Ethernet based camera interfacing
1,297 次查看
jagadeesh_11
Can we interface the IP camera in RT1170  EVK via ethernet.
Please Guide us.
Jagadeesh
1,282 次查看
gusarambula
Hello Jagadeesh,
You should be able to receive the IP camera stream on the i.MXRT1170. There is not an example with the IP Camera implementation per se. However, the i.MXRT1170 SDK have some Ethernet and lwip examples, which may help as a starting point.
Gustavo
