RT1062 Stalls and Crashes on Read / Write to eLCDIF Config
405 次查看
CameronKramr
Running an RT1062 bare-metal on a custom board with some known issues. Code for configuring the eLCDIF works on the EVK board for the RT1062, but when I run the same code on a custom board, writes or reads to LCDIF control registers stall the processor and causes the debugger (Segger J-link) to error out. If I by-pass PLL5 and use the 24 MHz clock directly, the issue persists in the same way. This is enough to trigger the error on my custom board, but not the EVK:
//Never gets past here
uint32_t ctrl = LCDIF->CTRL;
The LCDIF is the only component that fails like this (so far). I have been able to configure the SEMC, ADC, PIT, and GPIO without issue.
I suspect it's related to the fact that I have to cut the NVCC_PLL trace to the processor due to some design errors and can't otherwise attach the suggested capacitors. Otherwise the 24 MHz Clock starts and is strong/clean.
I've seen similar failures when attempting to edit registers when their clocks are gated, but I've walked the clock tree (manually) several times and it looks good to me.
Because everything else works, I feel like it could be a configuration issue, but because the same code doesn't crash on the EVK, I'm starting to think the issue is hardware related.
Q1: Has anyone else experienced something similar (specific modules not working)?
Q2: Was that was solved by correcting the NVCC_PLL capacitance or something else?
Q3: Are there other troubleshooting tests or things to look at that might shine more light on what's going on?
Trying to get help / suggestions before doing a full re-run of the design.
Here's the clock registers for the by-passed PLL configuration:
ccm                    <struct>
    CCR                0x0401107f
    CSR                0x00000038
    CCSR               0x00000100
    CACRR              0x00000001
    CBCDR              0x38038300
    CBCMR              0xf42e8104
    CSCMR1             0x6793007f
    CSCMR2             0x13192f06
    CSCDR1             0x06490b03
    CS1CDR             0x0ec102c1
    CS2CDR             0x000736c1
    CDCDR              0x33f71f92
    CSCDR2             0x00010150
    CSCDR3             0x00030841
    CDHIPR             0x00000000
    CLPCR              0x00000079
    CISR               0x04d20000
    CIMR               0xffffffff
    CCOSR              0x000a0001
    CGPR               0x0000fe62
    CCGR0              0xc0c00fff
    CCGR1              0xcc033000
    CCGR2              0x3c3f0033
    CCGR3              0xf00c3c00
    CCGR4              0x0000f33f
    CCGR5              0xf0033000
    CCGR6              0x00fc0fff
    CCGR7              0xfff00c30
    CMEOR              0x7fffffff
ccma                   <struct>
    PLL_ARM            0x80002064
    PLL_ARM_SET        0x80002064
    PLL_ARM_CLR        0x80002064
    PLL_ARM_TOG        0x80002064
    PLL_USB1           0x80003000
    PLL_USB1_SET       0x80003000
    PLL_USB1_CLR       0x80003000
    PLL_USB1_TOG       0x80003000
    PLL_USB2           0x00012000
    PLL_USB2_SET       0x00012000
    PLL_USB2_CLR       0x00012000
    PLL_USB2_TOG       0x00012000
    PLL_SYS            0x80002001
    PLL_SYS_SET        0x80002001
    PLL_SYS_CLR        0x80002001
    PLL_SYS_TOG        0x80002001
    PLL_SYS_SS         0x00000000
    PLL_SYS_NUM        0x00000000
    PLL_SYS_DENOM      0x00000012
    PLL_AUDIO          0x00011006
    PLL_AUDIO_SET      0x00011006
    PLL_AUDIO_CLR      0x00011006
    PLL_AUDIO_TOG      0x00011006
    PLL_AUDIO_NUM      0x05f5e100
    PLL_AUDIO_DENOM    0x2964619c
    PLL_VIDEO          0x0011201b
    PLL_VIDEO_SET      0x0011201b
    PLL_VIDEO_CLR      0x0011201b
    PLL_VIDEO_TOG      0x0011201b
    PLL_VIDEO_NUM      0x05f5e100
    PLL_VIDEO_DENOM    0x10a24447
    PLL_ENET           0x00011005
    PLL_ENET_SET       0x00011005
    PLL_ENET_CLR       0x00011005
    PLL_ENET_TOG       0x00011005
    PFD_480            0x0f1a234c
    PFD_480_SET        0x0f1a234c
    PFD_480_CLR        0x0f1a234c
    PFD_480_TOG        0x0f1a234c
    PFD_528            0x405d4040
    PFD_528_SET        0x405d4040
    PFD_528_CLR        0x405d4040
    PFD_528_TOG        0x405d4040
    MISC0              0x24008080
    MISC0_SET          0x24008080
    MISC0_CLR          0x24008080
    MISC0_TOG          0x24008080
    MISC1              0x80030000
    MISC1_SET          0x80030000
    MISC1_CLR          0x80030000
    MISC1_TOG          0x80030000
    MISC2              0x002f272f
    MISC2_SET          0x002f272f
    MISC2_CLR          0x002f272f
    MISC2_TOG          0x002f272f
2 回复数
272 次查看
Gavin_Jia
Hi @CameronKramr ,
Thanks for your interest in NXP MIMXRT series!
Based on the values you provided for the `CSCDR2` register, the LCDIF pre-clock is still routed through the PLL5 path. The NVCC_PLL capacitor you mentioned is a potential issue; we recommend following the hardware development manual.
Gavin
245 次查看
CameronKramr
Hi Gavin,
Thanks for your reply. I thought by configuring by-pass mode in the PLL, it shouldn't matter that I still "used" PLL5. Thanks for the recommendation though.
Anyway, I tried it using PLL2 and still have the same issue. Here's my clock configuration showing that::
ccm                    <struct>
    CCR                0x0401107f
    CSR                0x00000038
    CCSR               0x00000100
    CACRR              0x00000001
    CBCDR              0x38038300
    CBCMR              0xf52e8104
    CSCMR1             0x6793007f
    CSCMR2             0x13192f06
    CSCDR1             0x06490b03
    CS1CDR             0x0ec102c1
    CS2CDR             0x000736c1
    CDCDR              0x33f71f92
    CSCDR2             0x001c7150
    CSCDR3             0x00030841
    CDHIPR             0x00000000
    CLPCR              0x00000079
    CISR               0x04d20000
    CIMR               0xffffffff
    CCOSR              0x000a0001
    CGPR               0x0000fe62
    CCGR0              0xc0c00fff
    CCGR1              0xcc033000
    CCGR2              0x3c3f00f3
    CCGR3              0xf00c3c00
    CCGR4              0x0000f33f
    CCGR5              0xf0033000
    CCGR6              0x00fc0fff
    CCGR7              0xfff00c30
    CMEOR              0x7fffffff
ccma                   <struct>
    PLL_ARM            0x80002064
    PLL_USB1           0x80003000
    PLL_USB2           0x00012000
    PLL_SYS            0x80002001
    PLL_VIDEO          0x0001100c
    PLL_VIDEO_SET      0x0001100c
    PLL_VIDEO_CLR      0x0001100c
    PLL_VIDEO_TOG      0x0001100c
    PLL_ENET           0x00011005
    PFD_480            0x0f1a234c
    PFD_528            0x405d4040
    MISC0              0x24008080
    MISC1              0x80030000
    MISC2              0x002f272f
Please let me know if anything else would help debug the issue. I have new boards that will have the NVCC_PLL capacitors so I'll be able to test with that. I just think it's strange that the LCDIF appears to be the only module affected. Thanks again for your help!
%3CLINGO-SUB%20id%3D%22lingo-sub-2348722%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERT1062%20%E5%9C%A8%E8%AF%BB%E5%8F%96%2F%E5%86%99%E5%85%A5%20eLCDIF%20%E9%85%8D%E7%BD%AE%E6%97%B6%E5%81%9C%E6%BB%9E%E5%92%8C%E5%B4%A9%E6%BA%83%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2348722%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%9C%A8%E8%87%AA%E5%AE%9A%E4%B9%89%E4%B8%BB%E6%9D%BF%E4%B8%8A%E8%A3%B8%E6%9C%BA%E8%BF%90%E8%A1%8C%20RT1062%EF%BC%8C%E4%BD%86%E5%AD%98%E5%9C%A8%E4%B8%80%E4%BA%9B%E5%B7%B2%E7%9F%A5%E9%97%AE%E9%A2%98%E3%80%82%E9%85%8D%E7%BD%AE%20ELCDIF%20%E7%9A%84%E4%BB%A3%E7%A0%81%E5%9C%A8%20RT1062%20%E7%9A%84%20EVK%20%E6%9D%BF%E4%B8%8A%E8%BF%90%E8%A1%8C%EF%BC%8C%E4%BD%86%E6%98%AF%E5%BD%93%E6%88%91%E5%9C%A8%E8%87%AA%E5%AE%9A%E4%B9%89%E4%B8%BB%E6%9D%BF%E4%B8%8A%E8%BF%90%E8%A1%8C%E7%9B%B8%E5%90%8C%E7%9A%84%E4%BB%A3%E7%A0%81%E6%97%B6%EF%BC%8C%E5%86%99%E5%85%A5%E6%88%96%E8%AF%BB%E5%8F%96%20LCDIF%20%E6%8E%A7%E5%88%B6%E5%AF%84%E5%AD%98%E5%99%A8%E4%BC%9A%E4%BD%BF%E5%A4%84%E7%90%86%E5%99%A8%E5%81%9C%E6%AD%A2%E8%BF%90%E8%A1%8C%E5%B9%B6%E5%AF%BC%E8%87%B4%E8%B0%83%E8%AF%95%E5%99%A8%EF%BC%88Segger%20J-Link%EF%BC%89%E5%87%BA%E9%94%99%E3%80%82%E5%A6%82%E6%9E%9C%E7%BB%95%E8%BF%87%20PLL5%20%E7%9B%B4%E6%8E%A5%E4%BD%BF%E7%94%A8%2024%20MHz%20%E6%97%B6%E9%92%9F%EF%BC%8C%E9%97%AE%E9%A2%98%E4%BE%9D%E7%84%B6%E5%AD%98%E5%9C%A8%E3%80%82%E8%BF%99%E8%B6%B3%E4%BB%A5%E5%9C%A8%E6%88%91%E7%9A%84%E8%87%AA%E5%AE%9A%E4%B9%89%E4%B8%BB%E6%9D%BF%E4%B8%8A%E8%A7%A6%E5%8F%91%E9%94%99%E8%AF%AF%EF%BC%8C%E4%BD%86%E4%B8%8D%E6%98%AF%20EVK%EF%BC%9A%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-c%22%3E%3CCODE%20translate%3D%22no%22%3E%2F%2FNever%20gets%20past%20here%0Auint32_t%20ctrl%20%3D%20LCDIF-%26gt%3BCTRL%3B%3C%2FCODE%3E%3C%2FPRE%3E%3CP%3ELCDIF%20%E6%98%AF%E5%94%AF%E4%B8%80%E5%87%BA%E7%8E%B0%E8%BF%99%E7%A7%8D%E6%95%85%E9%9A%9C%E7%9A%84%E5%85%83%E5%99%A8%E4%BB%B6%EF%BC%88%E5%88%B0%E7%9B%AE%E5%89%8D%E4%B8%BA%E6%AD%A2%EF%BC%89%E3%80%82%E6%88%91%E5%8F%AF%E4%BB%A5%E9%A1%BA%E5%88%A9%E9%85%8D%E7%BD%AE%20SEMC%E3%80%81ADC%E3%80%81PIT%20%E5%92%8C%20GPIO%E3%80%82%20%3C%2FP%3E%3CP%3E%E6%88%91%E6%80%80%E7%96%91%E8%BF%99%E4%B8%8E%E4%BB%A5%E4%B8%8B%E4%BA%8B%E5%AE%9E%E6%9C%89%E5%85%B3%EF%BC%9A%E7%94%B1%E4%BA%8E%E4%B8%80%E4%BA%9B%E8%AE%BE%E8%AE%A1%E9%94%99%E8%AF%AF%EF%BC%8C%E6%88%91%E5%BF%85%E9%A1%BB%E5%88%87%E6%96%AD%E5%A4%84%E7%90%86%E5%99%A8%E7%9A%84%20NVCC_PLL%20%E8%B5%B0%E7%BA%BF%EF%BC%8C%E5%90%A6%E5%88%99%E6%97%A0%E6%B3%95%E8%BF%9E%E6%8E%A5%E5%BB%BA%E8%AE%AE%E7%9A%84%E7%94%B5%E5%AE%B9%E3%80%82%E5%90%A6%E5%88%99%EF%BC%8C24%20MHz%20%E6%97%B6%E9%92%9F%E5%B0%B1%E4%BC%9A%E5%90%AF%E5%8A%A8%EF%BC%8C%E5%B9%B6%E4%B8%94%E5%BE%88%E5%BC%BA%2F%E5%BE%88%E5%B9%B2%E5%87%80%E3%80%82%3C%2FP%3E%3CP%3E%E5%BD%93%E5%AF%84%E5%AD%98%E5%99%A8%E7%9A%84%E6%97%B6%E9%92%9F%E5%A4%84%E4%BA%8E%E9%97%A8%E6%8E%A7%E7%8A%B6%E6%80%81%E6%97%B6%EF%BC%8C%E6%88%91%E5%9C%A8%E5%B0%9D%E8%AF%95%E7%BC%96%E8%BE%91%E5%AF%84%E5%AD%98%E5%99%A8%E6%97%B6%E4%B9%9F%E9%81%87%E5%88%B0%E8%BF%87%E7%B1%BB%E4%BC%BC%E7%9A%84%E6%95%85%E9%9A%9C%EF%BC%8C%E4%BD%86%E6%88%91%E5%B7%B2%E7%BB%8F%EF%BC%88%E6%89%8B%E5%8A%A8%EF%BC%89%E8%B5%B0%E4%BA%86%E5%A5%BD%E5%87%A0%E6%AC%A1%E6%97%B6%E9%92%9F%E6%A0%91%EF%BC%8C%E5%9C%A8%E6%88%91%E7%9C%8B%E6%9D%A5%E4%B8%80%E5%88%87%E6%AD%A3%E5%B8%B8%E3%80%82%3C%2FP%3E%3CP%3E%E5%9B%A0%E4%B8%BA%E5%85%B6%E4%BB%96%E4%B8%80%E5%88%87%E6%AD%A3%E5%B8%B8%EF%BC%8C%E6%88%91%E8%A7%89%E5%BE%97%E5%8F%AF%E8%83%BD%E6%98%AF%E9%85%8D%E7%BD%AE%E9%97%AE%E9%A2%98%EF%BC%8C%E4%BD%86%E5%9B%A0%E4%B8%BA%E5%90%8C%E6%A0%B7%E7%9A%84%E4%BB%A3%E7%A0%81%E5%9C%A8%20EVK%20%E4%B8%8A%E4%B8%8D%E4%BC%9A%E5%B4%A9%E6%BA%83%EF%BC%8C%E6%88%91%E5%BC%80%E5%A7%8B%E8%A7%89%E5%BE%97%E9%97%AE%E9%A2%98%E4%B8%8E%E7%A1%AC%E4%BB%B6%E6%9C%89%E5%85%B3%E3%80%82%3C%2FP%3E%3CP%3E%E9%97%AE%E9%A2%98%201%EF%BC%9A%E6%98%AF%E5%90%A6%E6%9C%89%E4%BA%BA%E9%81%87%E5%88%B0%E8%BF%87%E7%B1%BB%E4%BC%BC%E6%83%85%E5%86%B5%EF%BC%88%E7%89%B9%E5%AE%9A%E6%A8%A1%E5%9D%97%E6%97%A0%E6%B3%95%E5%B7%A5%E4%BD%9C%EF%BC%89%EF%BC%9F%3C%2FP%3E%3CP%3E%E9%97%AE%E9%A2%98%202%EF%BC%9A%E6%98%AF%E9%80%9A%E8%BF%87%E4%BF%AE%E6%AD%A3%20NVCC_PLL%20%E7%94%B5%E5%AE%B9%E8%BF%98%E6%98%AF%E5%85%B6%E4%BB%96%E6%96%B9%E6%B3%95%E8%A7%A3%E5%86%B3%E4%BA%86%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%EF%BC%9F%3C%2FP%3E%3CP%3E%E9%97%AE%E9%A2%98%203%EF%BC%9A%20%E6%98%AF%E5%90%A6%E6%9C%89%E5%85%B6%E4%BB%96%E6%95%85%E9%9A%9C%E6%8E%92%E9%99%A4%E6%B5%8B%E8%AF%95%E6%88%96%E9%9C%80%E8%A6%81%E6%9F%A5%E7%9C%8B%E7%9A%84%E5%86%85%E5%AE%B9%EF%BC%8C%E5%8F%AF%E4%BB%A5%E6%9B%B4%E6%B8%85%E6%A5%9A%E5%9C%B0%E8%AF%B4%E6%98%8E%E9%97%AE%E9%A2%98%E6%89%80%E5%9C%A8%EF%BC%9F%3C%2FP%3E%3CP%3E%E5%9C%A8%E9%87%8D%E6%96%B0%E8%BF%9B%E8%A1%8C%E5%85%A8%E9%9D%A2%E8%AE%BE%E8%AE%A1%E4%B9%8B%E5%89%8D%EF%BC%8C%E6%88%91%E6%83%B3%E5%AF%BB%E6%B1%82%E5%B8%AE%E5%8A%A9%2F%E5%BB%BA%E8%AE%AE%E3%80%82%3C%2FP%3E%3CP%3E%E8%BF%99%E6%98%AF%E6%97%81%E8%B7%AF%20PLL%20%E9%85%8D%E7%BD%AE%E7%9A%84%E6%97%B6%E9%92%9F%E5%AF%84%E5%AD%98%E5%99%A8%EF%BC%9A%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3Eccm%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%3CSTRUCT%3E%20%20%20%20%20%20%0A%20%20%20%20CCR%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%200x0401107f%20%20%20%20%0A%20%20%20%20CSR%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%200x00000038%20%20%20%20%0A%20%20%20%20CCSR%20%20%20%20%20%20%20%20%20%20%20%20%20%20%200x00000100%20%20%20%20%0A%20%20%20%20CACRR%20%20%20%20%20%20%20%20%20%20%20%20%20%200x00000001%20%20%20%20%0A%20%20%20%20CBCDR%20%20%20%20%20%20%20%20%20%20%20%20%20%200x38038300%20%20%20%20%0A%20%20%20%20CBCMR%20%20%20%20%20%20%20%20%20%20%20%20%20%200xf42e8104%20%20%20%20%0A%20%20%20%20CSCMR1%20%20%20%20%20%20%20%20%20%20%20%20%200x6793007f%20%20%20%20%0A%20%20%20%20CSCMR2%20%20%20%20%20%20%20%20%20%20%20%20%200x13192f06%20%20%20%20%0A%20%20%20%20CSCDR1%20%20%20%20%20%20%20%20%20%20%20%20%200x06490b03%20%20%20%20%0A%20%20%20%20CS1CDR%20%20%20%20%20%20%20%20%20%20%20%20%200x0ec102c1%20%20%20%20%0A%20%20%20%20CS2CDR%20%20%20%20%20%20%20%20%20%20%20%20%200x000736c1%20%20%20%20%0A%20%20%20%20CDCDR%20%20%20%20%20%20%20%20%20%20%20%20%20%200x33f71f92%20%20%20%20%0A%20%20%20%20CSCDR2%20%20%20%20%20%20%20%20%20%20%20%20%200x00010150%20%20%20%20%0A%20%20%20%20CSCDR3%20%20%20%20%20%20%20%20%20%20%20%20%200x00030841%20%20%20%20%0A%20%20%20%20CDHIPR%20%20%20%20%20%20%20%20%20%20%20%20%200x00000000%20%20%20%20%0A%20%20%20%20CLPCR%20%20%20%20%20%20%20%20%20%20%20%20%20%200x00000079%20%20%20%20%0A%20%20%20%20CISR%20%20%20%20%20%20%20%20%20%20%20%20%20%20%200x04d20000%20%20%20%20%0A%20%20%20%20CIMR%20%20%20%20%20%20%20%20%20%20%20%20%20%20%200xffffffff%20%20%20%20%0A%20%20%20%20CCOSR%20%20%20%20%20%20%20%20%20%20%20%20%20%200x000a0001%20%20%20%20%0A%20%20%20%20CGPR%20%20%20%20%20%20%20%20%20%20%20%20%20%20%200x0000fe62%20%20%20%20%0A%20%20%20%20CCGR0%20%20%20%20%20%20%20%20%20%20%20%20%20%200xc0c00fff%20%20%20%20%0A%20%20%20%20CCGR1%20%20%20%20%20%20%20%20%20%20%20%20%20%200xcc033000%20%20%20%20%0A%20%20%20%20CCGR2%20%20%20%20%20%20%20%20%20%20%20%20%20%200x3c3f0033%20%20%20%20%0A%20%20%20%20CCGR3%20%20%20%20%20%20%20%20%20%20%20%20%20%200xf00c3c00%20%20%20%20%0A%20%20%20%20CCGR4%20%20%20%20%20%20%20%20%20%20%20%20%20%200x0000f33f%20%20%20%20%0A%20%20%20%20CCGR5%20%20%20%20%20%20%20%20%20%20%20%20%20%200xf0033000%20%20%20%20%0A%20%20%20%20CCGR6%20%20%20%20%20%20%20%20%20%20%20%20%20%200x00fc0fff%20%20%20%20%0A%20%20%20%20CCGR7%20%20%20%20%20%20%20%20%20%20%20%20%20%200xfff00c30%20%20%20%20%0A%20%20%20%20CMEOR%20%20%20%20%20%20%20%20%20%20%20%20%20%200x7fffffff%20%20%20%20%0Accma%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%3CSTRUCT%3E%20%20%20%20%20%20%0A%20%20%20%20PLL_ARM%20%20%20%20%20%20%20%20%20%20%20%200x80002064%20%20%20%20%0A%20%20%20%20PLL_ARM_SET%20%20%20%20%20%20%20%200x80002064%20%20%20%20%0A%20%20%20%20PLL_ARM_CLR%20%20%20%20%20%20%20%200x80002064%20%20%20%20%0A%20%20%20%20PLL_ARM_TOG%20%20%20%20%20%20%20%200x80002064%20%20%20%20%0A%20%20%20%20PLL_USB1%20%20%20%20%20%20%20%20%20%20%200x80003000%20%20%20%20%0A%20%20%20%20PLL_USB1_SET%20%20%20%20%20%20%200x80003000%20%20%20%20%0A%20%20%20%20PLL_USB1_CLR%20%20%20%20%20%20%200x80003000%20%20%20%20%0A%20%20%20%20PLL_USB1_TOG%20%20%20%20%20%20%200x80003000%20%20%20%20%0A%20%20%20%20PLL_USB2%20%20%20%20%20%20%20%20%20%20%200x00012000%20%20%20%20%0A%20%20%20%20PLL_USB2_SET%20%20%20%20%20%20%200x00012000%20%20%20%20%0A%20%20%20%20PLL_USB2_CLR%20%20%20%20%20%20%200x00012000%20%20%20%20%0A%20%20%20%20PLL_USB2_TOG%20%20%20%20%20%20%200x00012000%20%20%20%20%0A%20%20%20%20PLL_SYS%20%20%20%20%20%20%20%20%20%20%20%200x80002001%20%20%20%20%0A%20%20%20%20PLL_SYS_SET%20%20%20%20%20%20%20%200x80002001%20%20%20%20%0A%20%20%20%20PLL_SYS_CLR%20%20%20%20%20%20%20%200x80002001%20%20%20%20%0A%20%20%20%20PLL_SYS_TOG%20%20%20%20%20%20%20%200x80002001%20%20%20%20%0A%20%20%20%20PLL_SYS_SS%20%20%20%20%20%20%20%20%200x00000000%20%20%20%20%0A%20%20%20%20PLL_SYS_NUM%20%20%20%20%20%20%20%200x00000000%20%20%20%20%0A%20%20%20%20PLL_SYS_DENOM%20%20%20%20%20%200x00000012%20%20%20%20%0A%20%20%20%20PLL_AUDIO%20%20%20%20%20%20%20%20%20%200x00011006%20%20%20%20%0A%20%20%20%20PLL_AUDIO_SET%20%20%20%20%20%200x00011006%20%20%20%20%0A%20%20%20%20PLL_AUDIO_CLR%20%20%20%20%20%200x00011006%20%20%20%20%0A%20%20%20%20PLL_AUDIO_TOG%20%20%20%20%20%200x00011006%20%20%20%20%0A%20%20%20%20PLL_AUDIO_NUM%20%20%20%20%20%200x05f5e100%20%20%20%20%0A%20%20%20%20PLL_AUDIO_DENOM%20%20%20%200x2964619c%20%20%20%20%0A%20%20%20%20PLL_VIDEO%20%20%20%20%20%20%20%20%20%200x0011201b%20%20%20%20%0A%20%20%20%20PLL_VIDEO_SET%20%20%20%20%20%200x0011201b%20%20%20%20%0A%20%20%20%20PLL_VIDEO_CLR%20%20%20%20%20%200x0011201b%20%20%20%20%0A%20%20%20%20PLL_VIDEO_TOG%20%20%20%20%20%200x0011201b%20%20%20%20%0A%20%20%20%20PLL_VIDEO_NUM%20%20%20%20%20%200x05f5e100%20%20%20%20%0A%20%20%20%20PLL_VIDEO_DENOM%20%20%20%200x10a24447%20%20%20%20%0A%20%20%20%20PLL_ENET%20%20%20%20%20%20%20%20%20%20%200x00011005%20%20%20%20%0A%20%20%20%20PLL_ENET_SET%20%20%20%20%20%20%200x00011005%20%20%20%20%0A%20%20%20%20PLL_ENET_CLR%20%20%20%20%20%20%200x00011005%20%20%20%20%0A%20%20%20%20PLL_ENET_TOG%20%20%20%20%20%20%200x00011005%20%20%20%20%0A%20%20%20%20PFD_480%20%20%20%20%20%20%20%20%20%20%20%200x0f1a234c%20%20%20%20%0A%20%20%20%20PFD_480_SET%20%20%20%20%20%20%20%200x0f1a234c%20%20%20%20%0A%20%20%20%20PFD_480_CLR%20%20%20%20%20%20%20%200x0f1a234c%20%20%20%20%0A%20%20%20%20PFD_480_TOG%20%20%20%20%20%20%20%200x0f1a234c%20%20%20%20%0A%20%20%20%20PFD_528%20%20%20%20%20%20%20%20%20%20%20%200x405d4040%20%20%20%20%0A%20%20%20%20PFD_528_SET%20%20%20%20%20%20%20%200x405d4040%20%20%20%20%0A%20%20%20%20PFD_528_CLR%20%20%20%20%20%20%20%200x405d4040%20%20%20%20%0A%20%20%20%20PFD_528_TOG%20%20%20%20%20%20%20%200x405d4040%20%20%20%20%0A%20%20%20%20MISC0%20%20%20%20%20%20%20%20%20%20%20%20%20%200x24008080%20%20%20%20%0A%20%20%20%20MISC0_SET%20%20%20%20%20%20%20%20%20%200x24008080%20%20%20%20%0A%20%20%20%20MISC0_CLR%20%20%20%20%20%20%20%20%20%200x24008080%20%20%20%20%0A%20%20%20%20MISC0_TOG%20%20%20%20%20%20%20%20%20%200x24008080%20%20%20%20%0A%20%20%20%20MISC1%20%20%20%20%20%20%20%20%20%20%20%20%20%200x80030000%20%20%20%20%0A%20%20%20%20MISC1_SET%20%20%20%20%20%20%20%20%20%200x80030000%20%20%20%20%0A%20%20%20%20MISC1_CLR%20%20%20%20%20%20%20%20%20%200x80030000%20%20%20%20%0A%20%20%20%20MISC1_TOG%20%20%20%20%20%20%20%20%20%200x80030000%20%20%20%20%0A%20%20%20%20MISC2%20%20%20%20%20%20%20%20%20%20%20%20%20%200x002f272f%20%20%20%20%0A%20%20%20%20MISC2_SET%20%20%20%20%20%20%20%20%20%200x002f272f%20%20%20%20%0A%20%20%20%20MISC2_CLR%20%20%20%20%20%20%20%20%20%200x002f272f%20%20%20%20%0A%20%20%20%20MISC2_TOG%20%20%20%20%20%20%20%20%20%200x002f272f%20%20%20%20%3C%2FSTRUCT%3E%3C%2FSTRUCT%3E%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2350500%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RT1062%20Stalls%20and%20Crashes%20on%20Read%20%2F%20Write%20to%20eLCDIF%20Config%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2350500%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F260054%22%20target%3D%22_blank%22%3E%40CameronKramr%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E5%85%B3%E6%B3%A8%E6%81%A9%E6%99%BA%E6%B5%A6%20MIMXRT%20%E7%B3%BB%E5%88%97%EF%BC%81%3C%2FP%3E%0A%3CP%3E%E6%A0%B9%E6%8D%AE%E6%82%A8%E4%B8%BA%60CSCDR2%60%E5%AF%84%E5%AD%98%E5%99%A8%E6%8F%90%E4%BE%9B%E7%9A%84%E5%80%BC%EF%BC%8CLCDIF%20%E9%A2%84%E6%97%B6%E9%92%9F%E4%BB%8D%E9%80%9A%E8%BF%87%20PLL5%20%E8%B7%AF%E5%BE%84%E8%B7%AF%E7%94%B1%E3%80%82%E6%82%A8%E6%8F%90%E5%88%B0%E7%9A%84%20NVCC_PLL%20%E7%94%B5%E5%AE%B9%E6%98%AF%E4%B8%80%E4%B8%AA%E6%BD%9C%E5%9C%A8%E7%9A%84%E9%97%AE%E9%A2%98%EF%BC%9B%E6%88%91%E4%BB%AC%E5%BB%BA%E8%AE%AE%E6%82%A8%E9%81%B5%E5%BE%AA%E7%A1%AC%E4%BB%B6%E5%BC%80%E5%8F%91%E6%89%8B%E5%86%8C%E3%80%82%3C%2FP%3E%0A%3CP%3E%E8%87%B4%E4%BB%A5%E6%9C%80%E8%AF%9A%E6%8C%9A%E7%9A%84%E9%97%AE%E5%80%99%EF%BC%8C%3CBR%20%2F%3EGavin%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2351677%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RT1062%20Stalls%20and%20Crashes%20on%20Read%20%2F%20Write%20to%20eLCDIF%20Config%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2351677%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%EF%BC%8C%E5%8A%A0%E6%96%87%E3%80%81%3C%2FP%3E%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E7%AD%94%E5%A4%8D%E3%80%82%E6%88%91%E4%BB%A5%E4%B8%BA%E9%80%9A%E8%BF%87%E5%9C%A8%20PLL%20%E4%B8%AD%E9%85%8D%E7%BD%AE%E6%97%81%E8%B7%AF%E6%A8%A1%E5%BC%8F%EF%BC%8C%E5%B0%B1%E4%B8%8D%E4%BC%9A%E5%BD%B1%E5%93%8D%E6%88%91%E4%BB%8D%E7%84%B6%E4%BD%BF%E7%94%A8%22%22%20PLL5%E3%80%82%E8%B0%A2%E8%B0%A2%E4%BD%A0%E7%9A%84%E6%8E%A8%E8%8D%90%E3%80%82%3C%2FP%3E%3CP%3E%E6%80%BB%E4%B9%8B%EF%BC%8C%E6%88%91%E7%94%A8%20PLL2%20%E8%AF%95%E4%BA%86%E4%B8%80%E4%B8%8B%EF%BC%8C%E8%BF%98%E6%98%AF%E6%9C%89%E5%90%8C%E6%A0%B7%E7%9A%84%E9%97%AE%E9%A2%98%E3%80%82%E4%B8%8B%E9%9D%A2%E6%98%AF%E6%88%91%E7%9A%84%E6%97%B6%E9%92%9F%E9%85%8D%E7%BD%AE%E6%98%BE%E7%A4%BA%EF%BC%9A%EF%BC%9A%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3Eccm%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%3CSTRUCT%3E%20%20%20%20%20%20%0A%20%20%20%20CCR%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%200x0401107f%20%20%20%20%0A%20%20%20%20CSR%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%200x00000038%20%20%20%20%0A%20%20%20%20CCSR%20%20%20%20%20%20%20%20%20%20%20%20%20%20%200x00000100%20%20%20%20%0A%20%20%20%20CACRR%20%20%20%20%20%20%20%20%20%20%20%20%20%200x00000001%20%20%20%20%0A%20%20%20%20CBCDR%20%20%20%20%20%20%20%20%20%20%20%20%20%200x38038300%20%20%20%20%0A%20%20%20%20CBCMR%20%20%20%20%20%20%20%20%20%20%20%20%20%200xf52e8104%20%20%20%20%0A%20%20%20%20CSCMR1%20%20%20%20%20%20%20%20%20%20%20%20%200x6793007f%20%20%20%20%0A%20%20%20%20CSCMR2%20%20%20%20%20%20%20%20%20%20%20%20%200x13192f06%20%20%20%20%0A%20%20%20%20CSCDR1%20%20%20%20%20%20%20%20%20%20%20%20%200x06490b03%20%20%20%20%0A%20%20%20%20CS1CDR%20%20%20%20%20%20%20%20%20%20%20%20%200x0ec102c1%20%20%20%20%0A%20%20%20%20CS2CDR%20%20%20%20%20%20%20%20%20%20%20%20%200x000736c1%20%20%20%20%0A%20%20%20%20CDCDR%20%20%20%20%20%20%20%20%20%20%20%20%20%200x33f71f92%20%20%20%20%0A%20%20%20%20CSCDR2%20%20%20%20%20%20%20%20%20%20%20%20%200x001c7150%20%20%20%20%0A%20%20%20%20CSCDR3%20%20%20%20%20%20%20%20%20%20%20%20%200x00030841%20%20%20%20%0A%20%20%20%20CDHIPR%20%20%20%20%20%20%20%20%20%20%20%20%200x00000000%20%20%20%20%0A%20%20%20%20CLPCR%20%20%20%20%20%20%20%20%20%20%20%20%20%200x00000079%20%20%20%20%0A%20%20%20%20CISR%20%20%20%20%20%20%20%20%20%20%20%20%20%20%200x04d20000%20%20%20%20%0A%20%20%20%20CIMR%20%20%20%20%20%20%20%20%20%20%20%20%20%20%200xffffffff%20%20%20%20%0A%20%20%20%20CCOSR%20%20%20%20%20%20%20%20%20%20%20%20%20%200x000a0001%20%20%20%20%0A%20%20%20%20CGPR%20%20%20%20%20%20%20%20%20%20%20%20%20%20%200x0000fe62%20%20%20%20%0A%20%20%20%20CCGR0%20%20%20%20%20%20%20%20%20%20%20%20%20%200xc0c00fff%20%20%20%20%0A%20%20%20%20CCGR1%20%20%20%20%20%20%20%20%20%20%20%20%20%200xcc033000%20%20%20%20%0A%20%20%20%20CCGR2%20%20%20%20%20%20%20%20%20%20%20%20%20%200x3c3f00f3%20%20%20%20%0A%20%20%20%20CCGR3%20%20%20%20%20%20%20%20%20%20%20%20%20%200xf00c3c00%20%20%20%20%0A%20%20%20%20CCGR4%20%20%20%20%20%20%20%20%20%20%20%20%20%200x0000f33f%20%20%20%20%0A%20%20%20%20CCGR5%20%20%20%20%20%20%20%20%20%20%20%20%20%200xf0033000%20%20%20%20%0A%20%20%20%20CCGR6%20%20%20%20%20%20%20%20%20%20%20%20%20%200x00fc0fff%20%20%20%20%0A%20%20%20%20CCGR7%20%20%20%20%20%20%20%20%20%20%20%20%20%200xfff00c30%20%20%20%20%0A%20%20%20%20CMEOR%20%20%20%20%20%20%20%20%20%20%20%20%20%200x7fffffff%20%20%20%20%0Accma%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%3CSTRUCT%3E%20%20%20%20%20%20%0A%20%20%20%20PLL_ARM%20%20%20%20%20%20%20%20%20%20%20%200x80002064%20%20%20%20%0A%20%20%20%20PLL_ARM_SET%20%20%20%20%20%20%20%200x80002064%20%20%20%20%0A%20%20%20%20PLL_ARM_CLR%20%20%20%20%20%20%20%200x80002064%20%20%20%20%0A%20%20%20%20PLL_ARM_TOG%20%20%20%20%20%20%20%200x80002064%20%20%20%20%0A%20%20%20%20PLL_USB1%20%20%20%20%20%20%20%20%20%20%200x80003000%20%20%20%20%0A%20%20%20%20PLL_USB1_SET%20%20%20%20%20%20%200x80003000%20%20%20%20%0A%20%20%20%20PLL_USB1_CLR%20%20%20%20%20%20%200x80003000%20%20%20%20%0A%20%20%20%20PLL_USB1_TOG%20%20%20%20%20%20%200x80003000%20%20%20%20%0A%20%20%20%20PLL_USB2%20%20%20%20%20%20%20%20%20%20%200x00012000%20%20%20%20%0A%20%20%20%20PLL_USB2_SET%20%20%20%20%20%20%200x00012000%20%20%20%20%0A%20%20%20%20PLL_USB2_CLR%20%20%20%20%20%20%200x00012000%20%20%20%20%0A%20%20%20%20PLL_USB2_TOG%20%20%20%20%20%20%200x00012000%20%20%20%20%0A%20%20%20%20PLL_SYS%20%20%20%20%20%20%20%20%20%20%20%200x80002001%20%20%20%20%0A%20%20%20%20PLL_SYS_SET%20%20%20%20%20%20%20%200x80002001%20%20%20%20%0A%20%20%20%20PLL_SYS_CLR%20%20%20%20%20%20%20%200x80002001%20%20%20%20%0A%20%20%20%20PLL_SYS_TOG%20%20%20%20%20%20%20%200x80002001%20%20%20%20%0A%20%20%20%20PLL_SYS_SS%20%20%20%20%20%20%20%20%200x00000000%20%20%20%20%0A%20%20%20%20PLL_SYS_NUM%20%20%20%20%20%20%20%200x00000000%20%20%20%20%0A%20%20%20%20PLL_SYS_DENOM%20%20%20%20%20%200x00000012%20%20%20%20%0A%20%20%20%20PLL_AUDIO%20%20%20%20%20%20%20%20%20%200x00011006%20%20%20%20%0A%20%20%20%20PLL_AUDIO_SET%20%20%20%20%20%200x00011006%20%20%20%20%0A%20%20%20%20PLL_AUDIO_CLR%20%20%20%20%20%200x00011006%20%20%20%20%0A%20%20%20%20PLL_AUDIO_TOG%20%20%20%20%20%200x00011006%20%20%20%20%0A%20%20%20%20PLL_AUDIO_NUM%20%20%20%20%20%200x05f5e100%20%20%20%20%0A%20%20%20%20PLL_AUDIO_DENOM%20%20%20%200x2964619c%20%20%20%20%0A%20%20%20%20PLL_VIDEO%20%20%20%20%20%20%20%20%20%200x0001100c%20%20%20%20%0A%20%20%20%20PLL_VIDEO_SET%20%20%20%20%20%200x0001100c%20%20%20%20%0A%20%20%20%20PLL_VIDEO_CLR%20%20%20%20%20%200x0001100c%20%20%20%20%0A%20%20%20%20PLL_VIDEO_TOG%20%20%20%20%20%200x0001100c%20%20%20%20%0A%20%20%20%20PLL_VIDEO_NUM%20%20%20%20%20%200x05f5e100%20%20%20%20%0A%20%20%20%20PLL_VIDEO_DENOM%20%20%20%200x10a24447%20%20%20%20%0A%20%20%20%20PLL_ENET%20%20%20%20%20%20%20%20%20%20%200x00011005%20%20%20%20%0A%20%20%20%20PLL_ENET_SET%20%20%20%20%20%20%200x00011005%20%20%20%20%0A%20%20%20%20PLL_ENET_CLR%20%20%20%20%20%20%200x00011005%20%20%20%20%0A%20%20%20%20PLL_ENET_TOG%20%20%20%20%20%20%200x00011005%20%20%20%20%0A%20%20%20%20PFD_480%20%20%20%20%20%20%20%20%20%20%20%200x0f1a234c%20%20%20%20%0A%20%20%20%20PFD_480_SET%20%20%20%20%20%20%20%200x0f1a234c%20%20%20%20%0A%20%20%20%20PFD_480_CLR%20%20%20%20%20%20%20%200x0f1a234c%20%20%20%20%0A%20%20%20%20PFD_480_TOG%20%20%20%20%20%20%20%200x0f1a234c%20%20%20%20%0A%20%20%20%20PFD_528%20%20%20%20%20%20%20%20%20%20%20%200x405d4040%20%20%20%20%0A%20%20%20%20PFD_528_SET%20%20%20%20%20%20%20%200x405d4040%20%20%20%20%0A%20%20%20%20PFD_528_CLR%20%20%20%20%20%20%20%200x405d4040%20%20%20%20%0A%20%20%20%20PFD_528_TOG%20%20%20%20%20%20%20%200x405d4040%20%20%20%20%0A%20%20%20%20MISC0%20%20%20%20%20%20%20%20%20%20%20%20%20%200x24008080%20%20%20%20%0A%20%20%20%20MISC0_SET%20%20%20%20%20%20%20%20%20%200x24008080%20%20%20%20%0A%20%20%20%20MISC0_CLR%20%20%20%20%20%20%20%20%20%200x24008080%20%20%20%20%0A%20%20%20%20MISC0_TOG%20%20%20%20%20%20%20%20%20%200x24008080%20%20%20%20%0A%20%20%20%20MISC1%20%20%20%20%20%20%20%20%20%20%20%20%20%200x80030000%20%20%20%20%0A%20%20%20%20MISC1_SET%20%20%20%20%20%20%20%20%20%200x80030000%20%20%20%20%0A%20%20%20%20MISC1_CLR%20%20%20%20%20%20%20%20%20%200x80030000%20%20%20%20%0A%20%20%20%20MISC1_TOG%20%20%20%20%20%20%20%20%20%200x80030000%20%20%20%20%0A%20%20%20%20MISC2%20%20%20%20%20%20%20%20%20%20%20%20%20%200x002f272f%20%20%20%20%0A%20%20%20%20MISC2_SET%20%20%20%20%20%20%20%20%20%200x002f272f%20%20%20%20%0A%20%20%20%20MISC2_CLR%20%20%20%20%20%20%20%20%20%200x002f272f%20%20%20%20%0A%20%20%20%20MISC2_TOG%20%20%20%20%20%20%20%20%20%200x002f272f%20%20%20%20%3C%2FSTRUCT%3E%3C%2FSTRUCT%3E%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3CP%3E%E5%A6%82%E6%9E%9C%E6%9C%89%E5%85%B6%E4%BB%96%E6%9C%89%E5%8A%A9%E4%BA%8E%E8%B0%83%E8%AF%95%E9%97%AE%E9%A2%98%E7%9A%84%E4%BF%A1%E6%81%AF%EF%BC%8C%E8%AF%B7%E5%91%8A%E8%AF%89%E6%88%91%E3%80%82%E6%88%91%E6%9C%89%E5%B8%A6%E6%9C%89%20NVCC_PLL%20%E7%94%B5%E5%AE%B9%E7%9A%84%E6%96%B0%E6%9D%BF%E6%89%80%E4%BB%A5%E6%88%91%E5%B0%B1%E8%83%BD%E7%94%A8%E5%AE%83%E6%9D%A5%E6%B5%8B%E8%AF%95%E4%BA%86%E3%80%82%E6%88%91%E5%8F%AA%E6%98%AF%E8%A7%89%E5%BE%97%E5%A5%87%E6%80%AA%EF%BC%8CLCDIF%20%E4%BC%BC%E4%B9%8E%E6%98%AF%E5%94%AF%E4%B8%80%E5%8F%97%E5%BD%B1%E5%93%8D%E7%9A%84%E6%A8%A1%E5%9D%97%E3%80%82%E5%86%8D%E6%AC%A1%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%B8%AE%E5%8A%A9%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E
