MIMXRT106 Arbitrary Flash Memory
2,291 次查看
accatpaliz
Using MIMXRT106F MCU , could i use any arbitrary flash memory? for example a simple SPI flash i have used previously? if so i guess we need to write our driver to work with SPI flash and load it to ram at the beginning of programming process. is there any document to help me?
2 回复数
2,277 次查看
accatpaliz
i am designing now. and must choose decision about flash memory. because suggested hyper flash is expensive and my supplier could not find it easily in the market. thanks for any tips
2,264 次查看
PabloAvalos
Hi @accatpaliz
Thank you so much for your patience and for your interest in NXP Semiconductor products.
Regarding your questions, I think there is no way to use an external SPI Flash memory. I would highly recommend you to refer to these links that might be helpful based on your needs.:
https://www.nxp.com/docs/en/nxp/application-notes/AN12238.pdf
https://community.nxp.com/t5/i-MX-RT/How-to-boot-from-external-qspi-flash/td-p/1061926
Please let me know your comments or if you have more questions.
Thank you in advance.
Best Regards.
Pablo Avalos.
