QSPI in MXRT1064 flash_component_nor project.
max3
I was just wondering how to enable QSPI in the 1064 sdk's flash_component_nor example project. Trying to call FLEXSPI_NOR_EnableQuadMode results in the processor hanging in the quad to enable function on the FLEXSPI_UpdateLUT line, specifically the FLEXSPI_GetBusIdleStatus call.
Maxwell Kunes
jeremyzhou
Hi Maxwell Kunes,
Thank you for your interest in NXP Semiconductor products and
for the opportunity to serve you.
I think I need more details about the issue, so whether you can describe what code modification you did about the flash_component_nor example, and list the testing procedure.
Then I can replicate the issue on my site.
Looking forward to your reply.
TIC
