How To Use Clocks Config Tool?
10,395 次查看
omerkaanbasakin
Hı ı am working on imxrt 1052 in MCUXpresso11.1.1. I tried to change clock settings in source files and config tool but ı could not. How can USDHC1 set as in example?
10,247 次查看
kerryzhou
Hi Omer Kaan Basakinci ,
  Please check your clock:
The example clock:
The example is using the system PLL, but you didn't.
So, select the system PLL clock on your clocks diagram.
Double click the PL2_PFD2_BYPASS:
Select the PLL2 PFD2 output, not the PLL2 bypass clock selector output.
Wish it helps you!
If you still have questions about it, please kindly let me know.
Kerry
10,248 次查看
kerryzhou
The example clock:
Wish it helps you!
Kerry
10,247 次查看
omerkaanbasakin
hi kerryzhou‌,
Thanks for your reply,
I can make changes thanks to you. I changed
10,247 次查看
kerryzhou
You are welcome!
 Any new question in the future, welcome to create the new question post!
Kerry
