How to add driver library in MCUXpress IDE
2,705 次查看
vasudhevan
   EVK - IMXRT1064
   I imported tcp echo free rtos example code it contains tcp echo example code and related driver code ethernet,lwip etc..
   If i want to add httpserver,mqtt,etc... library or other driver library.
   How can i add library(driver source code) to MCUXpress IDE ?
Thanks & Regards
        Vasu
2,610 次查看
jingpan
Basically, if you want to migrate to new sdk, just uninstall the old one and install the new one.
If you want to add new driver, you can copy it to project. Some of the base driver also can be added by ConfigTools.
ConfigTools->Peripheral. Config the peripheral then the driver can be copy to project automaticlly.
Jing
4 回复数
2,610 次查看
jingpan
You can drag & drop source file to project. Be caution that when you want to create a folder, you must right click the project name ->  new -> Source Folder. Other wise, the file in that folder want be compiled by IDE.
Jing
2,610 次查看
vasudhevan
Hi Jing Pan,
     Thank you for your response.
     How to migrate to new sdk ?
     Again i need to import one project after needs to add driver library ?
Thanks & Regards
        Vasu
2,611 次查看
jingpan
Jing
2,610 次查看
vasudhevan
Hi Jing Pan,
       Thank you.
  Vasu
