How to import middlewear Example
4,200件の閲覧回数
narenchandra401
Hi community ,
Is there any way we can import a middlewear example in the IDE ?
I want to import the MCU Boot middleware .
Or I should have a base templet and manually add the src and include files in the project ?
Thanks and regards ,
Naren Chandra .
ラベル(5)
4,063件の閲覧回数
kerryzhou
Hi Naren chandra,
  Please read Getting Started with MCUXpresso SDK for EVK-MIMXRT1020.pdf under the SDK path:
SDK_2.7.0_EVK-MIMXRT1020\docs
  Then you can follow it to import the bootloader code to the MCUXpresso IDE:
If you still have questions about it, please kindly let me know.
Wish it helps you!
Kerry
5 返答(返信)
4,063件の閲覧回数
kerryzhou
Hi Naren chandra,
  You can refer to the flashloader project:
SDK_2.7.0_EVK-MIMXRT1020\boards\evkmimxrt1020\bootloader_examples\flashloader
This project is using the middleware:
Wish it helps you!
Kerry
4,063件の閲覧回数
narenchandra401
Hi Kerry ,
I am using MCUXpresso , I want to import the bootloader project inside middlewear -> mcu_boot -> bootloader .
The example you share is IAR based , just guide me in importing the project in mcuxpresso .
Naren Chandra
4,064件の閲覧回数
kerryzhou
Hi Naren chandra,
Wish it helps you!
Kerry
4,063件の閲覧回数
narenchandra401
Thanks Kerry ,
I have downloaded the latest SDK with all the Middlewear selected , was able to import the project in the IDE , Thanks , that was helpful in need of the time .
Thanks and regards
Naren Chandra
4,063件の閲覧回数
kerryzhou
Hi Naren chandra,
   You are welcome!
   Do you have any other questions about this topic?
   If your question is solved, please help me to mark the correct answer, just to close this question, thanks.
Kerry
