Basically, if you want to migrate to new sdk, just uninstall the old one and install the new one.
If you want to add new driver, you can copy it to project. Some of the base driver also can be added by ConfigTools.
ConfigTools->Peripheral. Config the peripheral then the driver can be copy to project automaticlly.
Jing
