MIMXRT1180 how to output a pwm signal on the pin M16 - GPIO_AD_27
2,289 次查看
silvio-vallorani
Hi guys,
I have a MIMXRT1189CVM8C.
I am not able to output a simple PWM signal from the pin M16 - GPIO_AD_27.
I have attached the screenshots of the MCUXpresso Config Tool which I set.
Can someone help me, please?
标记 (2)
4 回复数
2,138 次查看
silvio-vallorani
My new related question is about a function I need to implement, but I can't figure out how to do it cleanly and possibly totally in hardware.
I have a periodic square signal generated by my application.
I need to generate a new periodic square signal that is 8 time more fast and that perfectly sync with the signal above, every it's rise edge.
In the Reference Manual I saw this block diagram:
However, going into more detail about the behavior of PWM_EXT_SYNC I found this block diagram:
It seems that the PWM peripheral is unable to simultaneously generate the PWM signal and synchronize with the external signal, is this true?
Can you help me to find a good solution for my needs?
Thank you very much,
Silvio
1,878 次查看
mayliu1
Hi @silvio-vallorani ,
Q: It seems that the PWM peripheral is unable to simultaneously generate the PWM signal and synchronize with the external signal, is this true?
A: The FlexPWM module on i.MX RT1180 can simultaneously generate PWM outputs and synchronize its counter to an external signal.
For more detailed information, I suggest you can refer to this Application Note : AN14196: Flex Pulse Width Modulator (FlexPWM) Usage on MCX N Series | NXP Semiconductors,
especially Section 3.2.2 “Counter Synchronization”, which describes how the FlexPWM counter can be synchronized across modules or via external sources.
Best Regards
MayLiu
2,138 次查看
silvio-vallorani
Thank you @mayliu1 for your reply. I found the problem, it was related to the "fault disable" signals. I tryed to disable the beahviour that involve faults, using the "MCUX Config Tool" is not possible: if I uncheck all the "fault disable" signals, the generated code totally remove the PWM_SetupFaultDisableMap() call and the "fault disable map" register stay to it's all enabled by default. I think this is a buggy beahviour of the tool, beacouse if I uncheck all the "fault disable" signals from the tool and then I manually add the PWM_SetupFaultDisableMap() call with "0" as the mask, I obtain the expected behaviour.
Anyway, on my code I finally leave enabled all the "fault disable" signals and I added XBAR signals to route "InputLogicHigh" on "Flexpwm2Faultx" signals and that's works fine.
Now I have a new question, but I ask it as a separate message below.
2,219 次查看
mayliu1
Thank you so much for your interest in our products and for using our community.
I suggest you can refer to SDK demo "evkmimxrt1180_pwm_cm33".
1: Pin Configuration :
In MCUXpresso Config Tools, set pin M16 (GPIO_AD_27) to function as PWM2_B (submodule 1).
2: Add PWM Initialization Code
Follow the SDK demo for PWM setup. The demo project uses PWM1 submodule 0, submodule 1, and submodule 2 to generate waveforms.
You can adapt the same method for PWM2 Submodule 1.
Best Regards
MayLiu
%3CLINGO-SUB%20id%3D%22lingo-sub-2270005%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EMIMXRT1180%20%E5%A6%82%E4%BD%95%E5%9C%A8%E5%BC%95%E8%84%9A%20M16%20-%20GPIO_AD_27%20%E4%B8%8A%E8%BE%93%E5%87%BA%20pwm%20%E4%BF%A1%E5%8F%B7%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2270005%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E4%BB%AC%E5%A5%BD%20%3C%2FP%3E%3CP%3E%E6%88%91%E6%9C%89%E4%B8%80%E5%8F%B0%20MIMXRT1189CVM8C%E3%80%82%3CBR%20%2F%3E%E6%88%91%E6%97%A0%E6%B3%95%E4%BB%8E%E5%BC%95%E8%84%9A%20M16%20-%20GPIO_AD_27%20%E8%BE%93%E5%87%BA%E7%AE%80%E5%8D%95%E7%9A%84%20PWM%20%E4%BF%A1%E5%8F%B7%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E9%99%84%E4%B8%8A%E4%BA%86%E6%88%91%E8%AE%BE%E7%BD%AE%E7%9A%84%20MCUXpresso%20%E9%85%8D%E7%BD%AE%E5%B7%A5%E5%85%B7%E7%9A%84%E6%88%AA%E5%9B%BE%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E8%B0%81%E8%83%BD%E5%B8%AE%E5%B8%AE%E6%88%91%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2270387%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MIMXRT1180%20how%20to%20output%20a%20pwm%20signal%20on%20the%20pin%20M16%20-%20GPIO_AD_27%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2270387%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F252871%22%20target%3D%22_blank%22%3E%40silvio-vallorani%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CP%3E%E9%9D%9E%E5%B8%B8%E6%84%9F%E8%B0%A2%E6%82%A8%E5%85%B3%E6%B3%A8%E6%88%91%E4%BB%AC%E7%9A%84%E4%BA%A7%E5%93%81%E5%B9%B6%E4%BD%BF%E7%94%A8%E6%88%91%E4%BB%AC%E7%9A%84%E7%A4%BE%E5%8C%BA%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%88%91%E5%BB%BA%E8%AE%AE%E6%82%A8%E5%8F%82%E8%80%83%20SDK%20%E6%BC%94%E7%A4%BA%22evkmimxrt1180_pwm_cm33%22%20%E3%80%82%3C%2FP%3E%0A%3CP%3E1%3A%20%E5%BC%95%E8%84%9A%E9%85%8D%E7%BD%AE%20%EF%BC%9A%3C%2FP%3E%0A%3CP%3E%E5%9C%A8%20MCUXpresso%20%E9%85%8D%E7%BD%AE%E5%B7%A5%E5%85%B7%E4%B8%AD%EF%BC%8C%E5%B0%86%E5%BC%95%E8%84%9A%20M16%EF%BC%88GPIO_AD_27%EF%BC%89%E8%AE%BE%E7%BD%AE%E4%B8%BA%20PWM2_B%EF%BC%88%E5%AD%90%E6%A8%A1%E5%9D%97%201%EF%BC%89%E3%80%82%3C%2FP%3E%0A%3CP%3E2%3A%20%E6%B7%BB%E5%8A%A0%20PWM%20%E5%88%9D%E5%A7%8B%E5%8C%96%E4%BB%A3%E7%A0%81%3C%2FP%3E%0A%3CDIV%3E%E6%8C%89%E7%85%A7%20SDK%20%E6%BC%94%E7%A4%BA%E8%BF%9B%E8%A1%8C%20PWM%20%E8%AE%BE%E7%BD%AE%E3%80%82%E6%BC%94%E7%A4%BA%E9%A1%B9%E7%9B%AE%E4%BD%BF%E7%94%A8%20PWM1%20%E5%AD%90%E6%A8%A1%E5%9D%97%200%E3%80%81%E5%AD%90%E6%A8%A1%E5%9D%97%201%20%E5%92%8C%E5%AD%90%E6%A8%A1%E5%9D%97%202%20%E7%94%9F%E6%88%90%E6%B3%A2%E5%BD%A2%E3%80%82%3CBR%20%2F%3E%E5%90%8C%E6%A0%B7%E7%9A%84%E6%96%B9%E6%B3%95%E4%B9%9F%E9%80%82%E7%94%A8%E4%BA%8E%20PWM2%20%E5%AD%90%E6%A8%A1%E5%9D%97%201%E3%80%82%3C%2FDIV%3E%0A%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%0A%3CDIV%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FDIV%3E%0A%3CDIV%3EMayLiu%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2270672%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MIMXRT1180%20how%20to%20output%20a%20pwm%20signal%20on%20the%20pin%20M16%20-%20GPIO_AD_27%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2270672%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E7%9A%84%E6%96%B0%E7%9B%B8%E5%85%B3%E9%97%AE%E9%A2%98%E6%98%AF%E5%85%B3%E4%BA%8E%E6%88%91%E9%9C%80%E8%A6%81%E5%AE%9E%E7%8E%B0%E7%9A%84%E4%B8%80%E4%B8%AA%E5%8A%9F%E8%83%BD%EF%BC%8C%E4%BD%86%E6%88%91%E4%B8%8D%E7%9F%A5%E9%81%93%E5%A6%82%E4%BD%95%E5%B9%B2%E5%87%80%E5%88%A9%E8%90%BD%E5%9C%B0%E5%AE%9E%E7%8E%B0%E5%AE%83%EF%BC%8C%E8%80%8C%E4%B8%94%E5%8F%AF%E8%83%BD%E5%AE%8C%E5%85%A8%E7%94%A8%E7%A1%AC%E4%BB%B6%E5%AE%9E%E7%8E%B0%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E7%9A%84%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E4%BA%A7%E7%94%9F%E4%BA%86%E4%B8%80%E4%B8%AA%E5%91%A8%E6%9C%9F%E6%80%A7%E6%96%B9%E6%B3%A2%E4%BF%A1%E5%8F%B7%E3%80%82%3CBR%20%2F%3E%E6%88%91%E9%9C%80%E8%A6%81%E7%94%9F%E6%88%90%E4%B8%80%E4%B8%AA%E6%96%B0%E7%9A%84%E5%91%A8%E6%9C%9F%E6%80%A7%E6%96%B9%E6%B3%A2%E4%BF%A1%E5%8F%B7%EF%BC%8C%E5%AE%83%E7%9A%84%E9%80%9F%E5%BA%A6%E8%A6%81%E5%BF%AB%208%20%E5%80%8D%EF%BC%8C%E5%B9%B6%E4%B8%94%E5%9C%A8%E6%AF%8F%E4%B8%AA%E4%B8%8A%E5%8D%87%E6%B2%BF%E9%83%BD%E4%B8%8E%E4%B8%8A%E8%BF%B0%E4%BF%A1%E5%8F%B7%E5%AE%8C%E5%85%A8%E5%90%8C%E6%AD%A5%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-center%22%20image-alt%3D%22wavedrom.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22wavedrom.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22wavedrom.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22wavedrom.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F371604i808820953C200D1B%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22wavedrom.png%22%20alt%3D%22wavedrom.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E5%9C%A8%E5%8F%82%E8%80%83%E6%89%8B%E5%86%8C%E4%B8%AD%EF%BC%8C%E6%88%91%E7%9C%8B%E5%88%B0%E4%BA%86%E8%BF%99%E4%B8%AA%E6%96%B9%E6%A1%86%E5%9B%BE%EF%BC%9A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-center%22%20image-alt%3D%22rm1.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22rm1.png%22%20style%3D%22width%3A%20856px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22rm1.png%22%20style%3D%22width%3A%20856px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22rm1.png%22%20style%3D%22width%3A%20856px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F371605i801F2BCE21E76ED2%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22rm1.png%22%20alt%3D%22rm1.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E4%B8%8D%E8%BF%87%EF%BC%8C%E4%B8%BA%E4%BA%86%E6%9B%B4%E8%AF%A6%E7%BB%86%E5%9C%B0%E4%BA%86%E8%A7%A3%20PWM_EXT_SYNC%20%E7%9A%84%E8%A1%8C%E4%B8%BA%EF%BC%8C%E6%88%91%E6%89%BE%E5%88%B0%E4%BA%86%E8%BF%99%E4%B8%AA%E6%A1%86%E5%9B%BE%EF%BC%9A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-center%22%20image-alt%3D%22rm2.png%22%20style%3D%22width%3A%20859px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22rm2.png%22%20style%3D%22width%3A%20859px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22rm2.png%22%20style%3D%22width%3A%20859px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22rm2.png%22%20style%3D%22width%3A%20859px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F371606i03F41AD9FD08FB31%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22rm2.png%22%20alt%3D%22rm2.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%E7%9C%8B%E6%9D%A5%20PWM%20%E5%A4%96%E8%AE%BE%E6%97%A0%E6%B3%95%E5%90%8C%E6%97%B6%E4%BA%A7%E7%94%9F%20PWM%20%E4%BF%A1%E5%8F%B7%E5%B9%B6%E4%B8%8E%E5%A4%96%E9%83%A8%E4%BF%A1%E5%8F%B7%E5%90%8C%E6%AD%A5%EF%BC%8C%E6%98%AF%E8%BF%99%E6%A0%B7%E5%90%97%EF%BC%9F%3C%2FP%3E%3CP%3E%E6%82%A8%E8%83%BD%E5%B8%AE%E6%88%91%E6%89%BE%E5%88%B0%E6%BB%A1%E8%B6%B3%E6%88%91%E9%9C%80%E6%B1%82%E7%9A%84%E5%A5%BD%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%E5%90%97%EF%BC%9F%3C%2FP%3E%3CP%3E%E9%9D%9E%E5%B8%B8%E6%84%9F%E8%B0%A2%E3%80%81%3C%2FP%3E%3CP%3E%E8%A5%BF%E5%B0%94%E7%BB%B4%E5%A5%A5%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2270662%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MIMXRT1180%20how%20to%20output%20a%20pwm%20signal%20on%20the%20pin%20M16%20-%20GPIO_AD_27%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2270662%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3E%E6%84%9F%E8%B0%A2%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F239163%22%20target%3D%22_blank%22%3E%40mayliu1%3C%2FA%3E%E7%9A%84%E5%9B%9E%E5%A4%8D%E3%80%82%E6%88%91%E6%89%BE%E5%88%B0%E4%BA%86%E9%97%AE%E9%A2%98%E6%89%80%E5%9C%A8%EF%BC%8C%E5%AE%83%E4%B8%8E%22%E6%95%85%E9%9A%9C%E7%A6%81%E7%94%A8%22%20%E4%BF%A1%E5%8F%B7%E6%9C%89%E5%85%B3%E3%80%82%E6%88%91%E5%B0%9D%E8%AF%95%E4%BD%BF%E7%94%A8%22MCUX%20%E9%85%8D%E7%BD%AE%E5%B7%A5%E5%85%B7%22%20%E6%9D%A5%E7%A6%81%E7%94%A8%E6%B6%89%E5%8F%8A%E5%88%B0%E6%95%85%E9%9A%9C%E7%9A%84%E9%83%A8%E5%88%86%EF%BC%8C%E4%BD%86%E8%BF%99%E6%98%AF%E4%B8%8D%E5%8F%AF%E8%83%BD%E7%9A%84%EF%BC%9A%E5%A6%82%E6%9E%9C%E6%88%91%E5%8F%96%E6%B6%88%E9%80%89%E4%B8%AD%E6%89%80%E6%9C%89%22%E6%95%85%E9%9A%9C%E7%A6%81%E7%94%A8%22%20%E4%BF%A1%E5%8F%B7%EF%BC%8C%E7%94%9F%E6%88%90%E7%9A%84%E4%BB%A3%E7%A0%81%E4%BC%9A%E5%AE%8C%E5%85%A8%E5%88%A0%E9%99%A4%20PWM_SetupFaultDisableMap()%E8%B0%83%E7%94%A8%EF%BC%8C%E8%80%8C%22%E6%95%85%E9%9A%9C%E7%A6%81%E7%94%A8%E6%98%A0%E5%B0%84%22%20%E5%AF%84%E5%AD%98%E5%99%A8%E4%BC%9A%E4%BF%9D%E6%8C%81%E9%BB%98%E8%AE%A4%E7%9A%84%E5%85%A8%E9%83%A8%E5%90%AF%E7%94%A8%E7%8A%B6%E6%80%81%E3%80%82%E6%88%91%E8%AE%A4%E4%B8%BA%E8%BF%99%E6%98%AF%E5%B7%A5%E5%85%B7%E7%9A%84%E4%B8%80%E4%B8%AA%E9%94%99%E8%AF%AF%EF%BC%8C%E5%9B%A0%E4%B8%BA%E5%A6%82%E6%9E%9C%E6%88%91%E4%BB%8E%E5%B7%A5%E5%85%B7%E4%B8%AD%E5%8F%96%E6%B6%88%E9%80%89%E4%B8%AD%E6%89%80%E6%9C%89%22%E6%95%85%E9%9A%9C%E7%A6%81%E7%94%A8%22%20%E4%BF%A1%E5%8F%B7%EF%BC%8C%E7%84%B6%E5%90%8E%E6%89%8B%E5%8A%A8%E6%B7%BB%E5%8A%A0%20PWM_SetupFaultDisableMap()%20%E8%B0%83%E7%94%A8%EF%BC%8C%E5%B9%B6%E5%B0%86%220%22%20%E4%BD%9C%E4%B8%BA%E6%8E%A9%E7%A0%81%EF%BC%8C%E5%B0%B1%E4%BC%9A%E5%BE%97%E5%88%B0%E9%A2%84%E6%9C%9F%E7%9A%84%E8%A1%8C%E4%B8%BA%E3%80%82%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%3E%E6%80%BB%E4%B9%8B%EF%BC%8C%E5%9C%A8%E6%88%91%E7%9A%84%E4%BB%A3%E7%A0%81%E4%B8%AD%EF%BC%8C%E6%88%91%E6%9C%80%E7%BB%88%E5%90%AF%E7%94%A8%E4%BA%86%E6%89%80%E6%9C%89%22%E6%95%85%E9%9A%9C%E7%A6%81%E7%94%A8%22%20%E4%BF%A1%E5%8F%B7%EF%BC%8C%E5%B9%B6%E5%9C%A8%22Flexpwm2Faultx%22%20%E4%BF%A1%E5%8F%B7%E4%B8%8A%E6%B7%BB%E5%8A%A0%E4%BA%86%20XBAR%20%E4%BF%A1%E5%8F%B7%EF%BC%8C%E8%B7%AF%E7%94%B1%22InputLogicHigh%22%20%EF%BC%8C%E8%BF%99%E6%A0%B7%E5%B0%B1%E5%8F%AF%E4%BB%A5%E6%AD%A3%E5%B8%B8%E5%B7%A5%E4%BD%9C%E4%BA%86%E3%80%82%3C%2FSPAN%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%3E%E7%8E%B0%E5%9C%A8%E6%88%91%E6%9C%89%E4%B8%80%E4%B8%AA%E6%96%B0%E9%97%AE%E9%A2%98%EF%BC%8C%E4%BD%86%E6%88%91%E4%BC%9A%E5%9C%A8%E4%B8%8B%E9%9D%A2%E5%8D%95%E7%8B%AC%E7%95%99%E8%A8%80%E6%8F%90%E5%87%BA%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2289090%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MIMXRT1180%20how%20to%20output%20a%20pwm%20signal%20on%20the%20pin%20M16%20-%20GPIO_AD_27%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2289090%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F252871%22%20target%3D%22_blank%22%3E%40silvio-vallorani%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E6%8F%90%E4%BE%9B%E7%9A%84%E6%9C%80%E6%96%B0%E4%BF%A1%E6%81%AF%E3%80%82%3C%2FP%3E%0A%3CDIV%3E%E9%97%AE%EF%BC%9APWM%20%E5%A4%96%E8%AE%BE%E4%BC%BC%E4%B9%8E%E6%97%A0%E6%B3%95%E5%90%8C%E6%97%B6%E4%BA%A7%E7%94%9F%20PWM%20%E4%BF%A1%E5%8F%B7%E5%B9%B6%E4%B8%8E%E5%A4%96%E9%83%A8%E4%BF%A1%E5%8F%B7%E5%90%8C%E6%AD%A5%EF%BC%8C%E6%98%AF%E8%BF%99%E6%A0%B7%E5%90%97%EF%BC%9F%3C%2FDIV%3E%0A%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%0A%3CDIV%3E%E7%AD%94%EF%BC%9A%3CSPAN%3Ei.MX%20RT1180%20%E4%B8%8A%E7%9A%84%20FlexPWM%20%E6%A8%A1%E5%9D%97%E5%8F%AF%E5%90%8C%E6%97%B6%E4%BA%A7%E7%94%9F%20PWM%20%E8%BE%93%E5%87%BA%EF%BC%8C%E5%B9%B6%E5%B0%86%E5%85%B6%E8%AE%A1%E6%95%B0%E5%99%A8%E4%B8%8E%E5%A4%96%E9%83%A8%E4%BF%A1%E5%8F%B7%E5%90%8C%E6%AD%A5%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%3E%0A%3CDIV%3E%0A%3CP%3E%E6%AC%B2%E4%BA%86%E8%A7%A3%E6%9B%B4%E5%A4%9A%E8%AF%A6%E7%BB%86%E4%BF%A1%E6%81%AF%EF%BC%8C%E6%88%91%E5%BB%BA%E8%AE%AE%E4%BD%A0%E5%8F%AF%E4%BB%A5%E5%8F%82%E8%80%83%E6%9C%AC%E5%BA%94%E7%94%A8%E7%AC%94%E8%AE%B0%EF%BC%9A%3CA%20href%3D%22https%3A%2F%2Fdocs.nxp.com%2Fbundle%2FAN14196%2Fpage%2Ftopics%2Fcounter_synchronization.html%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EAN14196%EF%BC%9A%E6%9F%94%E6%80%A7%E8%84%89%E5%86%B2%E5%AE%BD%E5%BA%A6%E8%B0%83%E5%88%B6%E5%99%A8%20(flexPWM)%20%E5%9C%A8%20MCX%20N%20%E7%B3%BB%E5%88%97%E4%B8%8A%E7%9A%84%E7%94%A8%E6%B3%95%3C%2FA%3E%20%7C%20%E6%81%A9%E6%99%BA%E6%B5%A6%E5%8D%8A%E5%AF%BC%E4%BD%93%EF%BC%8C%3C%2FP%3E%0A%3CP%3E%E7%89%B9%E5%88%AB%E6%98%AF%E7%AC%AC%203.2.2%20%E8%8A%82%22%E8%AE%A1%E6%95%B0%E5%99%A8%E5%90%8C%E6%AD%A5%22%EF%BC%8C%E4%BB%8B%E7%BB%8D%E5%A6%82%E4%BD%95%E8%B7%A8%E6%A8%A1%E5%9D%97%E6%88%96%E9%80%9A%E8%BF%87%E5%A4%96%E9%83%A8%E6%BA%90%E5%90%8C%E6%AD%A5%20FlexPWM%20%E8%AE%A1%E6%95%B0%E5%99%A8%E3%80%82%3C%2FP%3E%0A%3C%2FDIV%3E%0A%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22mayliu1_0-1767758992316.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22mayliu1_0-1767758992316.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F371919i53DAB8BB72F723D8%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22mayliu1_0-1767758992316.png%22%20alt%3D%22mayliu1_0-1767758992316.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%0A%3CBR%20%2F%3E%0A%3C%2FDIV%3E%0A%3CDIV%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FDIV%3E%0A%3CDIV%3EMayLiu%3C%2FDIV%3E%3C%2FLINGO-BODY%3E
