RT1062 GT24C1024 EEPROM Write/Read Example code
Tony512JK
Hi:
           Do NXP have the GT24C1024 EEPROM Write/Read Example code?
Thanks a lot
Tony
Tony512JK
Hi Raul:
             I already implement this function.
              Thanks for your help!
Thanks a lot
Tony
RaRo
Hello @Tony512JK,
Unfortunately, there is not an example code for write/read the GT24C1024 EEPROM.
Nonetheless, you could use the I2C SDK´s examples as a starting point for your EEPROM implementation as GT24C1024 serial interface supports I2C communication.
Sorry for any inconvenient this may cause you.
Best regards, Raul.
