MIMXRT1064 Debugging Specifically Designed Card
Lukas_Frank
Senior Contributor I
Hi Dear Authorized,
I am able to debug my EVK with PEMicro Multilink FX Debug Probe by using below directives:
1. 20 pin cable connected from PEmicro Multilink to J21 on the MIMXRT1064-EVK
2. SW7 configured as OFF-OFF-ON-OFF on the MIMXRT1064-EVK
3. J1 jumper set to 3-4 on the MIMXRT1064-EVK
4. Micro USB connected to J9 to provide voltage on the MIMXRT1064-EVK.
My Question:
Is there a specific requirement for debugging MIMXRT1064DVL6A MCU in specifically designed card?
We designed a micro computer by using MIMXRT1064DVL6A for our startup in university research lab. I am using 10-pin JTAG Connector same as J34 in EVK. The JTAG_TMS, JTAG_TCK, JTAG_TDI, JTAG_TDO, and JTAG_nTRST pins connected corresponding counterparts for JTAG PORT in MCU PINOUT Page in SPF-32221_A2.pdf.
I am not able to debug my card. MCUXpresso returns PEMicro Connection Assistant window. It says “An error occurred while connecting to the interface hardware or target specified in the Launch Configuration Dialog….”
Could you please help me about what kind of tricks should be considered in this scenario?
Thanks and Regards.
jernejturnsek
I think by default MIMXRT1064 is in SWD mode. For JTAG mode you need to reconfigure it.
Pavel_Hernandez
Hello, The recommendation is in the HDG and this thread.
https://www.nxp.com/webapp/Download?colCode=MIMXRT105060HDUG
Design Considerations for Debug - NXP Community
The windows that you mentioned are similar to the image below. If yes, the common cases are, because the connection is too long, does not have power [the universal multilink FX is the only one that can provide power], and the cable connection is the other way around.
Confirm that and tell me if the problem persists.
Pavel
Lukas_Frank
Hi Dear @Pavel_Hernandez ,
I have the same window with little difference, my second combobox holds “UMultilink Universal FX Rev B on USB1(Name=PEM)” instead “USB1: USB-ML-12 Rev C (PE5515143)”. I tried and checked the issue which you link. Unfortunately problem is still around.
I am continue for trials.
Do you know another board specific prerequisites which I should apply to my card?
Thanks and Regards.
Pavel_Hernandez
Hello, the recommendation is in the document of the hardware design guide, you need to be sure the MCU is botting as that mentioned.
Pavel
Lukas_Frank
I have reached the document Hardware Development Guide (MIMXRT105060HDUG) but I can’t find “hardware design guide”. Could please share the link?
Thanks and Regards.
Pavel_Hernandez
Hello, maybe this information could help you, in the search bar put MIMXRT105060HDUG this will find the document.
Pavel
Lukas_Frank
I already have the document MIMXRT105060HDUG but this is “hardware development guide”. Didn’t you mention “hardware design guide” ?
Thanks and Regards.
Pavel_Hernandez
Hello, sorry I misspelled the wrong name.
Pavel
Pavel_Hernandez
Hello, my name is Pavel, and I will be supporting your case, let me get more information, and when I have more details, I will contact you.
Pavel
