RT1064 UVC example does not work.
yudoc
I am testing one of the UVC example using MIMXRT1064/1050 EVK. The example does not work for both board. My host environment is Ubuntu, Ubuntu is able to detect USB but I cannot initialize any of Linux webcam app. To test UVC example, which application should I use to see a image?
Labels (2)
Tags (2)
jingpan
HI @yudoc ,
I tried guvcview, but yes, it has problem. What tool do you use?
Jing
yudoc
I tested guvcview, cheese. Should I test UVC with windows?
jingpan
Hi @yudoc ,
Yes, it works fine on windows.
Jing
