LinkServer problems when debugging
652 次查看
tbonkers
I can upload and erase flash using a custom LinkServer algorithm, however I cannot debug. Starting gdbserver works, however when trying to connect I get a myriad of errors:
INFO: [stub (3333)] Pb: (100) Finished writing Flash successfully.
INFO: [stub (3333)] Wc: ============= SCRIPT: RT1160_reset_M7.scp =============
Wc: This probe = 1
Wc: This TAP = 0
Wc: This core = 0
Wc: SYSTEM Reset
Wc: Wirespeed = 10000000 Hz
Wc: Error: Wire Ack Fault - target connected?
Wc: DpID = 6BA02477
INFO: [stub (3333)] Wc: TAP 0: 6BA02477 Core 0: M7  APID: 84770001 ROM Table: E00FD003*
Wc: TAP 0: 6BA02477 AP   1:     APID: 24770011 ROM Table: E00FF003
Wc: TAP 0: 6BA02477 AP   2:     APID: 54770002 ROM Table: 00000002
Wc: APID = 0x84770001
Wc: View cores on the DAP AP
Wc: R15 = 0x00223104
Wc: Vector table SP/PC is the reset context.
Wc: PC = 0x3000EF1D
Wc: SP = 0x8021C450
Wc: XPSR = 0x01000000
Wc: VTOR = 0x30002000
Wc: Set DEMCR = 0x010007F1
Wc: ============= END SCRIPT ==============================
INFO: [stub (3333)] Nc: Using memory from core 0 after searching for a good core
INFO: [stub (3333)] Pc: ( 30) Emulator Connected
INFO: [stub (3333)] Pc: ( 40) Debug Halt
INFO: [stub (3333)] Pc: ( 50) CPU ID
INFO: [stub (3333)] Nc: debug interface type      = CoreSight DP (DAP DP ID 6BA02477) over SWD TAP 0
Nc: processor type            = Cortex-M7 (CPU ID 00000C27) on DAP AP 0
Nc: number of h/w breakpoints = 8
Nc: number of flash patches   = 0
Nc: number of h/w watchpoints = 4
Wc: This probe = 1
Wc: This TAP = 0
Wc: This core = 0
Wc: SYSTEM Reset
Wc: DpID = 6BA02477
INFO: [stub (3333)] Wc: View cores on the DAP AP
Wc: PC = 0xFFFFFFFF
Wc: SP = 0xFFFFFFFF
INFO: [stub (3333)] Nc: state - running or following reset request - re-read of state failed - rc Nn(05). Wire ACK Fault in DAP access
INFO: [stub (3333)] Xw:
The second reset script invocation seems to be where the problem occurs. Strangely enough, when I start LinkServer gdbserver with --attach option, I can connect with the debugger.
The issue might have something to do with the FlexSPI control block - when I'm using Octal DDR mode, I can connect and debug; when I'm using XSPI I can't.
4 回复数
616 次查看
tbonkers
I believe the problem might stem from the .cfx driver applying the wrong configuration option to the FlexSPI. I'm using IS25WX256 in Extended SPI mode. The LinkServer flash driver applies CONFIG_OPTION1 0xC0603001.
I tried using different CONFIG_OPTION1 in the flash driver (0xC0000001), but the problem with debug not working persists. When using MCUXpresso Secure Provisioning Tool, I can read/write flash using config option 0xC0000001.
Is there a way to get the currently applied config option from the FlexSPI ROM API?
552 次查看
carlos_o
Hi @tbonkers
Thanks for your post.
Could you please provide the chip you are using?
Is it a custom board? if not please provide which one you are using.
Could you please provide the reason why you need to use a custom script to use LinkServer?
533 次查看
tbonkers
I am using a custom board with MIMXRT1166CVM5A and octal flash IS25WX256.
I've had to use a custom algorithm for LinkServer as the reset pin of the flash does not match the reset pin used by MIMXRT1160-EVK.
515 次查看
carlos_o
Hi @tbonkers
This are some guide or information related to scripting with LinkServer
Solved: LinkServer automation with python - NXP Community
LinkServer Scripting, and how to Recover MCUs with a Script | MCU on Eclipse
I also recommend you review the script provided with the LinkServer at yourlinkserverlocation/binaries/scripts/
%3CLINGO-SUB%20id%3D%22lingo-sub-2179961%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E8%B0%83%E8%AF%95%E6%97%B6%E5%87%BA%E7%8E%B0%E7%9A%84%20LinkServer%20%E9%97%AE%E9%A2%98%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2179961%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E5%8F%AF%E4%BB%A5%E4%BD%BF%E7%94%A8%E8%87%AA%E5%AE%9A%E4%B9%89%20LinkServer%20%E7%AE%97%E6%B3%95%E4%B8%8A%E4%BC%A0%E5%92%8C%E6%93%A6%E9%99%A4%E9%97%AA%E5%AD%98%EF%BC%8C%E4%BD%86%E6%97%A0%E6%B3%95%E8%BF%9B%E8%A1%8C%E8%B0%83%E8%AF%95%E3%80%82%E5%90%AF%E5%8A%A8%20gdbserver%20%E6%AD%A3%E5%B8%B8%E5%B7%A5%E4%BD%9C%EF%BC%8C%E4%BD%86%E5%9C%A8%E5%B0%9D%E8%AF%95%E8%BF%9E%E6%8E%A5%E6%97%B6%E5%8D%B4%E5%87%BA%E7%8E%B0%E4%BA%86%E5%A4%A7%E9%87%8F%E9%94%99%E8%AF%AF%EF%BC%9A%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3EINFO%3A%20%5Bstub%20(3333)%5D%20Pb%3A%20(100)%20Finished%20writing%20Flash%20successfully.%0AINFO%3A%20%5Bstub%20(3333)%5D%20Wc%3A%20%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%20SCRIPT%3A%20RT1160_reset_M7.scp%20%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%0AWc%3A%20This%20probe%20%3D%201%0AWc%3A%20This%20TAP%20%3D%200%0AWc%3A%20This%20core%20%3D%200%0AWc%3A%20SYSTEM%20Reset%0AWc%3A%20Wirespeed%20%3D%2010000000%20Hz%0AWc%3A%20Error%3A%20Wire%20Ack%20Fault%20-%20target%20connected%3F%0AWc%3A%20DpID%20%3D%206BA02477%0AINFO%3A%20%5Bstub%20(3333)%5D%20Wc%3A%20TAP%200%3A%206BA02477%20Core%200%3A%20M7%20%20APID%3A%2084770001%20ROM%20Table%3A%20E00FD003*%0AWc%3A%20TAP%200%3A%206BA02477%20AP%20%20%201%3A%20%20%20%20%20APID%3A%2024770011%20ROM%20Table%3A%20E00FF003%0AWc%3A%20TAP%200%3A%206BA02477%20AP%20%20%202%3A%20%20%20%20%20APID%3A%2054770002%20ROM%20Table%3A%2000000002%0AWc%3A%20APID%20%3D%200x84770001%0AWc%3A%20View%20cores%20on%20the%20DAP%20AP%0AWc%3A%20TAP%200%3A%206BA02477%20Core%200%3A%20M7%20%20APID%3A%2084770001%20ROM%20Table%3A%20E00FD003*%0AWc%3A%20R15%20%3D%200x00223104%0AWc%3A%20Vector%20table%20SP%2FPC%20is%20the%20reset%20context.%0AWc%3A%20PC%20%3D%200x3000EF1D%0AWc%3A%20SP%20%3D%200x8021C450%0AWc%3A%20XPSR%20%3D%200x01000000%0AWc%3A%20VTOR%20%3D%200x30002000%0AWc%3A%20Set%20DEMCR%20%3D%200x010007F1%0AWc%3A%20%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%20END%20SCRIPT%20%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%0AINFO%3A%20%5Bstub%20(3333)%5D%20Nc%3A%20Using%20memory%20from%20core%200%20after%20searching%20for%20a%20good%20core%0AINFO%3A%20%5Bstub%20(3333)%5D%20Pc%3A%20(%2030)%20Emulator%20Connected%0AINFO%3A%20%5Bstub%20(3333)%5D%20Pc%3A%20(%2040)%20Debug%20Halt%0AINFO%3A%20%5Bstub%20(3333)%5D%20Pc%3A%20(%2050)%20CPU%20ID%0AINFO%3A%20%5Bstub%20(3333)%5D%20Nc%3A%20debug%20interface%20type%20%20%20%20%20%20%3D%20CoreSight%20DP%20(DAP%20DP%20ID%206BA02477)%20over%20SWD%20TAP%200%0ANc%3A%20processor%20type%20%20%20%20%20%20%20%20%20%20%20%20%3D%20Cortex-M7%20(CPU%20ID%2000000C27)%20on%20DAP%20AP%200%0ANc%3A%20number%20of%20h%2Fw%20breakpoints%20%3D%208%0ANc%3A%20number%20of%20flash%20patches%20%20%20%3D%200%0ANc%3A%20number%20of%20h%2Fw%20watchpoints%20%3D%204%0AINFO%3A%20%5Bstub%20(3333)%5D%20Wc%3A%20%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%20SCRIPT%3A%20RT1160_reset_M7.scp%20%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%0AWc%3A%20This%20probe%20%3D%201%0AWc%3A%20This%20TAP%20%3D%200%0AWc%3A%20This%20core%20%3D%200%0AWc%3A%20SYSTEM%20Reset%0AWc%3A%20Wirespeed%20%3D%2010000000%20Hz%0AWc%3A%20DpID%20%3D%206BA02477%0AWc%3A%20TAP%200%3A%206BA02477%20Core%200%3A%20M7%20%20APID%3A%2084770001%20ROM%20Table%3A%20E00FD003*%0AWc%3A%20TAP%200%3A%206BA02477%20AP%20%20%201%3A%20%20%20%20%20APID%3A%2024770011%20ROM%20Table%3A%20E00FF003%0AWc%3A%20TAP%200%3A%206BA02477%20AP%20%20%202%3A%20%20%20%20%20APID%3A%2054770002%20ROM%20Table%3A%2000000002%0AWc%3A%20APID%20%3D%200x84770001%0AINFO%3A%20%5Bstub%20(3333)%5D%20Wc%3A%20View%20cores%20on%20the%20DAP%20AP%0AWc%3A%20TAP%200%3A%206BA02477%20Core%200%3A%20M7%20%20APID%3A%2084770001%20ROM%20Table%3A%20E00FD003*%0AWc%3A%20R15%20%3D%200x00223104%0AWc%3A%20Vector%20table%20SP%2FPC%20is%20the%20reset%20context.%0AWc%3A%20PC%20%3D%200xFFFFFFFF%0AWc%3A%20SP%20%3D%200xFFFFFFFF%0AWc%3A%20XPSR%20%3D%200x01000000%0AWc%3A%20VTOR%20%3D%200x30002000%0AWc%3A%20Set%20DEMCR%20%3D%200x010007F1%0AWc%3A%20%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%20END%20SCRIPT%20%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%0AINFO%3A%20%5Bstub%20(3333)%5D%20Nc%3A%20state%20-%20running%20or%20following%20reset%20request%20-%20re-read%20of%20state%20failed%20-%20rc%20Nn(05).%20Wire%20ACK%20Fault%20in%20DAP%20access%0AINFO%3A%20%5Bstub%20(3333)%5D%20Xw%3A%0AINFO%3A%20%5Bstub%20(3333)%5D%20Nc%3A%20state%20-%20running%20or%20following%20reset%20request%20-%20re-read%20of%20state%20failed%20-%20rc%20Nn(05).%20Wire%20ACK%20Fault%20in%20DAP%20access%0AINFO%3A%20%5Bstub%20(3333)%5D%20Nc%3A%20state%20-%20running%20or%20following%20reset%20request%20-%20re-read%20of%20state%20failed%20-%20rc%20Nn(05).%20Wire%20ACK%20Fault%20in%20DAP%20access%0AINFO%3A%20%5Bstub%20(3333)%5D%20Nc%3A%20state%20-%20running%20or%20following%20reset%20request%20-%20re-read%20of%20state%20failed%20-%20rc%20Nn(05).%20Wire%20ACK%20Fault%20in%20DAP%20access%0AINFO%3A%20%5Bstub%20(3333)%5D%20Nc%3A%20state%20-%20running%20or%20following%20reset%20request%20-%20re-read%20of%20state%20failed%20-%20rc%20Nn(05).%20Wire%20ACK%20Fault%20in%20DAP%20access%3C%2FCODE%3E%3C%2FPRE%3E%3CP%3E%E7%AC%AC%E4%BA%8C%E6%AC%A1%20RESET%20%E8%84%9A%E6%9C%AC%E8%B0%83%E7%94%A8%E4%BC%BC%E4%B9%8E%E6%98%AF%E9%97%AE%E9%A2%98%E5%8F%91%E7%94%9F%E7%9A%84%E5%9C%B0%E6%96%B9%E3%80%82%E5%A5%87%E6%80%AA%E7%9A%84%E6%98%AF%EF%BC%8C%E5%BD%93%E6%88%91%E4%BD%BF%E7%94%A8%20--attach%20%E9%80%89%E9%A1%B9%E5%90%AF%E5%8A%A8%20LinkServer%20gdbserver%20%E6%97%B6%EF%BC%8C%E6%88%91%E5%8F%AF%E4%BB%A5%E8%BF%9E%E6%8E%A5%E5%88%B0%E8%B0%83%E8%AF%95%E5%99%A8%E3%80%82%3C%2FP%3E%3CP%3E%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E5%8F%AF%E8%83%BD%E4%B8%8E%20FlexSPI%20%E6%8E%A7%E5%88%B6%E5%9D%97%E6%9C%89%E5%85%B3--%E5%BD%93%E6%88%91%E4%BD%BF%E7%94%A8%E5%85%AB%E8%BF%9B%E5%88%B6%20DDR%20%E6%A8%A1%E5%BC%8F%E6%97%B6%EF%BC%8C%E6%88%91%E5%8F%AF%E4%BB%A5%E8%BF%9E%E6%8E%A5%E5%B9%B6%E8%B0%83%E8%AF%95%EF%BC%9B%E8%80%8C%E5%BD%93%E6%88%91%E4%BD%BF%E7%94%A8%20XSPI%20%E6%97%B6%EF%BC%8C%E5%B0%B1%E4%B8%8D%E8%A1%8C%E4%BA%86%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2183251%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LinkServer%20problems%20when%20debugging%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2183251%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F183978%22%20target%3D%22_blank%22%3E%40tbonkers%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E4%BB%A5%E4%B8%8B%E6%98%AF%E4%B8%80%E4%BA%9B%E4%B8%8E%20LinkServer%20%E8%84%9A%E6%9C%AC%E7%9B%B8%E5%85%B3%E7%9A%84%E6%8C%87%E5%8D%97%E6%88%96%E4%BF%A1%E6%81%AF%3C%2FP%3E%0A%3CP%3E%3CSPAN%20data-teams%3D%22true%22%3E%3CA%20id%3D%22menur1jr%22%20class%3D%22fui-Link%20___1q1shib%20f2hkw1w%20f3rmtva%20f1ewtqcl%20fyind8e%20f1k6fduh%20f1w7gpdv%20fk6fouc%20fjoy568%20figsok6%20f1s184ao%20f1mk8lai%20fnbmjn9%20f1o700av%20f13mvf36%20f1cmlufx%20f9n3di6%20f1ids18y%20f1tx3yz7%20f1deo86v%20f1eh06m1%20f1iescvh%20fhgqx19%20f1olyrje%20f1p93eir%20f1nev41a%20f1h8hb77%20f1lqvz6u%20f10aw75t%20fsle3fq%20f17ae5zn%22%20title%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fmcuxpresso-general%2Flinkserver-automation-with-python%2Fm-p%2F2013327%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FMCUXpresso-General%2FLinkServer-automation-with-python%2Fm-p%2F2013327%22%20target%3D%22_blank%22%20aria-label%3D%22Link%20Solved%3A%20LinkServer%20automation%20with%20python%20-%20NXP%20Community%22%3E%E5%B7%B2%E8%A7%A3%E5%86%B3%EF%BC%9A%E4%BD%BF%E7%94%A8%20python%20%E5%AE%9E%E7%8E%B0%20LinkServer%20%E8%87%AA%E5%8A%A8%E5%8C%96%20-%20NXP%20%E7%A4%BE%E5%8C%BA%3C%2FA%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20data-teams%3D%22true%22%3E%3CA%20id%3D%22menur1ju%22%20class%3D%22fui-Link%20___1q1shib%20f2hkw1w%20f3rmtva%20f1ewtqcl%20fyind8e%20f1k6fduh%20f1w7gpdv%20fk6fouc%20fjoy568%20figsok6%20f1s184ao%20f1mk8lai%20fnbmjn9%20f1o700av%20f13mvf36%20f1cmlufx%20f9n3di6%20f1ids18y%20f1tx3yz7%20f1deo86v%20f1eh06m1%20f1iescvh%20fhgqx19%20f1olyrje%20f1p93eir%20f1nev41a%20f1h8hb77%20f1lqvz6u%20f10aw75t%20fsle3fq%20f17ae5zn%22%20title%3D%22https%3A%2F%2Fmcuoneclipse.com%2F2023%2F07%2F25%2Flinkserver-scripting-and-how-to-recover-mcus-with-a-script%2F%22%20href%3D%22https%3A%2F%2Fmcuoneclipse.com%2F2023%2F07%2F25%2Flinkserver-scripting-and-how-to-recover-mcus-with-a-script%2F%22%20target%3D%22_blank%22%20rel%3D%22noreferrer%20noopener%20nofollow%22%20aria-label%3D%22Link%20LinkServer%20Scripting%2C%20and%20how%20to%20Recover%20MCUs%20with%20a%20Script%20%7C%20MCU%20on%20Eclipse%22%3ELinkServer%20%E8%84%9A%E6%9C%AC%EF%BC%8C%E4%BB%A5%E5%8F%8A%E5%A6%82%E4%BD%95%E4%BD%BF%E7%94%A8%E8%84%9A%E6%9C%AC%E6%81%A2%E5%A4%8D%20MCU%20%7C%20Eclipse%20%E4%B8%8A%E7%9A%84%20MCU%3C%2FA%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20data-teams%3D%22true%22%3E%E6%88%91%E8%BF%98%E5%BB%BA%E8%AE%AE%E4%BD%A0%E5%9C%A8%20linkserverlocation%2Fbinaries%2Fscripts%2F%20%E4%B8%8A%E6%9F%A5%E7%9C%8B%20LinkServer%20%E6%8F%90%E4%BE%9B%E7%9A%84%E8%84%9A%E6%9C%AC%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20data-teams%3D%22true%22%3EBR%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2181845%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LinkServer%20problems%20when%20debugging%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2181845%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%3CBR%20%2F%3E%E6%88%91%E6%AD%A3%E5%9C%A8%E4%BD%BF%E7%94%A8%E5%B8%A6%E6%9C%89%20MIMXRT1166CVM5A%20%E5%92%8C%E5%85%AB%E8%BF%9B%E5%88%B6%E9%97%AA%E5%AD%98%20IS25WX256%20%E7%9A%84%E8%87%AA%E5%AE%9A%E4%B9%89%E6%9D%BF%E3%80%82%3CBR%20%2F%3E%E6%88%91%E4%B8%8D%E5%BE%97%E4%B8%8D%E4%B8%BA%20LinkServer%20%E4%BD%BF%E7%94%A8%E8%87%AA%E5%AE%9A%E4%B9%89%E7%AE%97%E6%B3%95%EF%BC%8C%E5%9B%A0%E4%B8%BA%E9%97%AA%E5%AD%98%E7%9A%84%20RESET%20%E5%BC%95%E8%84%9A%E4%B8%8E%20MIMXRT1160-EVK%20%E4%BD%BF%E7%94%A8%E7%9A%84%20RESET%20%E5%BC%95%E8%84%9A%E4%B8%8D%E5%8C%B9%E9%85%8D%E3%80%82%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2181513%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LinkServer%20problems%20when%20debugging%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2181513%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F183978%22%20target%3D%22_blank%22%3E%40tbonkers%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E8%B0%A2%E8%B0%A2%E6%82%A8%E7%9A%84%E5%B8%96%E5%AD%90%E3%80%82%3C%2FP%3E%0A%3CP%3E%E8%83%BD%E5%90%A6%E6%8F%90%E4%BE%9B%E6%82%A8%E4%BD%BF%E7%94%A8%E7%9A%84%E8%8A%AF%E7%89%87%EF%BC%9F%3C%2FP%3E%0A%3CP%3E%E5%AE%83%E6%98%AF%E5%AE%9A%E5%88%B6%E6%9D%BF%E5%90%97%EF%BC%9F%E5%A6%82%E6%9E%9C%E6%B2%A1%E6%9C%89%EF%BC%8C%E8%AF%B7%E6%8F%90%E4%BE%9B%E6%82%A8%E6%AD%A3%E5%9C%A8%E4%BD%BF%E7%94%A8%E7%9A%84%E7%89%88%E6%9C%AC%E3%80%82%3C%2FP%3E%0A%3CP%3E%E8%83%BD%E5%90%A6%E8%AF%B7%E6%82%A8%E8%AF%B4%E6%98%8E%E4%B8%BA%E4%BB%80%E4%B9%88%E9%9C%80%E8%A6%81%E4%BD%BF%E7%94%A8%E8%87%AA%E5%AE%9A%E4%B9%89%E8%84%9A%E6%9C%AC%E6%9D%A5%E4%BD%BF%E7%94%A8%20LinkServer%EF%BC%9F%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2180199%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LinkServer%20problems%20when%20debugging%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2180199%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%88%91%E8%AE%A4%E4%B8%BA%E9%97%AE%E9%A2%98%E5%8F%AF%E8%83%BD%E6%9D%A5%E8%87%AA%20.cfx%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E5%AF%B9%20FlexSPI%20%E5%BA%94%E7%94%A8%E4%BA%86%E9%94%99%E8%AF%AF%E7%9A%84%E9%85%8D%E7%BD%AE%E9%80%89%E9%A1%B9%E3%80%82%E6%88%91%E5%9C%A8%E6%89%A9%E5%B1%95%20SPI%20%E6%A8%A1%E5%BC%8F%E4%B8%8B%E4%BD%BF%E7%94%A8%20IS25WX256%E3%80%82LinkServer%20%E9%97%AA%E5%AD%98%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E5%BA%94%E7%94%A8%20CONFIG_OPTION1%200xC0603001%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E6%88%91%E5%B0%9D%E8%AF%95%E5%9C%A8%E9%97%AA%E5%AD%98%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E4%B8%AD%E4%BD%BF%E7%94%A8%E4%B8%8D%E5%90%8C%E7%9A%84%20CONFIG_OPTION1%EF%BC%880xC0000001%EF%BC%89%EF%BC%8C%E4%BD%86%E8%B0%83%E8%AF%95%E5%A4%B1%E8%B4%A5%E7%9A%84%E9%97%AE%E9%A2%98%E4%BE%9D%E7%84%B6%E5%AD%98%E5%9C%A8%E3%80%82%E4%BD%BF%E7%94%A8%20MCUXpresso%20%E5%AE%89%E5%85%A8%E9%85%8D%E7%BD%AE%E5%B7%A5%E5%85%B7%E6%97%B6%EF%BC%8C%E6%88%91%E5%8F%AF%E4%BB%A5%E4%BD%BF%E7%94%A8%E9%85%8D%E7%BD%AE%E9%80%89%E9%A1%B9%200xC000000001%20%E8%AF%BB%E5%8F%96%2F%E5%86%99%E5%85%A5%E9%97%AA%E5%AD%98%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E6%9C%89%E6%B2%A1%E6%9C%89%E5%8A%9E%E6%B3%95%E4%BB%8E%20FlexSPI%20ROM%20API%20%E8%8E%B7%E5%8F%96%E5%BD%93%E5%89%8D%E5%BA%94%E7%94%A8%E7%9A%84%E9%85%8D%E7%BD%AE%E9%80%89%E9%A1%B9%EF%BC%9F%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E
