How to enable building BSD in AzureRTOS NETX
2,643 次查看
michaeldkfowler
 I have tried enabling BSD Sockets in AzureRTOS be adding nx_bsd.c and nx_bsd.h to the src directory and adding #define TX_THREAD_EXTENSION_3 int bsd_errno; to tx_port.h . The project builds, but hangs after startup. How do I get BSD sockets working on the NXP build of AzureRTOS?
标记 (1)
2,608 次查看
michaeldkfowler
It seems it can't be done with the copy of AzureRTOS NXP ships. Cloning the repo from MS here: https://docs.microsoft.com/en-us/samples/azure-rtos/getting-started/connect-an-nxp-mimxrt1050-evkb-e... has a copy with BSD enabled.
2,612 次查看
DeffoWill
Did you ever get this working? I have tried on the 1170-evk and not been successful either.
