Flexcomm1 I2C configuration
422 次查看
Nazmin
Hi Team,
I have been trying to configure I2C using Flexcomm1. I am not able to establish a connection between master and slave. I am trying to execute the same example code with changes. Following are the snapshot of the changes made in the sample code (SDK_2_11_1_EVK MIMXRT685\boards\evkmimxrt685\driver_examples\i2c\polling_b2b\master). in order to shift from FC4 to FC1.
#define GDY112X_I2C_BASE            I2C1
#define I2C1_MASTER_CLOCK_FREQUENCY  CLOCK_GetFlexCommClkFreq(1U)
#define GDY112X_I2C_BAUDRATE        (100000U)
/* GDY112X address (7-bit) */
#define GDY112X_7BIT_I2C_ADDR            (0x3A)
int main(void)
/* Init Flexcomm1 as I2C */
 i2c_master_config_t masterConfig;
I2C_MasterGetDefaultConfig(&masterConfig);
/* Change the default baudrate configuration */
masterConfig.baudRate_Bps = GDY112X_I2C_BAUDRATE;
/* Initialize the I2C master peripheral */
I2C_MasterInit(GDY112X_I2C_BASE, &masterConfig, I2C1_MASTER_CLOCK_FREQUENCY);
/*This function to write and read data from master to slave/slave from master/*
void GDY1121_MinimalI2CTest(void)
    status_t status;
    uint8_t reg = WHO_AM_I_REG;
    uint8_t whoami = 0;
    PRINTF("Starting minimal I2C test...\r\n");
 // 1) Send register address (write)
    status = I2C_MasterStart(GDY112X_I2C_BASE, GDY112X_7BIT_I2C_ADDR, kI2C_Write);
    if (status != kStatus_Success) {
        PRINTF("Start (write) failed, status=%d\r\n", status);
        return;
    status = I2C_MasterWriteBlocking(GDY112X_I2C_BASE, &reg, 1, kI2C_TransferNoStopFlag);
        PRINTF("Write reg addr failed, status=%d\r\n", status);
        I2C_MasterStop(GDY112X_I2C_BASE);
        return;
// 2) Restart and read 1 byte
    status = I2C_MasterRepeatedStart(GDY112X_I2C_BASE, GDY112X_7BIT_I2C_ADDR, kI2C_Read);
        PRINTF("Repeated start (read) failed, status=%d\r\n", status);
        return;
    status = I2C_MasterReadBlocking(GDY112X_I2C_BASE, &whoami, 1, kI2C_TransferDefaultFlag);
        PRINTF("Read WHO_AM_I failed, status=%d\r\n", status);
        return;
    // 3) Stop
    PRINTF("WHO_AM_I read success: 0x%02X\r\n", whoami);
/* pin_mux.c/*
void BOARD_InitPins(void)
/* PIO0_8 : FC1_I2C_SCL */
    const uint32_t port0_pin8_config = (/* Pin is configured as FC1_TXD_SCL_MISO_WS*/
                                        IOPCTL_PIO_FUNC1 |
                                        /* Enable pull-up / pull-down function */
                                        IOPCTL_PIO_PUPD_EN |
                                        /* Enable pull-up function */
                                        IOPCTL_PIO_PULLUP_EN |
                                        /* Enables input buffer function */
                                        IOPCTL_PIO_INBUF_EN |
                                        /* Normal mode */
                                        IOPCTL_PIO_SLEW_RATE_NORMAL |
/* Normal drive */
                                        IOPCTL_PIO_FULLDRIVE_DI |
                                        /* Analog mux is disabled */
                                        IOPCTL_PIO_ANAMUX_DI |
                                        /* Pseudo Output Drain is disabled */
                                        IOPCTL_PIO_PSEDRAIN_DI |
                                        /* Input function is not inverted */
                                        IOPCTL_PIO_INV_DI);
    IOPCTL_PinMuxSet(IOPCTL, 0U, 8U, port0_pin8_config);
/* PIO0_9 : FC1_I2C_SDA */
    const uint32_t port0_pin9_config = (/* Pin is configured as FC1_RXD_SDA_MOSI_DATA */
                                        IOPCTL_PIO_FUNC1 |
/* Normal mode */
                                        /* Normal drive */
                                        IOPCTL_PIO_INV_DI);
    IOPCTL_PinMuxSet(IOPCTL, 0U, 9U, port0_pin9_config);
After run, the system hang in function I2C_MasterTransferBlocking(). Please advise
326 次查看
Nazmin
Hi @Pablo_Ramos , this issue solved in ticket Case: 00737268.
348 次查看
Pablo_Ramos
Hi Nazmin,
Could you help me with the following questions?
Do you see any outputs through the I2C pins? If you do, could you share a snippet?
In which instance does I2C_MasterTransferBlocking hang?
If you use the example without any changes, does it work?
Pablo
%3CLINGO-SUB%20id%3D%22lingo-sub-2175470%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EFlexcomm1%20I2C%20%E9%85%8D%E7%BD%AE%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2175470%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CFONT%20face%3D%22times%20new%20roman%2Ctimes%22%3E%E5%97%A8%EF%BC%8C%E5%9B%A2%E9%98%9F%E3%80%81%3C%2FFONT%3E%3C%2FP%3E%3CP%3E%3CFONT%20face%3D%22times%20new%20roman%2Ctimes%22%3E%E6%88%91%E4%B8%80%E7%9B%B4%E5%9C%A8%E5%B0%9D%E8%AF%95%E4%BD%BF%E7%94%A8%20Flexcomm1%20%E9%85%8D%E7%BD%AE%20I2C%E3%80%82%3C%2FFONT%3E%3CFONT%20face%3D%22times%20new%20roman%2Ctimes%22%3E%E6%88%91%E6%97%A0%E6%B3%95%E5%9C%A8%E4%B8%BB%E6%9C%8D%E5%8A%A1%E5%99%A8%E5%92%8C%E4%BB%8E%E6%9C%BA%E4%B9%8B%E9%97%B4%E5%BB%BA%E7%AB%8B%E8%BF%9E%E6%8E%A5%E3%80%82%3C%2FFONT%3E%3CFONT%20face%3D%22times%20new%20roman%2Ctimes%22%3E%E6%88%91%E6%AD%A3%E5%9C%A8%E5%B0%9D%E8%AF%95%E9%80%9A%E8%BF%87%E6%9B%B4%E6%94%B9%E6%89%A7%E8%A1%8C%E7%9B%B8%E5%90%8C%E7%9A%84%E7%A4%BA%E4%BE%8B%E4%BB%A3%E7%A0%81%E3%80%82%E4%BB%A5%E4%B8%8B%E6%98%AF%E4%B8%BA%E4%BB%8E%20FC4%20%E8%BD%AC%E7%A7%BB%E5%88%B0%20FC1%20%E8%80%8C%E5%AF%B9%E7%A4%BA%E4%BE%8B%E4%BB%A3%E7%A0%81%EF%BC%88SDK_2_11_1_EVK%20MIMXRT685%5C%20boards%5C%20evkmimxrt685%5C%20driver_examples%5C%20i2c%5C%20polling_b2b%5C%20master%EF%BC%89%E6%89%80%E5%81%9A%E7%9A%84%E6%9B%B4%E6%94%B9%E7%9A%84%E5%BF%AB%E7%85%A7%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FFONT%3E%3C%2FP%3E%3CDIV%3E%3CDIV%3E%3CSPAN%3E%23define%3C%2FSPAN%3E%20%3CSPAN%3Egdy112x_i2c_base%3C%2FSPAN%3E%3CSPAN%3E%20%20%20%20%20%20%20%20%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3EI2C1%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%23define%3C%2FSPAN%3E%20%3CSPAN%3Ei2c1_master_clock_frequency%3C%2FSPAN%3E%3CSPAN%3E%20%20%3C%2FSPAN%3E%3CSPAN%3ECLOCK_GetFlexCommClkFreq%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E1U%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%23define%3C%2FSPAN%3E%20%3CSPAN%3Egdy112x_i2c_baudrate%3C%2FSPAN%3E%3CSPAN%3E%20%20%20%20%20%20%20%20(%3C%2FSPAN%3E%3CSPAN%3E100000U%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%2F*%20GDY112X%20%E5%9C%B0%E5%9D%80%EF%BC%887%20%E4%BD%8D%EF%BC%89%20*%2F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%23define%3C%2FSPAN%3E%20%3CSPAN%3EGDY112X_7BIT_I2C_ADDR%3C%2FSPAN%3E%3CSPAN%3E%20%20%20%20%20%20%20%20%20%20%20%20(%3C%2FSPAN%3E%3CSPAN%3E0x3A%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CDIV%3E%3CSPAN%3Eint%3C%2FSPAN%3E%20%3CSPAN%3Emain%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3Evoid%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3CDIV%3E%3CDIV%3E%3CSPAN%3E%2F*%20%E5%B0%86%20Flexcomm1%20%E5%88%9D%E5%A7%8B%E5%8C%96%E4%B8%BA%20I2C%20*%2F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CSPAN%3Ei2c_master_config_t%3C%2FSPAN%3E%20%3CSPAN%3E%E4%B8%BB%E9%85%8D%E7%BD%AE%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CDIV%3E%3CSPAN%3EI2C_MasterGetDefaultConfig%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E%26amp%3B%3C%2FSPAN%3E%3CSPAN%3EmasterConfig%3C%2FSPAN%3E%3CSPAN%3E)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%2F*%20%E6%9B%B4%E6%94%B9%E9%BB%98%E8%AE%A4%E6%B3%A2%E7%89%B9%E7%8E%87%E9%85%8D%E7%BD%AE%20*%2F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E4%B8%BB%E9%85%8D%E7%BD%AE%3C%2FSPAN%3E%3CSPAN%3E.%3C%2FSPAN%3E%3CSPAN%3E%E6%B3%A2%E7%89%B9%E7%8E%87_Bps%3C%2FSPAN%3E%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3Egdy112x_i2c_baudrate%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E%2F*%20%E5%88%9D%E5%A7%8B%E5%8C%96%20I2C%20%E4%B8%BB%E5%A4%96%E8%AE%BE%20*%2F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EI2C_MasterInit%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3Egdy112x_i2c_base%3C%2FSPAN%3E%3CSPAN%3E%2C%20%3C%2FSPAN%3E%3CSPAN%3E%26amp%3B%3C%2FSPAN%3E%3CSPAN%3E%E4%B8%BB%E9%85%8D%E7%BD%AE%3C%2FSPAN%3E%3CSPAN%3E%2C%20%3C%2FSPAN%3E%3CSPAN%3Ei2c1_master_clock_frequency%3C%2FSPAN%3E%3CSPAN%3E)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%2F*%E8%AF%A5%E5%87%BD%E6%95%B0%E7%94%A8%E4%BA%8E%E4%BB%8E%E4%B8%BB%E7%AB%99%E5%90%91%E4%BB%8E%E7%AB%99%2F%E4%BB%8E%E4%B8%BB%E7%AB%99%E5%90%91%E4%BB%8E%E7%AB%99%E5%86%99%E5%85%A5%E5%92%8C%E8%AF%BB%E5%8F%96%E6%95%B0%E6%8D%AE%2F*%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Evoid%3C%2FSPAN%3E%20%3CSPAN%3EGDY1121_MinimalI2CTest%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3Evoid%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CDIV%3E%3CSPAN%3E%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3Estatus_t%3C%2FSPAN%3E%20%3CSPAN%3E%E7%8A%B6%E6%80%81%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3Euint8_t%3C%2FSPAN%3E%20%3CSPAN%3Ereg%3C%2FSPAN%3E%20%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3EWHO_AM_I_REG%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3Euint8_t%3C%2FSPAN%3E%20%3CSPAN%3Ewhoami%3C%2FSPAN%3E%20%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3E0%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3EPRINTF%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E%22%E5%BC%80%E5%A7%8B%E6%9C%80%E5%B0%8F%20I2C%20%E6%B5%8B%E8%AF%95...%3C%2FSPAN%3E%3CSPAN%3E%5Cr%5Cn%3C%2FSPAN%3E%3CSPAN%3E%22%3C%2FSPAN%3E%3CSPAN%3E)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CSPAN%3E%2F%2F%201)%20%E5%8F%91%E9%80%81%E5%AF%84%E5%AD%98%E5%99%A8%E5%9C%B0%E5%9D%80%EF%BC%88%E5%86%99%EF%BC%89%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3E%E7%8A%B6%E6%80%81%3C%2FSPAN%3E%20%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3EI2C_MasterStart%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3Egdy112x_i2c_base%3C%2FSPAN%3E%3CSPAN%3E%2C%20%3C%2FSPAN%3E%3CSPAN%3EGDY112X_7BIT_I2C_ADDR%3C%2FSPAN%3E%3CSPAN%3E%2C%20%3C%2FSPAN%3E%3CSPAN%3EkI2C_Write%3C%2FSPAN%3E%3CSPAN%3E)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3E%E5%A6%82%E6%9E%9C%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3Estatus%3C%2FSPAN%3E%20%3CSPAN%3E!%3D%3C%2FSPAN%3E%20%3CSPAN%3EkStatus_Success%3C%2FSPAN%3E%3CSPAN%3E)%20%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3EPRINTF%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E%22%E5%90%AF%E5%8A%A8%EF%BC%88%E5%86%99%E5%85%A5%EF%BC%89%E5%A4%B1%E8%B4%A5%EF%BC%8Cstatus%3D%3C%2FSPAN%3E%3CSPAN%3E%25d%3C%2FSPAN%3E%3CSPAN%3E%5C%E6%80%81%3C%2FSPAN%3E%3CSPAN%3E%22%3C%2FSPAN%3E%3CSPAN%3E%2C%20%3C%2FSPAN%3E%3CSPAN%3Estatus%3C%2FSPAN%3E%3CSPAN%3E)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3E%E8%BF%94%E5%9B%9E%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%26nbsp%3B%20%7D%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3E%E7%8A%B6%E6%80%81%3C%2FSPAN%3E%20%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3EI2C_MasterWriteBlocking%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3Egdy112x_i2c_base%3C%2FSPAN%3E%3CSPAN%3E%2C%20%3C%2FSPAN%3E%3CSPAN%3E%26amp%3B%3C%2FSPAN%3E%3CSPAN%3Ereg%3C%2FSPAN%3E%3CSPAN%3E%2C%20%3C%2FSPAN%3E%3CSPAN%3E1%3C%2FSPAN%3E%3CSPAN%3E%2C%20%3C%2FSPAN%3E%3CSPAN%3EkI2C_TransferNoStopFlag%3C%2FSPAN%3E%3CSPAN%3E)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3E%E5%A6%82%E6%9E%9C%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3Estatus%3C%2FSPAN%3E%20%3CSPAN%3E!%3D%3C%2FSPAN%3E%20%3CSPAN%3EkStatus_Success%3C%2FSPAN%3E%3CSPAN%3E)%20%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3EPRINTF%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E%22%E5%86%99%E6%B3%A8%E5%86%8C%E5%9C%B0%E5%9D%80%E5%A4%B1%E8%B4%A5%EF%BC%8Cstatus%3D%3C%2FSPAN%3E%3CSPAN%3E%25d%3C%2FSPAN%3E%3CSPAN%3E%5C%E7%8A%B6%E6%80%81%3C%2FSPAN%3E%3CSPAN%3E%22%3C%2FSPAN%3E%3CSPAN%3E%2C%20%3C%2FSPAN%3E%3CSPAN%3Estatus%3C%2FSPAN%3E%3CSPAN%3E)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3EI2C_MasterStop%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3Egdy112x_i2c_base%3C%2FSPAN%3E%3CSPAN%3E)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3E%E8%BF%94%E5%9B%9E%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%7D%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CDIV%3E%3CDIV%3E%3CSPAN%3E%2F%2F2)%20%E9%87%8D%E5%90%AF%E5%B9%B6%E8%AF%BB%E5%8F%96%201%20%E5%AD%97%E8%8A%82%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3E%E7%8A%B6%E6%80%81%3C%2FSPAN%3E%20%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3EI2C_MasterRepeatedStart%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3Egdy112x_i2c_base%3C%2FSPAN%3E%3CSPAN%3E%2C%20%3C%2FSPAN%3E%3CSPAN%3EGDY112X_7BIT_I2C_ADDR%3C%2FSPAN%3E%3CSPAN%3E%2C%20%3C%2FSPAN%3E%3CSPAN%3EkI2C_Read%3C%2FSPAN%3E%3CSPAN%3E)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3E%E5%A6%82%E6%9E%9C%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3Estatus%3C%2FSPAN%3E%20%3CSPAN%3E!%3D%3C%2FSPAN%3E%20%3CSPAN%3EkStatus_Success%3C%2FSPAN%3E%3CSPAN%3E)%20%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3EPRINTF%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E%22%E9%87%8D%E5%A4%8D%E5%90%AF%E5%8A%A8%EF%BC%88%E8%AF%BB%E5%8F%96%EF%BC%89%E5%A4%B1%E8%B4%A5%EF%BC%8Cstatus%3D%3C%2FSPAN%3E%3CSPAN%3E%25d%3C%2FSPAN%3E%3CSPAN%3E%5Cr%5Cn%3C%2FSPAN%3E%3CSPAN%3E%22%3C%2FSPAN%3E%3CSPAN%3E%2C%20%3C%2FSPAN%3E%3CSPAN%3Estatus%3C%2FSPAN%3E%3CSPAN%3E)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3EI2C_MasterStop%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3Egdy112x_i2c_base%3C%2FSPAN%3E%3CSPAN%3E)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3E%E8%BF%94%E5%9B%9E%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%26nbsp%3B%20%7D%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3E%E7%8A%B6%E6%80%81%3C%2FSPAN%3E%20%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3EI2C_MasterReadBlocking%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3Egdy112x_i2c_base%3C%2FSPAN%3E%3CSPAN%3E%2C%20%3C%2FSPAN%3E%3CSPAN%3E%26amp%3B%3C%2FSPAN%3E%3CSPAN%3E%E8%AF%BB%E5%8F%96%3C%2FSPAN%3E%3CSPAN%3E%2C%20%3C%2FSPAN%3E%3CSPAN%3E1%3C%2FSPAN%3E%3CSPAN%3E%2C%20%3C%2FSPAN%3E%3CSPAN%3EkI2C_TransferDefaultFlag%3C%2FSPAN%3E%3CSPAN%3E)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3E%E5%A6%82%E6%9E%9C%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3Estatus%3C%2FSPAN%3E%20%3CSPAN%3E!%3D%3C%2FSPAN%3E%20%3CSPAN%3EkStatus_Success%3C%2FSPAN%3E%3CSPAN%3E)%20%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3EPRINTF%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E%22%E8%AF%BB%E5%8F%96%20WHO_AM_I%20%E5%A4%B1%E8%B4%A5%EF%BC%8Cstatus%3D%3C%2FSPAN%3E%3CSPAN%3E%25d%3C%2FSPAN%3E%3CSPAN%3E%5C(......)%E3%80%82%3C%2FSPAN%3E%3CSPAN%3E%22%3C%2FSPAN%3E%3CSPAN%3E%2C%20%3C%2FSPAN%3E%3CSPAN%3Estatus%3C%2FSPAN%3E%3CSPAN%3E)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3EI2C_MasterStop%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3Egdy112x_i2c_base%3C%2FSPAN%3E%3CSPAN%3E)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3E%E8%BF%94%E5%9B%9E%3C%2FSPAN%3E%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%26nbsp%3B%20%7D%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3E%2F%2F%203)%20%E5%81%9C%E6%AD%A2%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3EI2C_MasterStop%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3Egdy112x_i2c_base%3C%2FSPAN%3E%3CSPAN%3E)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3EPRINTF%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E%22WHO_AM_I%20%E8%AF%BB%E5%8F%96%E6%88%90%E5%8A%9F%EF%BC%9A0x%3C%2FSPAN%3E%3CSPAN%3E%2502X%3C%2FSPAN%3E%3CSPAN%3E%5C%E8%AF%BB%E5%8F%96%E6%88%90%E5%8A%9F%3C%2FSPAN%3E%3CSPAN%3E%22%3C%2FSPAN%3E%3CSPAN%3E%2C%20%3C%2FSPAN%3E%3CSPAN%3Ewhoami%3C%2FSPAN%3E%3CSPAN%3E)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%7D%3C%2FSPAN%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CP%3E%3CFONT%20face%3D%22times%20new%20roman%2Ctimes%22%3E%26nbsp%3B%3C%2FFONT%3E%3C%2FP%3E%3CP%3E%3CFONT%20face%3D%22times%20new%20roman%2Ctimes%22%3E%2F*%20pin_mux.c%2F*%3C%2FFONT%3E%3C%2FP%3E%3CDIV%3E%3CDIV%3E%3CSPAN%3Evoid%3C%2FSPAN%3E%20%3CSPAN%3EBOARD_InitPins%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3Evoid%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CDIV%3E%3CSPAN%3E%2F*%20PIO0_8%20%EF%BC%9AFC1_I2C_SCL%20*%2F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3Econst%3C%2FSPAN%3E%20%3CSPAN%3Euint32_t%3C%2FSPAN%3E%20%3CSPAN%3Eport0_pin8_config%3C%2FSPAN%3E%20%3CSPAN%3E%3D%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E%2F*%20%E5%BC%95%E8%84%9A%E9%85%8D%E7%BD%AE%E4%B8%BA%20FC1_TXD_SCL_MISO_WS*%2F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3Eiopctl_pio_func1%3C%2FSPAN%3E%20%3CSPAN%3E%7C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%2F*%20%E5%90%AF%E7%94%A8%E4%B8%8A%E6%8B%89%2F%E4%B8%8B%E6%8B%89%E5%8A%9F%E8%83%BD%20*%2F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3Eiopctl_pio_pupd_en%3C%2FSPAN%3E%20%3CSPAN%3E%7C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%2F*%20%E5%90%AF%E7%94%A8%E4%B8%8A%E6%8B%89%E5%8A%9F%E8%83%BD%20*%2F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3Eiopctl_pio_pullup_en%3C%2FSPAN%3E%20%3CSPAN%3E%7C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%2F*%20%E5%90%AF%E7%94%A8%E8%BE%93%E5%85%A5%E7%BC%93%E5%86%B2%E5%8C%BA%E5%8A%9F%E8%83%BD%20*%2F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3Eiopctl_pio_inbuf_en%3C%2FSPAN%3E%20%3CSPAN%3E%7C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%2F*%20%E6%AD%A3%E5%B8%B8%E6%A8%A1%E5%BC%8F%20*%2F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3Eiopctl_pio_slew_rate_normal%3C%2FSPAN%3E%20%3CSPAN%3E%7C%3C%2FSPAN%3E%3CDIV%3E%3CDIV%3E%3CSPAN%3E%2F*%20%E6%AD%A3%E5%B8%B8%E9%A9%B1%E5%8A%A8%20*%2F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3Eiopctl_pio_fulldrive_di%3C%2FSPAN%3E%20%3CSPAN%3E%7C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%2F*%20%E6%A8%A1%E6%8B%9F%E5%A4%9A%E8%B7%AF%E5%A4%8D%E7%94%A8%E5%99%A8%E5%B7%B2%E7%A6%81%E7%94%A8%20*%2F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3Eiopctl_pio_anamux_di%3C%2FSPAN%3E%20%3CSPAN%3E%7C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%2F*%20%E4%BC%AA%E8%BE%93%E5%87%BA%E6%BC%8F%E6%9E%81%E5%B7%B2%E7%A6%81%E7%94%A8%20*%2F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3Eiopctl_pio_psedrain_di%3C%2FSPAN%3E%20%3CSPAN%3E%7C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%2F*%20%E8%BE%93%E5%85%A5%E5%87%BD%E6%95%B0%E6%9C%AA%E5%8F%8D%E8%BD%AC%20*%2F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3Eiopctl_pio_inv_di%3C%2FSPAN%3E%3CSPAN%3E)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3EIOPCTL_PinMuxSet%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3EIOPCTL%3C%2FSPAN%3E%3CSPAN%3E%2C%20%3C%2FSPAN%3E%3CSPAN%3E0U%3C%2FSPAN%3E%3CSPAN%3E%2C%20%3C%2FSPAN%3E%3CSPAN%3E8U%3C%2FSPAN%3E%3CSPAN%3E%2C%20%3C%2FSPAN%3E%3CSPAN%3E%E7%AB%AF%E5%8F%A3%200_pin8_config%3C%2FSPAN%3E%3CSPAN%3E)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CDIV%3E%3CSPAN%3E%2F*%20PIO0_9%20%EF%BC%9AFC1_I2C_SDA%20*%2F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3Econst%3C%2FSPAN%3E%20%3CSPAN%3Euint32_t%3C%2FSPAN%3E%20%3CSPAN%3Eport0_pin9_config%3C%2FSPAN%3E%20%3CSPAN%3E%3D%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E%2F*%20%E5%BC%95%E8%84%9A%E9%85%8D%E7%BD%AE%E4%B8%BA%20FC1_RXD_SDA_MOSI_DATA%20*%2F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3Eiopctl_pio_func1%3C%2FSPAN%3E%20%3CSPAN%3E%7C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%2F*%20%E5%90%AF%E7%94%A8%E4%B8%8A%E6%8B%89%2F%E4%B8%8B%E6%8B%89%E5%8A%9F%E8%83%BD%20*%2F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3Eiopctl_pio_pupd_en%3C%2FSPAN%3E%20%3CSPAN%3E%7C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%2F*%20%E5%90%AF%E7%94%A8%E4%B8%8A%E6%8B%89%E5%8A%9F%E8%83%BD%20*%2F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3Eiopctl_pio_pullup_en%3C%2FSPAN%3E%20%3CSPAN%3E%7C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%2F*%20%E5%90%AF%E7%94%A8%E8%BE%93%E5%85%A5%E7%BC%93%E5%86%B2%E5%8C%BA%E5%8A%9F%E8%83%BD%20*%2F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3Eiopctl_pio_inbuf_en%3C%2FSPAN%3E%20%3CSPAN%3E%7C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CDIV%3E%3CSPAN%3E%2F*%20%E6%AD%A3%E5%B8%B8%E6%A8%A1%E5%BC%8F%20*%2F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3Eiopctl_pio_slew_rate_normal%3C%2FSPAN%3E%20%3CSPAN%3E%7C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%2F*%20%E6%AD%A3%E5%B8%B8%E9%A9%B1%E5%8A%A8%20*%2F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3Eiopctl_pio_fulldrive_di%3C%2FSPAN%3E%20%3CSPAN%3E%7C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%2F*%20%E6%A8%A1%E6%8B%9F%E5%A4%9A%E8%B7%AF%E5%A4%8D%E7%94%A8%E5%99%A8%E5%B7%B2%E7%A6%81%E7%94%A8%20*%2F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3Eiopctl_pio_anamux_di%3C%2FSPAN%3E%20%3CSPAN%3E%7C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%2F*%20%E4%BC%AA%E8%BE%93%E5%87%BA%E6%BC%8F%E6%9E%81%E5%B7%B2%E7%A6%81%E7%94%A8%20*%2F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3Eiopctl_pio_psedrain_di%3C%2FSPAN%3E%20%3CSPAN%3E%7C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%2F*%20%E8%BE%93%E5%85%A5%E5%87%BD%E6%95%B0%E6%9C%AA%E5%8F%8D%E8%BD%AC%20*%2F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3Eiopctl_pio_inv_di%3C%2FSPAN%3E%3CSPAN%3E)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%3C%2FSPAN%3E%3CSPAN%3EIOPCTL_PinMuxSet%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3EIOPCTL%3C%2FSPAN%3E%3CSPAN%3E%2C%20%3C%2FSPAN%3E%3CSPAN%3E0U%3C%2FSPAN%3E%3CSPAN%3E%2C%20%3C%2FSPAN%3E%3CSPAN%3E9U%3C%2FSPAN%3E%3CSPAN%3E%2C%20%3C%2FSPAN%3E%3CSPAN%3E%E7%AB%AF%E5%8F%A3%200_pin9_config%3C%2FSPAN%3E%3CSPAN%3E)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%7D%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%3CSPAN%3E%E8%BF%90%E8%A1%8C%E5%90%8E%EF%BC%8C%E7%B3%BB%E7%BB%9F%E5%9C%A8%E5%87%BD%E6%95%B0%20%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%3EI2C_MasterTransferBlocking()%E5%87%BD%E6%95%B0%E4%B8%AD%E6%8C%82%E8%B5%B7%E3%80%82%E8%AF%B7%E6%8C%87%E7%A4%BA%3C%2FSPAN%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2177766%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Flexcomm1%20I2C%20configuration%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2177766%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F231808%22%20target%3D%22_blank%22%3E%40Pablo_Ramos%3C%2FA%3E%EF%BC%8C%E6%AD%A4%E9%97%AE%E9%A2%98%E5%B7%B2%E5%9C%A8%E7%A5%A8%E6%8D%AE%E4%B8%AD%E8%A7%A3%E5%86%B3%20%3CSPAN%3E%3CA%20href%3D%22https%3A%2F%2Fsupport.nxp.com%2Fs%2Fcase%2F500Tg00000PqSJaIAN%2Fic-communication-issue-with-rt685-evk-and-gdy1121-barometer-sensor%3Flanguage%3Den_US%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%E6%A1%88%E4%BE%8B%3A%2000737268.%3C%2FA%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2177743%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Flexcomm1%20I2C%20configuration%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2177743%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%EF%BC%8C%E7%BA%B3%E5%85%B9%E6%98%8E%E3%80%81%3C%2FP%3E%0A%3CP%3E%E6%82%A8%E8%83%BD%E5%B8%AE%E6%88%91%E8%A7%A3%E5%86%B3%E4%BB%A5%E4%B8%8B%E9%97%AE%E9%A2%98%E5%90%97%EF%BC%9F%3C%2FP%3E%0A%3CP%3EI2C%20%E5%BC%95%E8%84%9A%E6%9C%89%E8%BE%93%E5%87%BA%E5%90%97%EF%BC%9F%E5%A6%82%E6%9E%9C%E6%9C%89%EF%BC%8C%E8%83%BD%E5%90%A6%E5%88%86%E4%BA%AB%E4%B8%80%E4%B8%AA%E7%89%87%E6%AE%B5%EF%BC%9F%3C%2FP%3E%0A%3CP%3EI2C_MasterTransferBlocking%20%E5%9C%A8%E5%93%AA%E7%A7%8D%E6%83%85%E5%86%B5%E4%B8%8B%E4%BC%9A%E6%8C%82%E8%B5%B7%EF%BC%9F%3C%2FP%3E%0A%3CP%3E%E5%A6%82%E6%9E%9C%E4%B8%8D%E5%81%9A%E4%BB%BB%E4%BD%95%E6%94%B9%E5%8A%A8%E5%B0%B1%E4%BD%BF%E7%94%A8%E8%AF%A5%E7%A4%BA%E4%BE%8B%EF%BC%8C%E6%98%AF%E5%90%A6%E5%8F%AF%E8%A1%8C%EF%BC%9F%3C%2FP%3E%0A%3CP%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FP%3E%0A%3CP%3E%E5%B7%B4%E5%8B%83%E7%BD%97%3C%2FP%3E%3C%2FLINGO-BODY%3E
