IMXRT1062 Audio PLL's electrical parameters
Taka05
In which document are the electrical parameters of the IMXRT1062 audio PLL(PLL4) found?
(such as datasheet of IMXRT600 14.7 Main/System and Audio PLLs)
Miguel04
Hi @Taka05
You can find the electrical parameters for the Audio PLL on the datasheet Chapter 4.2.3.1
Let me know if you have another question.
Best Regards, Miguel.
Taka05
Hi @Miguel04
I'm looking for a document that details which PLL characteristics such as jitter.
Is there a way to check these characteristics other than using an EVK to measure them?
Miguel04
Hi @Taka05
The PLL Jitter is not a documented value, however we can ensure that our PLL was designed to keep this value as low as possible. For an exact value on this measure, individual test of your part number would be necessary.
Taka05
Hi @Miguel04
I have two packages, MIMXRT1062DVL6B and MIMXRT1062DVJ6B.
Taka05
