How to put a big array in OCRAM?
1,398 次查看
simmania
I'm usingMCUXpresso with  MIMXRT1010-EVK hardware.
In my program I need a big array. The linker tries to put this in the SRAM_DTC (which I assume is the DTCM). But there is not enough room. While the SRAM_OC (which I assume is the OCRAM) is completely empty.
So, how to instruct the linker to put my big array in SRAM_OC?
Is there some tutorial about this kind of memory management stuff?
1,393 次查看
simmania
Ok, I found it out.
So here is how I did it, in case other people may want to know:
In the Properties of the project, under C/C++ Build -> MCU settings, I could see that the OCRAM section has the alias 'RAM3'. (here you also can change the sizes of the RAM sections)
Then in the code you can do:
#include <cr_section_macros.h>
__DATA(RAM3) uint16_t buffer[BUFSIZE];
1,394 次查看
simmania
Ok, I found it out.
%3CLINGO-SUB%20id%3D%22lingo-sub-2001975%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%A6%82%E4%BD%95%E5%9C%A8%20OCRAM%20%E4%B8%AD%E6%94%BE%E7%BD%AE%E4%B8%80%E4%B8%AA%E5%A4%A7%E9%98%B5%E5%88%97%EF%BC%9F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2001975%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%3CBR%20%2F%3E%E6%88%91%E6%AD%A3%E5%9C%A8%E4%BD%BF%E7%94%A8%E5%B8%A6%E6%9C%89%20MIMXRT1010-EVK%20%E7%A1%AC%E4%BB%B6%E7%9A%84%20MCUXpresso%E3%80%82%3C%2FP%3E%3CP%3E%E5%9C%A8%E6%88%91%E7%9A%84%E7%A8%8B%E5%BA%8F%E4%B8%AD%E6%88%91%E9%9C%80%E8%A6%81%E4%B8%80%E4%B8%AA%E5%A4%A7%E6%95%B0%E7%BB%84%E3%80%82%E9%93%BE%E6%8E%A5%E5%99%A8%E5%B0%9D%E8%AF%95%E5%B0%86%E5%85%B6%E6%94%BE%E5%85%A5%3CSPAN%3ESRAM_DTC%3C%2FSPAN%3E%20%EF%BC%88%E6%88%91%E8%AE%A4%E4%B8%BA%E6%98%AF%20DTCM%EF%BC%89%E3%80%82%E4%BD%86%E6%B2%A1%E6%9C%89%E8%B6%B3%E5%A4%9F%E7%9A%84%E7%A9%BA%E9%97%B4%E3%80%82%E8%80%8C%3CSPAN%3ESRAM_OC%3C%2FSPAN%3E%20%EF%BC%88%E6%88%91%E8%AE%A4%E4%B8%BA%E6%98%AF%20OCRAM%EF%BC%89%E5%AE%8C%E5%85%A8%E6%98%AF%E7%A9%BA%E7%9A%84%E3%80%82%3CBR%20%2F%3E%E9%82%A3%E4%B9%88%EF%BC%8C%E5%A6%82%E4%BD%95%E6%8C%87%E7%A4%BA%E9%93%BE%E6%8E%A5%E5%99%A8%E5%B0%86%E6%88%91%E7%9A%84%E5%A4%A7%E6%95%B0%E7%BB%84%E6%94%BE%E5%85%A5%20SRAM_OC%20%E4%B8%AD%EF%BC%9F%3C%2FP%3E%3CP%3E%E6%9C%89%E6%B2%A1%E6%9C%89%E5%85%B3%E4%BA%8E%E8%BF%99%E7%A7%8D%E5%86%85%E5%AD%98%E7%AE%A1%E7%90%86%E7%9A%84%E6%95%99%E7%A8%8B%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E
