MIMXRT1160 Unique ID eFuse
1,548 次查看
tbonkers
MIMXRT1160 has a 64-bit Unique ID fuse at 0x900-0x910. Can the value be used as device unique ID, or is it "unique" across processor/batches? If that's the case, is there another pre-programmed register or fuse which can be used as device unique ID?
1,445 次查看
mayliu1
Hi @tbonkers ,
Regarding "My requirement is to have an unique ID for each device, and I was thinking that it would be great if I can use the value of the fuse 0x900."
Are you saying that you used the value of fuse 0x900, a 32-bit data? If so, I don't think that's a good choice, 32-bit data is not unique .
But if you use the fuse values 0x900 and 0x910, the 64-bit data is unique (unique ID), which would be Okay.
Wish it helps you.
Best Regards
MayLiu
1,533 次查看
mayliu1
Hi @tbonkers ,
Thank you so much for your interest in our products and for using our community.
 Yes, IMXRT1160 has a 64-bit Unique ID which configuration  by NXP.
Regarding "If that's the case, is there another pre-programmed register or fuse which can be used as device unique ID?"
Could you tell me more details of your requirement?  In IMXRT1160 already provide a 64 bit  device unique ID fuse at 0x900-0x910.
Best Regards
MayLiu
1,471 次查看
tbonkers
From your response I understand that the value of the fuse is indeed unique for each unit - please correct me if I'm wrong.
1,446 次查看
mayliu1
Hi @tbonkers ,
Wish it helps you.
Best Regards
MayLiu
%3CLINGO-SUB%20id%3D%22lingo-sub-2149920%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EMIMXRT1160%20%E7%8B%AC%E7%89%B9%20ID%20%E7%94%B5%E5%AD%90%E4%BF%9D%E9%99%A9%E4%B8%9D%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2149920%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EMIMXRT1160%20%E5%9C%A8%200x900-0x910%20%E5%A4%84%E6%9C%89%E4%B8%80%E4%B8%AA%2064%20%E4%BD%8D%E7%9A%84%E5%94%AF%E4%B8%80%20ID%20%E7%86%94%E4%B8%9D%E3%80%82%E8%AF%A5%E5%80%BC%E5%8F%AF%E4%BB%A5%E7%94%A8%E4%BD%9C%E8%AE%BE%E5%A4%87%E5%94%AF%E4%B8%80%20ID%EF%BC%8C%E8%BF%98%E6%98%AF%E8%B7%A8%E5%A4%84%E7%90%86%E5%99%A8%2F%E6%89%B9%E6%AC%A1%E7%9A%84%20%22%20%E5%94%AF%E4%B8%80%20%22%EF%BC%9F%E5%A6%82%E6%9E%9C%E6%98%AF%E8%BF%99%E6%A0%B7%EF%BC%8C%E8%BF%98%E6%9C%89%E5%85%B6%E4%BB%96%E9%A2%84%E7%BC%96%E7%A8%8B%E7%9A%84%E5%AF%84%E5%AD%98%E5%99%A8%E6%88%96%E7%86%94%E4%B8%9D%E5%8F%AF%E7%94%A8%E4%BD%9C%E8%AE%BE%E5%A4%87%E5%94%AF%E4%B8%80ID%E5%90%97%EF%BC%9F%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2157419%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MIMXRT1160%20Unique%20ID%20eFuse%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2157419%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F183978%22%20target%3D%22_blank%22%3E%40tbonkers%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E6%8F%90%E4%BE%9B%E7%9A%84%E6%9C%80%E6%96%B0%E4%BF%A1%E6%81%AF%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%E5%85%B3%E4%BA%8E%20%22%20%E6%88%91%E7%9A%84%E8%A6%81%E6%B1%82%E6%98%AF%E4%B8%BA%E6%AF%8F%E5%8F%B0%E8%AE%BE%E5%A4%87%E9%83%BD%E6%9C%89%E4%B8%80%E4%B8%AA%E5%94%AF%E4%B8%80%E7%9A%84%20ID%EF%BC%8C%E6%88%91%E6%83%B3%E5%A6%82%E6%9E%9C%E6%88%91%E8%83%BD%E4%BD%BF%E7%94%A8%E7%86%94%E4%B8%9D%200x900%20%E7%9A%84%E5%80%BC%E9%82%A3%E5%B0%B1%E5%A4%AA%E5%A5%BD%E4%BA%86%E3%80%82%22%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E4%BD%A0%E6%98%AF%E8%AF%B4%E4%BD%A0%E4%BD%BF%E7%94%A8%E4%BA%86%E7%86%94%E4%B8%9D%200x900%20%E7%9A%84%E5%80%BC%EF%BC%8C%E4%B8%80%E4%B8%AA%2032%20%E4%BD%8D%E6%95%B0%E6%8D%AE%EF%BC%9F%E5%A6%82%E6%9E%9C%E6%98%AF%E8%BF%99%E6%A0%B7%EF%BC%8C%E6%88%91%E8%AE%A4%E4%B8%BA%E8%BF%99%E4%B8%8D%E6%98%AF%E4%B8%80%E4%B8%AA%E5%A5%BD%E7%9A%84%E9%80%89%E6%8B%A9%EF%BC%8C%E5%9B%A0%E4%B8%BA%2032%20%E4%BD%8D%E6%95%B0%E6%8D%AE%E5%B9%B6%E4%B8%8D%E6%98%AF%E5%94%AF%E4%B8%80%E7%9A%84%E3%80%82%20%3C%2FP%3E%0A%3CP%3E%E4%BD%86%E6%98%AF%EF%BC%8C%E5%A6%82%E6%9E%9C%E4%BD%A0%E4%BD%BF%E7%94%A8%E7%86%94%E4%B8%9D%E5%80%BC%200x900%20%E5%92%8C%200x910%EF%BC%8C%E9%82%A3%E4%B9%88%2064%20%E4%BD%8D%E6%95%B0%E6%8D%AE%E6%98%AF%E5%94%AF%E4%B8%80%E7%9A%84%EF%BC%88%E5%94%AF%E4%B8%80%20ID%EF%BC%89%EF%BC%8C%E9%82%A3%E5%B0%B1%E6%B2%A1%E9%97%AE%E9%A2%98%E4%BA%86%E3%80%82%3C%2FP%3E%0A%3CP%3E%E5%B8%8C%E6%9C%9B%E5%AE%83%E8%83%BD%E5%B8%AE%E5%88%B0%E4%BD%A0%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%95%AC%E4%B8%8A%3CBR%20%2F%3EMayLiu%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2156612%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MIMXRT1160%20Unique%20ID%20eFuse%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2156612%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%3CBR%20%2F%3E%E6%88%91%E7%9A%84%E8%A6%81%E6%B1%82%E6%98%AF%E4%B8%BA%E6%AF%8F%E5%8F%B0%E8%AE%BE%E5%A4%87%E9%83%BD%E6%9C%89%E4%B8%80%E4%B8%AA%E5%94%AF%E4%B8%80%E7%9A%84%20ID%EF%BC%8C%E6%88%91%E6%83%B3%E5%A6%82%E6%9E%9C%E6%88%91%E8%83%BD%E4%BD%BF%E7%94%A8%E7%86%94%E4%B8%9D%200x900%20%E7%9A%84%E5%80%BC%E9%82%A3%E5%B0%B1%E5%A4%AA%E5%A5%BD%E4%BA%86%E3%80%82%3CBR%20%2F%3E%E4%BB%8E%E4%BD%A0%E7%9A%84%E5%9B%9E%E5%A4%8D%E4%B8%AD%EF%BC%8C%E6%88%91%E4%BA%86%E8%A7%A3%E5%88%B0%E6%AF%8F%E4%B8%AA%E5%8D%95%E4%BD%8D%E7%9A%84%E7%86%94%E4%B8%9D%E5%80%BC%E7%A1%AE%E5%AE%9E%E6%98%AF%E5%94%AF%E4%B8%80%E7%9A%84-%E5%A6%82%E6%9E%9C%E6%88%91%E9%94%99%E4%BA%86%EF%BC%8C%E8%AF%B7%E7%BA%A0%E6%AD%A3%E6%88%91%E3%80%82%3CBR%20%2F%3E%E8%B0%A2%E8%B0%A2%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2150517%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MIMXRT1160%20Unique%20ID%20eFuse%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2150517%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F183978%22%20target%3D%22_blank%22%3E%40tbonkers%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CP%3E%E9%9D%9E%E5%B8%B8%E6%84%9F%E8%B0%A2%E6%82%A8%E5%85%B3%E6%B3%A8%E6%88%91%E4%BB%AC%E7%9A%84%E4%BA%A7%E5%93%81%E5%B9%B6%E4%BD%BF%E7%94%A8%E6%88%91%E4%BB%AC%E7%9A%84%E7%A4%BE%E5%8C%BA%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%98%AF%E7%9A%84%EF%BC%8C%3CSPAN%3EIMXRT1160%20%E5%85%B7%E6%9C%89%E6%81%A9%E6%99%BA%E6%B5%A6%E9%85%8D%E7%BD%AE%E7%9A%84%2064%20%E4%BD%8D%E5%94%AF%E4%B8%80%20ID%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22mayliu1_0-1754970106981.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22mayliu1_0-1754970106981.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F351903iB4655A5B87BA53D2%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22mayliu1_0-1754970106981.png%22%20alt%3D%22mayliu1_0-1754970106981.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E5%85%B3%E4%BA%8E%20%22%3CSPAN%3E%E5%A6%82%E6%9E%9C%E6%98%AF%E8%BF%99%E6%A0%B7%E7%9A%84%E8%AF%9D%EF%BC%8C%E8%BF%98%E6%9C%89%E5%85%B6%E4%BB%96%E9%A2%84%E7%BC%96%E7%A8%8B%E7%9A%84%E5%AF%84%E5%AD%98%E5%99%A8%E6%88%96%E7%86%94%E4%B8%9D%E5%8F%AF%E7%94%A8%E4%BD%9C%E8%AE%BE%E5%A4%87%E5%94%AF%E4%B8%80%20ID%20%E5%90%97%EF%BC%9F%3C%2FSPAN%3E%22%3C%2FP%3E%0A%3CP%3E%E8%83%BD%E5%90%A6%E5%91%8A%E8%AF%89%E6%88%91%E6%82%A8%E7%9A%84%E8%A6%81%E6%B1%82%E7%9A%84%E6%9B%B4%E5%A4%9A%E7%BB%86%E8%8A%82%EF%BC%9F%20%E5%9C%A8%20IMXRT1160%20%E4%B8%AD%EF%BC%8C%E5%B7%B2%E7%BB%8F%E5%9C%A8%20%3CSPAN%3E0x900-0x910%20%E5%A4%84%E6%8F%90%E4%BE%9B%E4%BA%86%E4%B8%80%E4%B8%AA%2064%20%E4%BD%8D%E8%AE%BE%E5%A4%87%E5%94%AF%E4%B8%80%20ID%20%E7%86%94%E4%B8%9D%3C%2FSPAN%3E%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22mayliu1_1-1754970965556.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22mayliu1_1-1754970965556.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F351909iB2132D088498774B%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22mayliu1_1-1754970965556.png%22%20alt%3D%22mayliu1_1-1754970965556.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EMayLiu%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
