FreeRTOS hard fault when using Newlib
457件の閲覧回数
chect1
Trying to get Segger RTT working and found I needed reentr.h, so I tried switching to newlib to solve that problem. Once I do, I get hard fault (Imprecise data bus) when I try and use the idle function in FreeRTOS
Project attached
Switching to Redlib works fine, newlib crashes
Seems to work ok if I turn the idle function off, although I haven't troubleshot it further
My goal is to get Segger RTT working on the CM4 core, which is proving much more difficult than anticipated. Are there any examples for this?
タグ(1)
427件の閲覧回数
EdwinHz
Hi @chect1,
Unfortunately we do not have any documentation or example of how to integrate Segger RTT with the RT1170's CM4 core. However, Erich Styger does have a post on how to properly integrate newlib (and newlib-nano) with FreeRTOS for our MCUs, so please look into that and let me know if it works for you: Using FreeRTOS with newlib and newlib-nano | MCU on Eclipse
BR,
Edwin.
