J-Link Flash Programming
7,544件の閲覧回数
Angel487
Greetings.
I’m new to iMX MCUs & MCUxpresso IDE and I'm trying to flash/and debug via J-link a board mounting an iMXRT1052 with 128M nor flash. Unfortunately I'm just able to connect to the MCU but not able to erase or program it. I've tried with J-flash V7.50, V7.70 and MCUxpresso.
I've attached dome screenshots
I hope you can help me to find the problem. Thanks!
3 返答(返信)
7,529件の閲覧回数
Pavel_Hernandez
Hello, my name is Pavel, and I will be supporting your case, let me get into your case and when I have more information, I will contact you.
Pavel
7,519件の閲覧回数
Pavel_Hernandez
Hello, maybe this thread could help you.
RT board recovery for debugger connect issues - NXP Community
Pavel
7,416件の閲覧回数
Angel487
Thank you Pavel for the support!
The "SPT Mass Erase" method has solved the issue.
