The DCD is described in section 8.7 (Program image) of i.MX RT1020
Reference Manual, Rev. 0, 06/2018. For an example, look at dcd_data[]
in “evkmimxrt1020_sdram_ini_dcd.c” of i.MX RT1020 SDK.
SDRAM Datasheet provides information about required initialization
sequence. Also use section 46.4.6 (SDRAM Controller Operations) for
i.MX RT SEMC specifics regarding SDRAM functioning.
Yuri
Note: If this post answers your question, please click the Correct Answer
button. Thank you!
