Efuse burning using MfgTools/Flashloader
1,700 次查看
farid_mabrouk
@kerry Zhou
I hope you are doing well!
I have been able to use MCUboot Utility to burn the efuses and program the flash; thank you for helping with that!
Now our requirements changed, we need to do all the efuse burning and flash programming using Flashloader/MfgTools. Could you please recommend and user guide or document I could use to do the flash programming and efuse burning.
what are the registers addresses and names for efuses burning?
Thank you all for your help!
1,660 次查看
kerryzhou
Hi Andre marcus ,
   Thanks a lot for your trust, you can refer to the application note AN12079:
https://www.nxp.com/webapp/sps/download/mod_download.jsp?colCode=AN12079&location=null&appType=moder...
  Chapter 4.3. Program fuse
Wish it helps you!
If you still have questions about it, please kindly let me know.
Kerry
