Quadrature Encoder Velocity Measurement
RegulaTor
I am trying to figure out how to use a timer to improve low speed quadrature encoder measurements on i.MX RT1060. I can see in the reference manual (55.4.2 Prescaler for Slow or Fast Speed Measurement) that there should be some support for low speed measurements using a timer. However, I am having a hard time understanding how I can set this up? Are the some examples since this was posted?
If not could you provide a brief explanation of what I need to do? Does the ENC have its own timer or should I setup a separate timer?  What are the steps for setting up such a timer?
Thanks!
Tor
Kan_Li
Hello @RegulaTor ,
Yes, we have such kind of demo but it is just internal used, would you please raise a private case for it? Please kindly refer to https://www.nxp.com/video/tutorial-for-nxp-support-case-portal:NCP-VIDEO for details.
Kan
Kan_Li
Hello @RegulaTor ,
Kan
RegulaTor
Hi @Kan_Li ,
Thank you I have made a support case with the same title as this one.
Tor
%3CLINGO-SUB%20id%3D%22lingo-sub-2194405%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EQuadrature%20Encoder%20Velocity%20Measurement%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2194405%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%3CP%3EI%20am%20trying%20to%20figure%20out%20how%20to%20use%20a%20timer%20to%20improve%20low%20speed%20quadrature%20encoder%20measurements%20on%20i.MX%20RT1060.%20I%20can%20see%20in%20the%20reference%20manual%20(55.4.2%20Prescaler%20for%20Slow%20or%20Fast%20Speed%20Measurement)%20that%20there%20should%20be%20some%20support%20for%20low%20speed%20measurements%20using%20a%20timer.%20However%2C%20I%20am%20having%20a%20hard%20time%20understanding%20how%20I%20can%20set%20this%20up%3F%20Are%20the%20some%20examples%20since%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-RT-Crossover-MCUs%2FQuadrature-Encoder-speed-measurement%2Fm-p%2F1681289%22%20target%3D%22_self%22%3Ethis%20was%20posted%3C%2FA%3E%3F%3C%2FP%3E%3CP%3EIf%20not%20could%20you%20provide%20a%20brief%20explanation%20of%20what%20I%20need%20to%20do%3F%20Does%20the%20ENC%20have%20its%20own%20timer%20or%20should%20I%20setup%20a%20separate%20timer%3F%26nbsp%3B%20What%20are%20the%20steps%20for%20setting%20up%20such%20a%20timer%3F%3C%2FP%3E%3CP%3EThanks!%3C%2FP%3E%3CP%3EBest%20regards%2C%3C%2FP%3E%3CP%3ETor%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2194405%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3Ei.MXRT%20106x%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2195531%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Quadrature%20Encoder%20Velocity%20Measurement%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2195531%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F59276%22%20target%3D%22_blank%22%3E%40Kan_Li%3C%2FA%3E%26nbsp%3B%2C%3C%2FP%3E%3CP%3EThank%20you%20I%20have%20made%20a%20support%20case%20with%20the%20same%20title%20as%20this%20one.%3C%2FP%3E%3CP%3EBest%20regards%2C%3C%2FP%3E%3CP%3ETor%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2194974%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Quadrature%20Encoder%20Velocity%20Measurement%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2194974%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F256251%22%20target%3D%22_blank%22%3E%40RegulaTor%3C%2FA%3E%26nbsp%3B%2C%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EYes%2C%20we%20have%20such%20kind%20of%20demo%20but%20it%20is%20just%20internal%20used%2C%20would%20you%20please%20raise%20a%20private%20case%20for%20it%3F%20Please%20kindly%20refer%20to%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fvideo%2Ftutorial-for-nxp-support-case-portal%3ANCP-VIDEO%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fwww.nxp.com%2Fvideo%2Ftutorial-for-nxp-support-case-portal%3ANCP-VIDEO%3C%2FA%3E%26nbsp%3Bfor%20details.%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EHave%20a%20great%20day%2C%3CBR%20%2F%3EKan%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3E-------------------------------------------------------------------------------%3CBR%20%2F%3ENote%3A%3CBR%20%2F%3E-%20If%20this%20post%20answers%20your%20question%2C%20please%20click%20the%20%22Mark%20Correct%22%20button.%20Thank%20you!%3CBR%20%2F%3E-%20We%20are%20following%20threads%20for%207%20weeks%20after%20the%20last%20post%2C%20later%20replies%20are%20ignored%3CBR%20%2F%3EPlease%20open%20a%20new%20thread%20and%20refer%20to%20the%20closed%20one%2C%20if%20you%20have%20a%20related%20question%20at%20a%20later%20point%20in%20time.%3CBR%20%2F%3E-------------------------------------------------------------------------------%3C%2FP%3E%3C%2FLINGO-BODY%3E
