How To Use Clocks Config Tool?
10,394件の閲覧回数
omerkaanbasakin
Hı ı am working on imxrt 1052 in MCUXpresso11.1.1. I tried to change clock settings in source files and config tool but ı could not. How can USDHC1 set as in example?
10,246件の閲覧回数
kerryzhou
Hi Omer Kaan Basakinci ,
  Please check your clock:
The example clock:
The example is using the system PLL, but you didn't.
So, select the system PLL clock on your clocks diagram.
Double click the PL2_PFD2_BYPASS:
Select the PLL2 PFD2 output, not the PLL2 bypass clock selector output.
Wish it helps you!
If you still have questions about it, please kindly let me know.
Kerry
3 返答(返信)
10,247件の閲覧回数
kerryzhou
The example clock:
Wish it helps you!
Kerry
10,246件の閲覧回数
omerkaanbasakin
hi kerryzhou‌,
Thanks for your reply,
I can make changes thanks to you. I changed
10,246件の閲覧回数
kerryzhou
You are welcome!
 Any new question in the future, welcome to create the new question post!
Kerry
