF%BC%89%E8%BF%9B%E8%A1%8C%E8%AE%BE%E8%AE%A1%E6%9B%B4%E4%B8%BA%E9%87%8D%E8%A6%81%EF%BC%8C%E8%BF%99%E6%A0%B7%E4%BD%A0%E6%89%8D%E8%83%BD%E7%BB%A7%E7%BB%AD%E7%8E%A9%E6%9C%89%E8%B6%A3%E7%9A%84%E4%B8%9C%E8%A5%BF%EF%BC%8C%E8%80%8C%E4%B8%8D%E4%BC%9A%E5%9B%A0%E4%B8%BA%E6%B5%AA%E8%B4%B9%E6%97%B6%E9%97%B4%E7%9A%84%E6%84%9A%E8%A0%A2%E8%A1%8C%E4%B8%BA%E8%80%8C%E8%A2%AB%E5%9B%B0%E5%9C%A8%E8%BD%B4%E4%B8%8A%E3%80%82%E7%A5%9D%E4%BD%A0%E5%A5%BD%E8%BF%90--%E8%BF%99%E4%BA%9B%20RT%20%E6%9C%BA%E5%9E%8B%E5%8D%83%E5%A5%87%E7%99%BE%E6%80%AA%EF%BC%8C%E7%A6%BB%20EVKB%20%E8%B6%8A%E8%BF%9C%EF%BC%8C%E9%97%AE%E9%A2%98%E5%B0%B1%E8%B6%8A%E5%A4%9A%E3%80%82%E7%BB%8F%E5%8E%86%E8%BF%87......%E6%9C%89%E4%BC%A4%E7%96%A4%E3%80%82%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2184078%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RT1176%20Custom%20Board%20%E2%80%93%20LED%20blink%20app%20does%20not%20run%20after%20reset%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2184078%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3Elol%20I%20will%20fire%20myself.%E8%BF%99%E6%98%AF%E4%B8%80%E4%B8%AA%E4%B8%9A%E4%BD%99%E7%88%B1%E5%A5%BD%E6%9D%BF%E3%80%82%E6%88%91%E6%98%AF%E6%96%B0%E6%89%8B%E3%80%82%E8%BF%99%E5%AF%B9%E6%88%91%E6%9D%A5%E8%AF%B4%E7%BB%9D%E5%AF%B9%E6%98%AF%E4%B8%80%E6%AC%A1%E5%AD%A6%E4%B9%A0%E7%BB%8F%E5%8E%86%E3%80%82%E6%88%91%E8%A7%A3%E5%86%B3%E4%BA%86%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E3%80%82%E6%88%91%E7%9A%84%E9%97%AE%E9%A2%98%E6%98%AF%EF%BC%8C%E6%88%91%E9%80%89%E6%8B%A9%E7%9A%84%E6%98%AF%20%22%E5%AE%8C%E5%85%A8%20FDCB%22%EF%BC%8C%E4%B8%8D%E7%9F%A5%E4%BB%80%E4%B9%88%E5%8E%9F%E5%9B%A0%EF%BC%8C%E7%A8%8B%E5%BA%8F%E6%97%A0%E6%B3%95%E6%AD%A3%E5%B8%B8%E5%90%AF%E5%8A%A8%E3%80%82%20%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2183969%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RT1176%20Custom%20Board%20%E2%80%93%20LED%20blink%20app%20does%20not%20run%20after%20reset%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2183969%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E4%BD%A0%E7%9A%84%E6%9D%BF%E8%AE%BE%E8%AE%A1%E7%9C%9F%E7%9A%84%E4%B8%8D%E5%8C%85%E5%90%AB%20SWD%2FJTAG%20%E5%90%97%EF%BC%9F%E5%A6%82%E6%9E%9C%E6%98%AF%E8%BF%99%E6%A0%B7%EF%BC%8C%E4%BD%A0%E5%B0%B1%E5%BA%94%E8%AF%A5%E7%AB%8B%E5%8D%B3%E8%A7%A3%E9%9B%87%E8%BF%99%E4%BD%8D%E8%AE%BE%E8%AE%A1%E5%B8%88%EF%BC%8C%E5%9B%A0%E4%B8%BA%E4%BB%96%E5%AE%9E%E5%9C%A8%E6%98%AF%E5%A4%AA%E6%97%A0%E8%83%BD%E4%BA%86--%E4%BD%A0%E5%9C%A8%E5%B0%9D%E8%AF%95%E4%B8%BA%E8%BF%99%E5%9D%97%E7%A0%96%E5%A4%B4%E5%BC%80%E5%8F%91%E6%97%B6%E8%82%AF%E5%AE%9A%E4%BC%9A%E6%9C%89%E7%97%9B%E8%8B%A6%E7%9A%84%E7%BB%8F%E5%8E%86%E3%80%82%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2180040%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RT1176%20Custom%20Board%20%E2%80%93%20LED%20blink%20app%20does%20not%20run%20after%20reset%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2180040%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F255370%22%20target%3D%22_blank%22%3E%40JoshuaV%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E6%8A%B1%E6%AD%89%E5%9B%9E%E5%A4%8D%E6%99%9A%E4%BA%86%E3%80%82%3C%2FP%3E%0A%3CP%3E%E4%BD%A0%E8%83%BD%E7%A1%AE%E8%AE%A4%E4%B8%80%E4%B8%8B%E4%BD%A0%E7%9A%84%E5%AF%86%E7%A0%81%E7%9A%84%E5%90%AF%E5%8A%A8%E6%A8%A1%E5%BC%8F%E5%90%97%EF%BC%9F%3C%2FP%3E%0A%3CP%3E%E5%B0%86%E7%A8%8B%E5%BA%8F%E4%B8%8B%E8%BD%BD%E5%88%B0%E6%9D%BF%E5%90%8E%EF%BC%8C%E8%AE%B0%E5%BE%97%E5%B0%86%E5%90%AF%E5%8A%A8%E6%A8%A1%E5%BC%8F%E6%9B%B4%E6%94%B9%E4%B8%BA%E5%86%85%E9%83%A8%E5%90%AF%E5%8A%A8%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E
