I understood but what i dont get is, How it links with the internal execution.
For example, Read Sequence is present in index zero of LUT table in the example you shared. If I place the Read Sequence at index 10 will it work?
How controller recognizes which is read sequence, Erase and other config sequences?
Where are we specifying these commands or is there any preconditions like Read should always start from index zero like that?
