Inline encryption engine(IEE) for External flash memory in IMXRT1170
ソリューションへジャンプ
3,607件の閲覧回数
Nagaveni
I am using IMXRT1170 Evk ,
  1. can I use IEE(Inline encryption engine) for both encryption and decryption to   read and write to the external flash memory ?
  2. please find below image  and can you tell us what is difference between 8.1.2 section from security RM manual and 7.10 section from IMXRT1170RM manual ?
Thanks in advance
3,537件の閲覧回数
Omar_Anguiano
Thank you for your patience!
The IEE features on the SRM don't take the system limitations of RT1170. So IEE on RT1170 can only decrypt FlexSPI Nor memory.
Omar
3 返答(返信)
3,565件の閲覧回数
Omar_Anguiano
Hello
I hope you are well.
IEE on flexspi is only capable of decryption, however, let me confirm if it is also possible to encrypt flexspi through IEE.
Omar
3,556件の閲覧回数
Nagaveni
Thank you for the response,
Please confirm ASAP, Regarding IEE encryption for Flash memory
3,538件の閲覧回数
Omar_Anguiano
Omar
