Hi @tbayram ,
It's easy to check the issues, please follow me:
1. open the SDK flexspi_nr_polling_transfer_cm7 code .
2. check :
const uint32_t customLUT[CUSTOM_LUT_LENGTH] = {
make sure the LUT read, erase, quad, etc commander matches you used flash.
3. Run the project in the internal RAM:
Whether it can pass all the testing?
I mean, the log should like this:
FLEXSPI example started!
Vendor ID: 0x9d
Erasing Serial NOR over FlexSPI...
Erase data - successfully.
Program data - successfully.
This will help you to check your external flash situation, and also help you enable the quad mode.
Please try it on your side.
Kerry
