FLEXCan RxIdle triggers on FLEXCAN_TransferSendNonBlocking
1,635 次查看
_bjs
How it is possible that Rx-Idle triggers on a Send command?
How do i fix it?
1,624 次查看
_bjs
Problem solved by use of:
https://community.nxp.com/t5/i-MX-RT/IMXRT1062-Flexcan-FD-FIFO-Example/m-p/898644#M2914
This example can make a single mask for every item in the fifo queue, works very nice!
1,625 次查看
_bjs
