IMXRT1176 FBB_DISABLE Fuse is already set
1,210 次查看
bia-bonobo
I have some fresh custom boards with i.MX-RT1170 MCU, when I check the fuses, which I expect them to be blank. All of them have the fuse FBB_DISABLE on address 0x870[4] set which disables the FBB. I was expecting that all fuses by default would not be set. Because it's not possible to unset it.
What's going on here?
Adrian
标记 (1)
1,025 次查看
Gavin_Jia
Hi @bia-bonobo ,
A more precise description would be that FBB_DISABLE is specific to the chip itself and is therefore factory-configured. When the RT1170 needs to operate in overdrive mode, it must read FBB_DISABLE first and then determine whether to enable FBB.
There is no publicly available list corresponding to part numbers; instead, this depends on the specific characteristics of the process/chip itself. Therefore, as described in the datasheet, the software flow should first read FBB_DISABLE.
Gavin
4 回复数
1,155 次查看
Gavin_Jia
Hi @bia-bonobo ,
Thanks for your interest in NXP MIMXRT series!
FBB_DISABLE is factory-configured and is related to your chip's part number. It functions more like a flag bit. Please refer to the note in the datasheet/RM.
Gavin
1,146 次查看
bia-bonobo
@Gavin_Jia Thank you for your response. I understand.
I also had some boards where this fuse was not set. But it's possible, these were another part number.
Is there a list for which part numbers this fuse is set and for which not?
1,026 次查看
Gavin_Jia
Hi @bia-bonobo ,
Gavin
1,013 次查看
bia-bonobo
I get it now, Thank you!
%3CLINGO-SUB%20id%3D%22lingo-sub-2324899%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EIMXRT1176%20FBB_DISABLE%20%E7%86%94%E4%B8%9D%E5%B7%B2%E7%BB%8F%E8%AE%BE%E7%BD%AE%E5%A5%BD%E4%BA%86%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2324899%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3C%2FP%3E%3CP%3E%E5%BD%93%E6%88%91%E6%A3%80%E6%9F%A5%E7%86%94%E4%B8%9D%E6%97%B6%EF%BC%8C%E6%88%91%E6%9C%89%E4%B8%80%E4%BA%9B%E8%A3%85%E6%9C%89%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fc-pwmxy87654%2Fi.MX-RT1170%2Fpd-p%2Fi.MX-RT1170%22%20class%3D%22lia-product-mention%22%20data-product%3D%22519-1%22%20target%3D%22_blank%22%3Ei.MX-RT1170%3C%2FA%3E%20MCU%20%E7%9A%84%E6%96%B0%E5%AE%9A%E5%88%B6%E6%9D%BF%EF%BC%8C%E6%88%91%E9%A2%84%E8%AE%A1%E7%86%94%E4%B8%9D%E4%BC%9A%E6%98%AF%E7%A9%BA%E7%99%BD%E7%9A%84%E3%80%82%E5%AE%83%E4%BB%AC%E9%83%BD%E8%AE%BE%E7%BD%AE%E4%BA%86%E5%9C%B0%E5%9D%80%200x870%20%5B4%5D%20%E4%B8%8A%E7%9A%84%E7%86%94%E4%B8%9D%20FBB_DISABLE%EF%BC%8C%E8%BF%99%E4%BC%9A%E7%A6%81%E7%94%A8%20FBB%E3%80%82%E6%88%91%E5%8E%9F%E6%9C%AC%E4%BB%A5%E4%B8%BA%E9%BB%98%E8%AE%A4%E6%83%85%E5%86%B5%E4%B8%8B%E4%B8%8D%E4%BC%9A%E8%AE%BE%E7%BD%AE%E6%89%80%E6%9C%89%E7%86%94%E4%B8%9D%E3%80%82%E5%9B%A0%E4%B8%BA%E4%B8%8D%E5%8F%AF%E8%83%BD%E5%8F%96%E6%B6%88%E8%AE%BE%E7%BD%AE%E3%80%82%3C%2FP%3E%3CP%3E%E8%BF%99%E6%98%AF%E6%80%8E%E4%B9%88%E5%9B%9E%E4%BA%8B%EF%BC%9F%3C%2FP%3E%3CP%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3C%2FP%3E%3CP%3E%E9%98%BF%E5%BE%B7%E9%87%8C%E5%AE%89%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2326278%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20IMXRT1176%20FBB_DISABLE%20Fuse%20is%20already%20set%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2326278%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F203261%22%20target%3D%22_blank%22%3E%40Gavin_Jia%3C%2FA%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%9B%9E%E5%A4%8D%E3%80%82%E6%88%91%E6%98%8E%E7%99%BD%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E8%BF%98%E6%9C%89%E4%B8%80%E4%BA%9B%E7%94%B5%E8%B7%AF%E6%9D%BF%E4%B8%8A%E6%B2%A1%E6%9C%89%E8%AE%BE%E7%BD%AE%E8%BF%99%E4%B8%AA%E7%86%94%E4%B8%9D%E3%80%82%E4%BD%86%E4%B9%9F%E6%9C%89%E5%8F%AF%E8%83%BD%EF%BC%8C%E8%BF%99%E4%BA%9B%E6%98%AF%E5%8F%A6%E4%B8%80%E4%B8%AA%E9%9B%B6%E4%BB%B6%E7%BC%96%E5%8F%B7%E3%80%82%3C%2FP%3E%3CP%3E%E6%98%AF%E5%90%A6%E6%9C%89%E6%B8%85%E5%8D%95%E5%88%97%E5%87%BA%E6%AD%A4%E7%86%94%E4%B8%9D%E6%98%AF%E9%92%88%E5%AF%B9%E5%93%AA%E4%BA%9B%E9%9B%B6%E4%BB%B6%E7%BC%96%E5%8F%B7%E8%AE%BE%E7%BD%AE%E7%9A%84%EF%BC%8C%E5%93%AA%E4%BA%9B%E4%B8%8D%E6%98%AF%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2326088%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20IMXRT1176%20FBB_DISABLE%20Fuse%20is%20already%20set%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2326088%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%E6%88%91%E6%98%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F256965%22%20target%3D%22_blank%22%3E%40bia-bonobo%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E5%AF%B9%20NXP%20MIMXRT%20%E7%B3%BB%E5%88%97%E7%9A%84%E5%85%B3%E6%B3%A8%EF%BC%81%3C%2FP%3E%0A%3CP%3EFBB_DISABLE%20%E5%87%BA%E5%8E%82%E9%85%8D%E7%BD%AE%EF%BC%8C%E4%B8%8E%E8%8A%AF%E7%89%87%E7%9A%84%E9%83%A8%E4%BB%B6%E5%8F%B7%E6%9C%89%E5%85%B3%E3%80%82%E5%AE%83%E7%9A%84%E5%8A%9F%E8%83%BD%E6%9B%B4%E5%83%8F%E6%98%AF%E4%B8%80%E4%B8%AA%E6%A0%87%E5%BF%97%E4%BD%8D%E3%80%82%E8%AF%B7%E5%8F%82%E9%98%85%E6%95%B0%E6%8D%AE%E8%A1%A8%2FRM%20%E4%B8%AD%E7%9A%84%E8%AF%B4%E6%98%8E%E3%80%82%3C%2FP%3E%0A%3CP%3E%E8%87%B4%E4%BB%A5%E6%9C%80%E8%AF%9A%E6%8C%9A%E7%9A%84%E9%97%AE%E5%80%99%EF%BC%8C%3CBR%20%2F%3EGavin%3C%2FP%3E%0A%3CDIV%20id%3D%22tinyMceEditorGavin_Jia_0%22%20class%3D%22mceNonEditable%20lia-copypaste-placeholder%22%3E%26nbsp%3B%3C%2FDIV%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2328746%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20IMXRT1176%20FBB_DISABLE%20Fuse%20is%20already%20set%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2328746%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E7%8E%B0%E5%9C%A8%E6%98%8E%E7%99%BD%E4%BA%86%EF%BC%8C%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2328732%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20IMXRT1176%20FBB_DISABLE%20Fuse%20is%20already%20set%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2328732%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%E6%88%91%E6%98%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F256965%22%20target%3D%22_blank%22%3E%40bia-bonobo%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CP%3E%E6%9B%B4%E5%87%86%E7%A1%AE%E7%9A%84%E6%8F%8F%E8%BF%B0%E6%98%AF%EF%BC%8CFBB_DISABLE%20%E6%98%AF%E8%8A%AF%E7%89%87%E6%9C%AC%E8%BA%AB%E7%89%B9%E6%9C%89%E7%9A%84%EF%BC%8C%E5%9B%A0%E6%AD%A4%E6%98%AF%E5%87%BA%E5%8E%82%E9%85%8D%E7%BD%AE%E7%9A%84%E3%80%82%E5%BD%93%20RT1170%20%E9%9C%80%E8%A6%81%E5%9C%A8%E8%B6%85%E9%80%9F%E6%A8%A1%E5%BC%8F%E4%B8%8B%E5%B7%A5%E4%BD%9C%E6%97%B6%EF%BC%8C%E5%BF%85%E9%A1%BB%E9%A6%96%E5%85%88%E8%AF%BB%E5%8F%96%20FBB_DISABLE%EF%BC%8C%E7%84%B6%E5%90%8E%E7%A1%AE%E5%AE%9A%E6%98%AF%E5%90%A6%E5%90%AF%E7%94%A8%20FBB%E3%80%82%3C%2FP%3E%0A%3CP%3E%E7%9B%AE%E5%89%8D%E8%BF%98%E6%B2%A1%E6%9C%89%E4%B8%8E%E9%9B%B6%E4%BB%B6%E7%BC%96%E5%8F%B7%E7%9B%B8%E5%AF%B9%E5%BA%94%E7%9A%84%E5%85%AC%E5%BC%80%E6%B8%85%E5%8D%95%EF%BC%9B%E7%9B%B8%E5%8F%8D%EF%BC%8C%E8%BF%99%E5%8F%96%E5%86%B3%E4%BA%8E%E5%B7%A5%E8%89%BA%2F%E8%8A%AF%E7%89%87%E6%9C%AC%E8%BA%AB%E7%9A%84%E5%85%B7%E4%BD%93%E7%89%B9%E7%82%B9%E3%80%82%E5%9B%A0%E6%AD%A4%EF%BC%8C%E5%A6%82%E6%95%B0%E6%8D%AE%E6%89%8B%E5%86%8C%E6%89%80%E8%BF%B0%EF%BC%8C%E8%BD%AF%E4%BB%B6%E6%B5%81%E7%A8%8B%E5%BA%94%E9%A6%96%E5%85%88%E8%AF%BB%E5%8F%96%20FBB_DISABLE%E3%80%82%3C%2FP%3E%0A%3CP%3E%E8%87%B4%E4%BB%A5%E6%9C%80%E8%AF%9A%E6%8C%9A%E7%9A%84%E9%97%AE%E5%80%99%EF%BC%8C%3CBR%20%2F%3EGavin%3C%2FP%3E%3C%2FLINGO-BODY%3E
